armclub 发表于 2022-1-20 22:17
高端路由器PCB IPQ5018+QCN9074+QCA8081+QPF4288SB+QPF4588SB
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1TB8S_0_BRIDGE_SMD_B__TB8STB8SBRIDGE_SMD_BD2TB8S_0_BRIDGE_SMD_B__TB8STB8SBRIDGE_SMD_BD4ZD_0_DO-214AA_SMCJ58CASMCJ58CADO-214AAD5ZD_DO-214AA_SS310SS310DO-214AAD61_7.5KE100A_DO-214AB__SK810/100SK810/100V/NCDO-214ABD71_7.5KE100A_DO-214AB__SK810/1_1SK810/100VDO-214ABDS1LED-ANODE1_0_0603LED_GREENGREEN0603LEDDS2LED-ANODE1_0_0603LED_GREENGREEN0603LEDDS3LED-ANODE1_0_0603LED_GREENGREEN0603LEDDS4LED-ANODE1_0_0603LED_GREENGREEN0603LEDDS5LED-ANODE1_0_0603LED_GREENGREEN0603LEDDS6LED-ANODE1_0_0603LED_GREENGREEN0603LEDE1EC_EC3D5-8_33UF/100V33uF/100VEC3D5-8E2IND_MAG_HIND_MAG2PIN_V1_2P040_2120OHM@100MHZ2P0402RE3L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE4L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE5L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE6L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE7L_2_2P0402R_BEAD/120R_100MHZ/1.bead/120R_100MHz/1.3A/04022P0402RE8L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE9L_2_2P0402R_120R/100MHZ/1.3A120R/100MHz/1.3A2P0402RE10IND_MAG_HIND_MAG2PIN_V1_2P0402R120OHM@100MHZ2P0402R_SDE11IND_MAG_HIND_MAG2PIN_V1_2P040_1120OHM@100MHZ2P0402ROFSE12IND_MAG_HIND_MAG2PIN_V1_2P040_2120OHM@100MHZ2P0402RE13IND_MAG_HIND_MAG2PIN_V1_2P0805R60R/100MHz/3.0A/08052P0805REE1L_4_2P0402R_1000R/100MHZ1000R/100MHz2P0402REE2L_4_2P0402R_1000R/100MHZ1000R/100MHz2P0402REE3L_4_2P0201R_RF_75R/100MHZ/300MA75R/100MHz/300mA2P0201R_RFEE4L_4_2P0201R_RF_75R/100MHZ/300MA75R/100MHz/300mA2P0201R_RFEE5L_4_2P0402R_120R/100MHZ/1300MA120R/100MHz/1300mA2P0402REE6L_4_2P0201R_RF_600R/100MHZ/280M600R/100MHz/280mA2P0201R_RFEE7L_4_2P0402R_120R/100MHZ/1300MA120R/100MHz/1300mA2P0402REE8L_4_2P0402R_120R/100MHZ/1300MA120R/100MHz/1300mA2P0402REE9L_4_2P0201R_RF_75R/100MHZ/300MA75R/100MHz/300mA2P0201R_RFEE10L_4_2P0201R_RF_33R/100MHZ/750MA33R/100MHz/750mA2P0201R_RFEE11L_4_2P0201R_RF_33R/100MHZ/750MA33R/100MHz/750mA2P0201R_RFEE12L_4_2P0402R_120R_100MHZ/1300MA120R_100MHz/1300mA2P0402REE13L_4_2P0402R_120R/100MHZ/1300MA120R/100MHz/1300mA2P0402REE14L_4_2P0201R_RF_600R/100MHZ/280M600R/100MHz/280mA2P0201R_RFEE15L_4_2P0201R_RF_600R/100MHZ/280M600R/100MHz/280mA2P0201R_RFEE16L_4_2P0402R_120R/100MHZ/NC120R/100MHz/NC2P0402RFB1RES_R0805_3A3AR0805FB2RES_R0805_3A3AR0805FFL1BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FFL2BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FFL3BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FFL4BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FL1BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FL2BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FL3BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1FL4BPF-BF2012-L5R5DAB_0_3PSM67X35NRFBPF1608060K88Q1C/NC3PSM67X35NV1H1SMTSO-M3-3-ET_1PCY161X161P_NT1RNT1R30001PCY161X161PH2SMTSO-M3-3-ET_M2D2-4D2_SMTSO-M3SMTSO-M3-3-ETM2D2-4D2H14SMTSO-M3-3-ET_1PCY161X161P_NT1RNT1R30001PCY161X161PJ1IPEX_1_JACK-COAXIAL-4P-PINDOWN_IPEXJACK-COAXIAL-4P-PINDOWNJ2SMA/UFLR_3SCOXSV4_I-PEX/20279-0I-PEX/20279-001E-013SCOXSV4J3SMA/UFLR_3SCOXSV4_I-PEX/20279-0I-PEX/20279-001E-013SCOXSV4J4SMA/UFLR_3SCOXSV4_I-PEX/20279-0I-PEX/20279-001E-013SCOXSV4J5SMA/UFLR_3SCOXSV4_I-PEX/20279-0I-PEX/20279-001E-013SCOXSV4J6SMA/UFLR_3SCOXSV4_I-PEX/20279-0I-PEX/20279-001E-013SCOXSV4J7PJ-A1-BDBH-FD0NN-1_0_RJ45-1XLEDPJ-A1-BDBH-FD0NN-1RJ45-1XLEDJ8PJ-A1-BDBH-FD0NN-1_0_RJ45-1XLEDPJ-A1-BDBH-FD0NN-1RJ45-1XLEDJ9CONPOWERJACK_POWER-JACK_PJ-102PJ-102AHPOWER-JACKJ10IPEX_1_JACK-COAXIAL-4P-PINDOWN_IPEXJACK-COAXIAL-4P-PINDOWNJ1178119-1209_4_FPC8-0_5MM_78119-178119-1209FPC8-0_5MMJ12CONN_4_CONN_S_1_J4X1_CONN_4_CONCONN_4_CONN_S_4PINJ4X1JX1IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8JX2IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8JX3IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8JX4IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8JX5IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8JX6IPEX_0_RF-CON-SMA-S-2_8_SMASMARF-CON-SMA-S-2_8L1L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFL2IND_MAG_HIND_MAG2PIN_2PSM169X163.3uH/2.9A/4.0/4.0/1.8mm2PSM169X169NV3L3L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFL4L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFL5L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFL6L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFL7L_4_2PSM205X205NV6_3.3UH/4.6A_13.3uH/4.6A/5.0*5.0*4.0mm2PSM205X205NV6L8L_4_2PSM205X205NV6_4.7UH/3.9A/54.7uH/3.9A/5.0/5.0/4.0mm2PSM205X205NV6L9IND_MAG_HIND_MAG2PIN_2PSM169X_12.2uH/3.2A/4.0/4.0/1.8mm2PSM169X169NV3L10L_4_2PSM169X169NV3_2.2UH/3.2A/42.2uH/3.2A/4.0/4.0/1.8mm2PSM169X169NV3L11L_4_2PSM205X205NV6_3.3UH/4.6A/53.3uH/4.6A/5.0/5.0/4.0mm2PSM205X205NV6L12L_0_2P0201R_RF_18NH/NC18NH/NC2P0201R_RFL21L_4_2PSM169X169NV3_2.2UH/3.2A/42.2uH/3.2A/4.0/4.0/1.8mm2PSM169X169NV3L22FB_RV2-5MM-05K820_FNR-05K820/40FNR-05K820/400ARV2-5MM-05K820L23L_4_2PSM169X169NV3_3.3UH/2.9A/43.3uH/2.9A/4.0/4.0/1.8mm2PSM169X169NV3L24INDUCTOR_0_SMD_L4-6X7MM-BOK6E_BBOK6E-5A50T/NCSMD_L4-6X7MM-BOK6EL25IND_4_SPA63-150M_10UH/3A10uH/3ASPA63-150ML26L_4_2P0201R_RF_18NH3%/NC18NH3%/NC2P0201R_RFLL1L/0402_0_2P0201R_RF_18NH/NC18nH/NC2P0201R_RFLL9IND_MAG_HIND_MAG_2PIN_2PSM87X711.0UH/20%/4.4A/HTQH20160H-1R0MSR-392PSM87X71RLL10IND_MAG_PRI_HIND_MAG_PRI_2PIN_21.0UH2PSM87X71NV4LL11IND_MAG_PRI_HIND_MAG_PRI_2PIN_21.0UH2PSM87X71NV4Q1NFET_DIODE_G1S2D3_3PSOT118X55G_BSS138LT1G/SOT23-33PSOT118X55GQ2NFET_DIODE_G1S2D3_3PSOT118X55G_BSS138LT1G/SOT23-33PSOT118X55GQ32N6766_0_3PSOT118X55G_BSS138TA/BSS138TA/NC3PSOT118X55GQ42N6766_0_3PSOT118X55G_BSS138TABSS138TA3PSOT118X55GQ52N6766_0_3PSOT118X55G_BSS138TABSS138TA3PSOT118X55GQ69013_3PSOT118X55G_MMBT3904LT1GMMBT3904LT1G3PSOT118X55GQ79013_3PSOT118X55G_MMBT3904LT1GMMBT3904LT1G3PSOT118X55GQ89013_3PSOT118X55G_MMBT3904LT1GMMBT3904LT1G3PSOT118X55GQ99013_3PSOT118X55G_MMBT3904LT1GMMBT3904LT1G3PSOT118X55GQ102N6766_0_3PSOT118X55G_BSS138TABSS138TA3PSOT118X55GQ119013_3PSOT118X55G_MMBT3904LT1GMMBT3904LT1G3PSOT118X55GQQ1NFET_DIODE_G1S2D3_3PSM43X28N_DMDMN3730UFB-73PSM43X28NQQ22N6766_0_3PSOT118X55G_BSS138TA/BSS138TA/NC3PSOT118X55GQQ32N6766_0_3PSOT118X55G_BSS138TA/BSS138TA/NC3PSOT118X55GRV5VARISTOR_RV2-6MM_05D681K05D681KRV2-6MMS1TACT_SW_P2P_TACTTACTSW_P2PS2RTC7608U_6PSM43X43N138V1_RTC760RTC7608U6PSM43X43N138V1S3RTC7608U_6PSM43X43N138V1_RTC760RTC7608U6PSM43X43N138V1T1XFMR-FM-1178-1LLF_1_SMD_TRAN24-LP82440NLSMD_TRAN24-1_27MM-TF5433T2XFMR-FM-1178-1LLF_1_SMD_TRAN24-LP82440NLSMD_TRAN24-1_27MM-TF5433U1TEXT2_MB101B_TEXT2text2MB101BU2FP9854SP_9PSO197X157G50V5_FR985FR9854SP/SO-89PSO197X157G50V5U3FP9854SP_9PSO197X157G50V5_FR985FR9854SP/SO-89PSO197X157G50V5U4RT6252BHGJ6F_0_6PSM67X51F197V5_MP1653H(ES)6PSM67X51F197V5U5RT6252BHGJ6F_0_6PSM67X51F197V4_MP1653H(ES)6PSM67X51F197V4U6QPF4288SB_ES_0_25PSM201X122N197QPF4288SB(ES)25PSM201X122N197V1U7QPF4288SB_ES_0_25PSM201X122N197QPF4288SB(ES)25PSM201X122N197V1U8FP9852PSD_6PSM67X51F197V5_FR985FR9853PSD/SOT-563-66PSM67X51F197V5U9FP6396S5_5PSO120X69G374V1_FP639FP6396S5/SOT23-55PSO120X69G374V1U10IPQ-5018_233PSM555X555N217_IPQ-IPQ-5018-0-MRQFN232-MT-00-0233PSM555X555N217U11QCA8081_PROTO_1_57PSM280X280N15QCA8081_PROTO57PSM280X280N157V4U12FP6396S5_5PSO120X69G374V1_FP639FP6396S5/SOT23-55PSO120X69G374V1U13MT41K256M16TW-107_96PGA557X321BMT41K256M16TW-107:P/BGA-9696PGA557X321B315U14FP6396S5_5PSO120X69G374V1_FP639FP6396S5/SOT23-55PSO120X69G374V1U15LMR16030_SPQ8_1M27_6M2X5_LMR160LMR16030SPQ8_1M27_6M2X5U16PD-TPS2378_SOP8_XS2100SXS2100SSOP8U17TEXT2_MB101B_TEXT2text2MB101BU18TEXT2_MB101B_TEXT2text2MB101BU19GD25LQ32DSIG_SOP8-208MILS_8PSO2GD25LQ32DSIG_SOP8-208MILS/NC8PSO210X212G50U20GD25LQ32DWIG_WSON-8_9PSM240X319GD25LQ32DWIG/SMD6.0*5.0*0.75mm9PSM240X319N50V2U21GD5F1GQ4RE9IH-SPI-NAND_9PSM240XGD5F1GQ4RE9IH/LGA-89PSM240X319N50V2UU1QPF4288SB_25PSM201X122N197V1_QPQPF4588SB25PSM201X122N197V1UU2QPF4288SB_25PSM201X122N197V1_QPQPF4588SB25PSM201X122N197V1UU3QCN9074_234PGA476X440B256_QCN90QCN9074(000-0)234PGA476X440B256UU4QPF4288SB_25PSM201X122N197V1_QPQPF4588SB25PSM201X122N197V1UU5RT6252BHGJ6F_1_5PSO120X70G_FP61FP6186(ES)5PSO120X70GUU6MP1614CGTL_8PSM87X51F197_MP1614MP1614CGTL8PSM87X51F197UU7RT6252BHGJ6F_1_5PSO120X70G_FP61FP6186(ES)5PSO120X70GUU8RT6252BHGJ6F_1_5PSO120X70G_FP61FP6186(ES)5PSO120X70GUU9QPF4288SB_25PSM201X122N197V1_QPQPF4588SB25PSM201X122N197V1UU10MP1601GTF_6PSM67X51F197V5_MP160MP1601GTF6PSM67X51F197V5UU11MP1601GTF_6PSM67X51F197V5_MP160MP1601GTF6PSM67X51F197V5Y1TXAL_4PSM83X67NV4_X2C048000L71HX2C048000L71HH-CEHZ4PSM83X67NV4Y27M50070029_4PSM130X102N_7M500707M500700294PSM130X102NYY1TXAL_4PSM83X67NV4_48MHZ/10PPM/948MHz/10ppm/9pF/1ZZXAE96000BB0A4PSM83X67NV4
armclub 发表于 2022-1-20 22:18
PCB文件。赚1个RMB 。没需要的看看就好。
cityhu 发表于 2022-1-21 00:14
燊 发表于 2022-1-21 08:13
nj20044 发表于 2022-1-21 08:17
kanxue_nmg 发表于 2022-1-21 08:24
wangy2000 发表于 2022-1-21 08:26
小鑫鑫 发表于 2022-1-21 08:35
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 高端路由器PCB IPQ5018+QCN9074+QCA8081+QPF4288SB+QPF4588SB
