NXP S32G274A+SJA1110 做的汽车方案 PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED2LED_DUAL_SEP2_RG_2_LED4_2P54_8PLEDR/GLED4_2P54_8P13X4P5MMD3PRTR5V0U2AX_SOT143B_IC_1.1MM_48PESD2ETH-AXSOT143BD4PRTR5V0U2AX_SOT143B_IC_1.1MM_48PESD2ETH-AXSOT143BD5DUALDIODE_CC_SOT23_SOT23_A_IC_1BAT54CLT1SOT23_AD6DUALDIODE_CC_SOT23_SOT23_A_IC_1BAT54CLT1SOT23_AD7LED_DUAL_SEP2_RG_0_LED_DUAL_2X1APHBM2012SURKCGKCLED_DUAL_2X1P25MM_SMD8LED_DUAL_SEP2_RG_0_LED_DUAL_2X1APHBM2012SURKCGKCLED_DUAL_2X1P25MM_SMD9LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603D10LED_LED_0603_IC_1.1MM_370-76427LEDRedLED_0603D11DIODE_SCH_A1A2C3_SOT1289_IC_0.8PMEG45A10EPDSOT1289D12ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028D13ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028D14ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028D15ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028D16ZDIODE_SOD123_048X028_IC_1.45MMBZT52C3V3SOD123_048X028D17ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD18ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD19ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD20ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD21ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD22ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD23ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD24ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD25ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD28DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD33LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603D34DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD35DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD36LED_LED_0603_IC_0.8MM_370-75077LED_GREENLED_0603D43ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD44ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD45ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD46ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD47ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD48ESD_DIODE_2LINE_SOT23_A_IC_1._1PESD2ETH1G-TSOT23_AD49ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD50ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD51ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD52ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD53ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD54ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD55ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD56ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD60DIODE_TVS_BIDIR_DO-214AC_BIDIR_SMAJ33CADO-214AC_BIDIRD61ZDIODE_SOD123_IC_1.35MM_480-800MMSZ4700T1GSOD123D62DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523D63DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD64DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD65DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD66ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD67ESD_DIODE_2LINE_SOT23_A_IC_1.1MPESD2IVN24-TSOT23_AD68DIODE_TVS_SOD-882_IC_0.5MM_480-PESD5V0S1ULSOD-882D69DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD70DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD71DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD72DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD73DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD76DIODE_SCHTKY_SOD123LF_IC_1.2MM_PMEG3020EHSOD123LFD77DIODE_TVS_SOD-882_IC_0.5MM_480-PESD5V0S1ULSOD-882D78DIODE_TVS_SOD-882_IC_0.5MM_480-PESD5V0S1ULSOD-882D79DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523D80DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GSOD_523F1FUSE_FUSE_3P4X1P8_DISCRETE_0.867AFUSE_3P4X1P8FL1FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL2FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL3FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL4FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL5FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL6FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL7FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL8FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL9FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL10FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL15FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL16FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL17FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL18FILTER_4P_IND_ACT1210_SM_DISCRE200uH@ 