MT6735M MTK6735M 智能手机PCB文件和原理图共享
NamePCB DecalPart TypeValueANT3301ELJ_DZ_F2ELJ_DZ_F2POGO PINANT5102ELJ_ANTPTH_LTPG-PT0H43-CB01ELJ_ANTPTH_LTPG-PT0H43-CB01POGO PINB6000L0603B0603-2500RBLM18BD252SN1BEAD2001L0402BEAD-0402BLM15BD102SN1DBEAD5001B0402FB_/_BLM15AG121SN1FB / BLM15AG601SN1BEAD6010L0402BEAD-0402BLM15BD102SN1DBEAD6200R0402BEAD-04020RC1C0201C0201L / 6.8 / nH / 0201CN6001ELJ_CMUS-06505-097-03ELJ_CMUS-06505-097-03KM0004U5P-03-06CON1ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3FH26-39S-0.3CON3302ELJ_RF_MM8030-2610RK0_2X2X1MMELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1CON3401ELJ_RF_MM8030-2610RK0_2X2X1MMELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1CON6002ELJ_ADJ-312-P2.0-3.9X_H4.2ELJ_ADJ-312-P2.0-3.9X_H4.2ADJ-312-P2.0-3.9X(反)D2000SOD323/SMD/MM3Z2V4T1TVS-6V2-PZ3D4V2H-ROHMPZ3D4V2H (PRISEMI)D6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45D6101SOD123DIODE_SCHOTTKY_2MM1Z5VD6102SOT23_3BAT54SBAT54SD6103SOD123DIODE_SCHOTTKY_2MM1Z20VD6108SOT23_3BAT54SBAT54SD6109SOD123DIODE_SCHOTTKY_21N5819D6110SOD123DIODE_SCHOTTKY_21N5819EMI6001FILTER/SMD/TCM0806GEMIX21A390FNPE_1NCH1000PTH_HOLE_1.6/2.8MMPTH_HOLE_1.6/2.8MMDNIH1001PTH_HOLE_1.6/2.8MMPTH_HOLE_1.6/2.8MMDNIJ1ELJ-KS270013ELJ-KS270013J25ELJ_HXQKTS-088_2_4ELJ_HXQKTS-088_2_4HX-088 2*4J26V30SIM(H3.0MM)DUALSIMALP-SIMD618-01J31ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5J32ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9NCJ6001C0805NC-CON-2-0805NCJ6003REC_DYS-1506T2332-W01REC_DYS-1506T2332-W01NCJ6006C0805NC-CON-2-0805NCJ6101ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5J6102ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3FPC51P-0.3MMJ6502SOCKET-SIM-LK-SIM437-0615RSOCKET-SIM-LK-SIM437-0615RS0DD-180006-01GJ6503ELJ_YHTKP-1915-W_PHS_H1.9ELJ_YHTKP-1915-W_PHS_H1.9YHTKP-1915-CJ6601NC-PADX2-1X1.5NC-CON-2-0805NCJ6602NC-PADX2-1X1.5NC-CON-2-0805NCL1302L0402L0402-1N01.0nH_0.3nHL2000IND2520L2520-22U0.33uH_252012L2001L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2002L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2003L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L2004IND2016L2520-22U2.2uH_201610L2005IND252010L2520-ELLYFJ100M1uH_252010/NCL2020L/IND/SMD/2520L/IND/SMD/25201uHL6003L0402L0402-1N01.0nH_0.3nHL6101MPH252012MPH252012NRH2410T4R7MNL6103CD43IND-CD4310uHL6105MPH252012MPH252012NRH2410T4R7MNLED6201FLASHLED_SMD_EFF-D8CA-POOTFLASHLED_SMD_EFF-D8CA-POOTFLASH LEDMARK1000MARK_ALLMARK_ALL_ADNIMARK1001MARK_ALLMARK_ALL_ADNIMARK1002MARK_ALLMARK_ALL_ADNIMARK1003MARK_ALLMARK_ALL_ADNINTC2000R0402RES0402NTCG104EF104FNTC3201R0402R0402-0RNTC / NTCG064EF104FQ6101SC-75_SOT-416_DTC114EET1-DSC-75_SOT-416_DTC114EET1-DNC DTC114YET1Q6102SC-75_SOT-416_DTC114EET1-DSC-75_SOT-416_DTC114EET1-DNC DTC114YET1Q6103SOT23_3IRF5210/TO_6WPM2026Q6104SOT23_3NPN_BECMMBT3904SH2100KLINK_NO_PAD_0.1MM_TOPKLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILSH6100NC_SHORT_0402NC_SHORT_0402SHORT1002KLINK_NO_PAD_0.1MM_TOPKLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILTP_SYSRST_BTP/SMD/0.5MMTP_0.5TP_URXD1101TP_1.0TP1.0MMTP_UTXD1101TP_1.0TP1.0MMU11ELI-MXC400XXC_6P_17X11.8_H0.9MMELI-MXC400XXC_6P_17X11.8_H0.9MMU1000MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735MU2001FAN54015FAN54015U2002MT6328/VFBGA205/P0.4/B0.25/6.6X6.6MT6328/VFBGA205/P0.4/B0.25/6.6X6.6MT6328V/AU2003WDFN8/SMD/P0.5/NCP6324WDFN8/SMD/P0.5/NCP6324NCP6324CMTAATBGU2305CP2155CP2155CP2155DN10-A1U3001FBGA178/SMD/B0.4/3-IN-1FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bU3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBABGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001U3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169U310226M_VTCXO_2520_2016_T_V26M_VTCXO_2520_2016_T_VVTCXO / 26 / MHz / KT2520F26000DCW28QAKU3203SKY77643SKY77643SKY77643/HRSMAC001/RF5410U3215BALUN/SMD/HHM22112A2BALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBU3303RF1628SPDT_/_BGS12SL6_2SPDT / RF1628AU3304DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAW-DPX-RX-BAL_2DPX / SAYEY806MBA0F0AU3306SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYRF1G95CA0B0AR05U3307SKY77910SKY77910SKY77910/HRTXAB008/RF5210U3308SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYFH2G53CCOFOA U3309SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814SAYFH1G74CA0B0AU3310FILTER/SMD/TFSL06050915-4108B1SAW_0_2LPF / TFSL06050915-4108B1 / NCU3311DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAW-DPX-RX-BAL_2DPX / SAYEY710MBA0F0AU3312DUPLEXER/8P/SMD/SAYEY710MBA0F0ASAW-DPX-RX-BAL_2SAYEY1G88BA0B0AU3313SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814SAYFH836MCC0F0A/SAYEY836MCA0F0AU3314SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814SAYFH1G74CA0B0AU3316SAW-SAYRF1G73CA0F0A-2016-1814SAW-SAYRF1G73CA0F0A-2016-1814SAYEY897MCA0B0AU3318BALUN/SMD/TFSZ06052460-3310A2BAL_/_TFSZ06051897-3317A1_2BAL / TFSZ06050775-3338A1U3329SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3338BALUN/SMD/TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2TFSZ06051897-3317A1U3401SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3402SKY13414IC/SP6T/SKY13416_0SP5T / SKY13416U3404SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3405SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3406SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3407SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0AU3408SAWFILTER/SMD/F6QB2G595P2BSSAWFILTER/SMD/SAFFB1G90FB0F0ASAW / B9898U3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB710MAA0F0AU3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB806MAA0F0AU3414FILTER/SMD/TFSL06050915-4108B1SAW_0_2LPF / TFSL06050915-4108B1 / NCU3468BALUN/SMD/TFSZ06052460-3310A2BAL_/_TFSZ06051897-3317A1_1BAL / TFSZ06050775-3338A1U3474RF1628SPDT_/_BGS12SL6_2SPDT / RF1628AU5101MT6625/SQFN40/SMD/P0.4/5X5MT6611_SMD_WLCSP-61_0U / MT6625L / QFN40U5102SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATASAFEB1G57KE0F00U5103MAX2659IC-GPS-LNAP-MAX2659-MAXIMMAX2659ELTU5104KLJ_TPX205950MT-7110A1_1.1X2X0.9KLJ_TPX205950MT-7110A1_1.1X2X0.9TRPX / TDK TPX205950MT-7110A1U5105SAW-1411SAFEB1G57KA0F00FBAR / ACPF-7124U6103SOT23_6AP3031_0CP2121ST-B2/TCS23352U6105SOT23_5TCS4150-EWD1013EA/TCS4150-EU6109SOT23_6AP3031_0EUP2530/CP2123ST-B1U6305CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMU6401G-SENSOR-MMC3516XPJ_1.6X1.6_H0.7M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7U6402STK3171STK3171STK3171U6403TLE4917OCH167TWADU6404BMA250IC-3-A-ACCELEROMETER-BMA250-BOSCHBMA223U6705GSL915GSL915VR2001R0402VR0402SFI0402-180E10RPP-LFVR2002R0402VR0402SFI0402-180E10RPP-LFVR2003SOD-323PTVSHC3D4V5BNC PTVSHC3D4V5BVR6000MLV0402VAR_0402SFI0402-180E10RPP-LFVR6001MLV0402VAR_0402SFI0402-180E10RPP-LFVR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45VR6004R0402VR0402SFI0402-180E10RPP-LFVR6005R0402VR0402SFI0402-180E10RPP-LFVR6006R0402VR0402EZJZ0V500AAVR6007R0402VR0402EZJZ0V500AAVR6008MLV0402VAR_0402SFI0402-180E10RPP-LFVR6009MLV0402VAR_0402SFI0402-180E10RPP-LFVR6010MLV0402VAR_0402SFI0402-180E10RPP-LFVR6011R0402VR0402NCVR6012R0402VR0402NCVR6015R0402VR0402SFI0402-180E10RPP-LFVR6026ESD5641D07ESD5641D07NC ESD5641D07VR6501R0402VR0402EZJZ0V500AAVR6502R0402VR0402EZJZ0V500AAVR6503R0402VR0402EZJZ0V500AAVR6504R0402VR04020_5%VR6512R0402VR0402SFI0402-180E10RPP-LFVR6515R0402VR0402EZJZ0V500AAVR6516R0402VR0402EZJZ0V500AAX2000CRYS/SMD/3.2X1.5/9H032000XX/TXCCRYS/SMD/3.2X1.5/9H032000XX/TXCNC 32.768KHz±20ppmX510126M_TCXO_2520TC7L26002015_2016L2642126M_TCXO_2520TC7L26002015_2016L26421NC TCXO / 26 / MHz / IT2205AE PCB 和原理图一起打包。回复可见下载
**** Hidden Message ***** 老吴一出,必属精品 下载下来瞻仰一下。
