ZYNQ7010 ZYNQ7020+USB3320C-EZK_6+RTL8169SB 做的PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1LED_LEDSC95P220X135X40-2N_FPGA_FPGA_DONELEDSC95P220X135X40-2ND2DIODE_DIOM6032X280N_DIODEDIODEDIOM6032X280NDP1CON20A_SHDR0S254P10X2_3300X900XCON20ASHDR0S254P10X2_3300X900X500DP2CON12A_SHDR0S254P6X2_2284X900X5CON12ASHDR0S254P6X2_2284X900X500DP3CON20A_SHDR0S254P10X2_3300X900XCON20ASHDR0S254P10X2_3300X900X500DP4CON20A_SHDR0S254P10X2_3300X900XCON20ASHDR0S254P10X2_3300X900X500DP5CON20A_SHDR0S254P10X2_3300X900XCON20ASHDR0S254P10X2_3300X900X500DP6CON12A_SHDR0S254P6X2_2284X900X5CON12ASHDR0S254P6X2_2284X900X500F1FUSE_SMC0805_500MA_MFU00003500mASMC0805HDMIHDMICONNECTOR_MINI_HDMI_HDMI CHDMIConnectorMINI_HDMIIIC1CON4_SHDR0S254P4X1_1000X300X500CON4SHDR0S254P4X1_1000X300X500J2GE_RJ45_GE_RJ45_GE_RJ45GE_RJ45GE_RJ45J5CON4_SHDR0S254P4X1_1000X300X500CON4SHDR0S254P4X1_1000X300X500J6MICROSD_2_MICRO_SD_MICRO SD_2MicroSD_2MICRO_SDJ72-JUMPER_JUMPER2_2-JUMPER2-JumperJUMPER2J8USB_TYPEA_USB_TYPEA_USB_TYPEAUSB_TYPEAUSB_TYPEAJ10CON40_FFC_0P5_40PIN_CON40CON40FFC_0P5_40PINJ13CON3_CN1_DCJACK_CON3CON3CN1_DCJACKJ15CON8A_SHDR0S254P4X2_1200X600X50CON8ASHDR0S254P4X2_1200X600X500J162-JUMPER_SMC0805_2-JUMPER2-JumperSMC0805J172-JUMPER_SMC0805_2-JUMPER2-JumperSMC0805JTAGHEADER14_SHDR0S254P7X2_2538X90JTAGSHDR0S254P7X2_2538X900X500L1INDUCTOR_C0603_INDUCTORINDUCTORC0603L2INDUCTOR_C0805_120OHM@100MHZ120OHM@100MHzC0805L3INDUCTOR_INDP4232X280N_2.2UH2.2uHINDP4232X280NL4INDUCTOR_INDP7070X280N_2.2UH502.2uH5000mAINDP7070X280NL5INDUCTOR_INDP7070X280N_2.2UH502.2uH5000mAINDP7070X280NL6INDUCTOR_INDP7070X280N_2.2UH502.2uH5000mAINDP7070X280NL7INDUCTOR_INDP7070X280N_2.2UH502.2uH5000mAINDP7070X280NL8INDUCTOR_C0805_INDUCTORINDUCTORC0805L9INDUCTOR_INDP7070X280N_2.2UH502.2uH5000mAINDP7070X280NOPV_SWCON3_SHDR0S254P3X1_1000X570X500POWERSHDR0S254P3X1_1000X570X500RN21RESAR_IS_4/SM_CAPCAF80P160X320XRESAR_IS_4/SMCAPCAF80P160X320X100-8NSW1BUTTON_KEY735SO_BUTTONButtonKEY735SOSW2SWKEY-DPDT_KEY_DPDT_SW KEY-DPDSWKEY-DPDTKEY_DPDTU1ZYNQ7010/7020_CLG400_ZYNQ7010/7Zynq7010/7020CLG400U2RTL8211E_RTL8211_QFN48_8169SB8169SBRTL8211_QFN48U3MT41J256M16_FBGA_96_MT41J256M16MT41J256M16FBGA_96U5TCM811TERCTR_TCM811TERCTR_TCM81TCM811TERCTRTCM811TERCTRU6CRYSTAL4_OSCCC290X385X150-4N_3333.33333.MHzOSCCC290X385X150-4NU7CRYSTAL4_OSCCC290X385X150-4N_5050MHzOSCCC290X385X150-4NU8W25Q256FV_MLP8_W25Q256FVW25Q256FVMLP8U9USB3320C-EZK_6_USB3320C_USB3320USB3320C-EZK_6USB3320CU10TPS2051BDBV_TPS2051BDBV_TPS2051TPS2051BDBVTPS2051BDBVU11TLV62130RGT_5_TLV62130RGT_TLV62TLV62130RGTTLV62130RGTU12TLV62130RGT_5_TLV62130RGT_TLV62TLV62130RGTTLV62130RGTU13TLV62130RGT_5_TLV62130RGT_TLV62TLV62130RGTTLV62130RGTU14TLV62130RGT_5_TLV62130RGT_TLV62TLV62130RGTTLV62130RGTU15ADG3308_SOIC65P640X140-20N_ADG3ADG3308SOIC65P640X140-20NU16ADG3308_SOIC65P640X140-20N_ADG3ADG3308SOIC65P640X140-20NU17TLV62130RGT_5_TLV62130RGT_TLV62TLV62130RGTTLV62130RGTU18AMS1117-3.3_SOT230P700X180-4N_AAMS1117-3.3SOT230P700X180-4NU19IF_NC7WZ07_NC7WZ07_NC7WZ07P6X_INC7WZ07P6XNC7WZ07U20IF_NC7SZ125_NC7SZ125_NC7SZ125_INC7SZ125NC7SZ125U21IF_GTL2002D_GTL2002D_GTL2002D_IGTL2002DGTL2002DU22PW_TPS2051BDBV_TPS2051BDBV_TPS2TPS2051BDBVTPS2051BDBVUART0CON4_SHDR0S254P4X1_1000X300X500CON4SHDR0S254P4X1_1000X300X500UART1CON4_SHDR0S254P4X1_1000X300X500CON4SHDR0S254P4X1_1000X300X500Y2CRYSTAL_OSCSC254P460X320X170-2N24MHzOSCSC254P460X320X170-2NY3CRYSTAL_OSCSC254P460X320X170-_125MHzOSCSC254P460X320X170-2N PCB 文件来了。回复可见
**** Hidden Message ***** 学习学习,谢谢分享…