100KHzIND_ACT1210_SMFL19FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL20FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL21FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL22FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL23FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL24FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL25FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL26FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL501FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTFL502FILTER_4P_IND4_4P7X3P4_SMT_DISCACT45B-101-2P-TL003IND4_4P7X3P4_SMTJ1MICRO_USB_CONN_9PIN_CON9_MICROA6.29105E+11CON9_MICROAB_USB_SHELL_THJ2MICRO_USB_CONN_9PIN_CON9_MICROA6.29105E+11CON9_MICROAB_USB_SHELL_THJ3CONN_MICRO_SD_CARD_REVERSED_CONConnMicroSDCON_SDCARD_8F_SM_RAJ4MICRO_USB_CONN_9PIN_CON9_MICROA6.29105E+11CON9_MICROAB_USB_SHELL_THJ5CONN_HDR_13X2_CON2X13_2MM_RA_THcon2x13CON2X13_2MM_RA_THJ6CONN_RCPT_2X20_CON2X20_2MM_RA_Tcon2x20CON2X20_2MM_RA_THJ16CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ37CONN_HDR_3X1_HDR103_A_IO_8.74MMHDR1X3HDR103_AJ44CONN_HDR_5X2_HDR205_10M_50_SM_KFTSH-105-01-L-DV-KHDR205_10M_50_SM_KJ47CON_67_FEMALE_RA_KEY_M_CON_75_0CON_MINI_PCIe_RACON_75_0P5_22X9_RA_KEY_MJ48HDR_2X10_HDR_20M_100_TH_IO_9.98HDR_2X10HDR_20M_100_THJ50HDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR1X3HDR1X3_THJ53CONN_HDR_24X1_CON24_2MM_34826_TCON24CON24_2MM_34826_TH_DIJ56CON_67_FEMALE_RA_A_CON_67_0P5_2M.2SKT KEY-ECON_67_0P5_22X6P73_RAJ57CONN_2X20_2G_CON2X20_0P8_23P5X5ASP-130367-01CON2X20_0P8_23P5X5P6_SMJ172CONN_HDR_3X1_HDR1X3_100_294X250HDR_1X3_W/LOCKHDR1X3_100_294X250_THJ176DCPOWER JACK_PJ-202B_IO_11MM_2CON_1_PWRPJ-202BJ177CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ178CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ180CONN_HDR_2X2_HDR2X2_50MIL_IO_4.HDR_2X2HDR2X2_50MILJ181CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ182CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ183CONN_HDR_3X1_HDR103_A_IO_8.74MMHDR1X3HDR103_AJ184CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ185CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ186CONN_HDR_2X1_HDR1X2_50MIL_IO_4.HDR_1X2HDR1X2_50MILJ187CONN_HDR_3X1_CON_1X3_1P27_TH_IOHDR_1X3CON_1X3_1P27_THJ188CONN_HDR_3X1_HDR103_A_IO_8.74MMHDR1X3HDR103_AL1BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL2BEAD_0_0603_CC_DISCRETE_0.95MM_120OHM0603_CCL3DLW43_IND4_CHOKE_0805_DISCRETE_90OHMIND4_CHOKE_0805L5EMIFILTER_NFM21P_CC_FIL_1206_DINFM31KC153R1H3CC_FIL_1206L6BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L7DLW43_IND_DLW43_DISCRETE_2.8MM_DLW43SHIND_DLW43L8BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L26IND_FERRITE_IND_0603_DISCRETE_0330OHMIND_0603L27BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L28BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L30BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L31IND_FERRITE_IND_0603_DISCRETE_0330OHMIND_0603L32BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L33BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L34BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L35BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L37BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L38IND_FERRITE_IND_0603_DISCRETE_0330OHMIND_0603L39IND_IND_2P2X2_DISCRETE_1.4MM_184.7UHIND_2P2X2L40IND_IND_2P2X2_DISCRETE_1.4MM_184.7UHIND_2P2X2L41BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L43BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L44BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L45BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L46BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L47BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L48BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L49BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L50BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L51BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L53BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L54BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L55BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L56BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L57BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L58BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L59IND_FERRITE_IND_0603_DISCRETE_0330OHMIND_0603L515BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101AIND_0805L519IND_3P_IND3_2P5_SQ5P2MM_DISCRET100nHIND3_2P5_SQ5P2MML520INDUCTOR_IND2_7P5X7_DISCRETE_5.4.7UHIND2_7P5X7L521INDUCTOR_IND_IHLP_DISCRETE_3.0M6.8uHIND_IHLPL522INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L523INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L524INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L528BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608L529BEAD_IND_0805_DISCRETE_1.05MM_2MPZ2012S101AIND_0805L530INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L531INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L532INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520L533BEAD_IND_1608_DISCRETE_0.95MM_1600OHMIND_1608LBK1INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520LBK2INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520LBK3INDUCTOR_IND2520_DISCRETE_1.2MM1uHIND2520LBO1INDUCTOR_IND2520_DISCRETE_1.2_14.7uHIND2520LPI1INDP_IND2_7P4X6P9_SM_DISCRETE_41uHIND2_7P4X6P9_SMLPRE1INDUCTOR_IND2_XAL1010_DISCRETE_4.7uHIND2_XAL1010P1PCIEXPRESS X1_CON_PCI_36_79TH_CONPCIE 36CON_PCI_36_79THP2RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ4513X2PORTSCON_RJ45_2X1_MAG_LEDP3RJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ4513X2PORTSCON_RJ45_2X1_MAG_LEDP4RJ45_7499011121A_CON_RJ45_16F_2RJ45CON_RJ45_16F_2P54_TH_RAP5CON_RJ45_19P_CON19_RJ-45_LED_80RJ45-19CON19_RJ-45_LED_80MIL_TH_RAQ1NMOS_NX3008NBK_DFN10106B_IC_0.4PMZB550UNEDFN10106BQ3NMOS_DUAL_8P_LFPAK56_1P27_4P7X5BUK9K18-40ELFPAK56_1P27_4P7X5P3Q5PNP_SC70_3_IC_1.1MM_480-79396_PPMST2907ASC70_3Q7NPN_SOT23_A_IC_1.1MM_480-78958_PMBT3904SOT23_AQ8NPN_SOT23_A_IC_1.1MM_480-78958_PMBT3904SOT23_AQ9PNP_SC70_3_IC_1.1MM_480-79396_PPMST2907ASC70_3Q10MOSFET_P_5P_SO8_U8FL_0P65_3P3SQNVTFS5116PLTAGU8FL_0P65_3P3SQQ11MOSFET_P_DIODE_SOT23_A_IC_1.1MMPMV27UPEASOT23_AQ12PNP_SC70_3_IC_1.1MM_480-79396_PPMST2907ASC70_3Q13NPN_SOT23_A_IC_1.1MM_480-78958_PMBT3904SOT23_AQZ1CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.932.768KHZXTAL2-3P2X1P5-SMRN3NETW_B8_10P_RCA_8_10_DISCRETE_010KRCA_8_10RN4NETW_B8_10P_RCA_8_10_DISCRETE_010KRCA_8_10RSNS1RES_4PIN_RC2512_4P_6P6X3P4_DISC0.01RC2512_4P_6P6X3P4SW1SW_TACT-SPST-2_SM1_SW2_TL1105M_TL1105MF160QSW2_TL1105MSW2SW_TACT-SPST-2_SM1_SW2_TL1105M_TL1105MF160QSW2_TL1105MSW3SW-SPST_SW2_DIP_1P27_2P51X5P7_ISWDIP 1 POSSW2_DIP_1P27_2P51X5P7SW4SW_DIP-8_SM_SW16_DIP_1P27_11P4XSW_DIP-8/SMSW16_DIP_1P27_11P4X5P7SW5SW_DIP-8_SM_SW16_DIP_1P27_11P4XSW_DIP-8/SMSW16_DIP_1P27_11P4X5P7SW6SW_DIP-8_SM_SW16_DIP_1P27_11P4XSW_DIP-8/SMSW16_DIP_1P27_11P4X5P7SW7SW_DIP-8_SM_SW16_DIP_1P27_11P4XSW_DIP-8/SMSW16_DIP_1P27_11P4X5P7SW8SW-SPST_SW2_DIP_1P27_2P51X5P7_ISWDIP 1 POSSW2_DIP_1P27_2P51X5P7SW9SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_SWDIP 2 POSSW2_DIP_1P27_4X5P8SW10SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_SWDIP 2 POSSW2_DIP_1P27_4X5P8SW11SW-SPST_SW2_DIP_1P27_2P51X5P7_ISWDIP 1 POSSW2_DIP_1P27_2P51X5P7SW12SW_DIP-2_SW2_DIP_1P27_4X5P8_IC_SWDIP 2 POSSW2_DIP_1P27_4X5P8SW15SW3_SPDT_SW3_SLIDE_260X500_TH_ISPDT_SLIDE_SWITCHSW3_SLIDE_260X500_THSW16SW2P_SW2_SPST_3P5X6P0_5P0_IC_5.EVQ-PE105KSW2_SPST_3P5X6P0_5P0SW17SW-SPST_SW2_DIP_1P27_2P51X5P7_ISWDIP 1 POSSW2_DIP_1P27_2P51X5P7U11G17_SC70-5_IC_1.1MM_312-81468_74LVC1G17GWSC70-5U2FT232RQ_QFN32_MC1320X_IC_1.05MMFT232RQQFN32_MC1320XU3FT232RQ_QFN32_MC1320X_IC_1.05MMFT232RQQFN32_MC1320XU574AUP1G11GW_SOT-363_0P65_SMT_IC74AUP1G11GWSOT-363_0P65_SMTU61G17_SC70-5_IC_1.1MM_312-81468_74LVC1G17GWSC70-5U7PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0PUSB3AB6XSON7_0P5_2P2X1P2U8USB83340_QFN32_QFN32_IC_0.9MM_USB83340QFN32U9TJA1024HG_24P_QFN24_0P5_5P6X3P6TJA1024HGQFN24_0P5_5P6X3P6_EPU11OPAMP_DUAL_8P_D_SO8_1P27_4X5_ICMCP6022-E/SNSO8_1P27_4X5U12OPAMP_DUAL_8P_D_SO8_1P27_4X5_ICMCP6022-E/SNSO8_1P27_4X5U13OPAMP_DUAL_8P_D_SO8_1P27_4X5_ICMCP6022-E/SNSO8_1P27_4X5U15TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU16TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU17TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU18TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU19TJA1153ATK_HVSON14_HVSON14_0P65TJA1153HVSON14_0P65_4P6X3P1_EPU20TJA1153ATK_HVSON14_HVSON14_0P65TJA1153HVSON14_0P65_4P6X3P1_EPU21TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU22TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU23TJA1081_SSOP_16P_SSOP16_6P5X5P6TJA1081GTSSSOP16_6P5X5P6MMU24PCAL6524HE_QFN_32P_UQFN32_0P5_5PCAL6524HEAZUQFN32_0P5_5X5_EP3X3U25MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U26MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U28MTFC16GAKAE_VFBGA_153P_FBGA153_MTFC32GAPALBH-AATFBGA153_0P5_11P5X13U31MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U331G125_SC70-5_IC_1.1MM_315-8095674AUP1G125GWSC70-5U34MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U37MX25UW51245GXDR00_BGA24_PBGA24_MX25UW51245GXDR00PBGA24_1_6X8MMU38MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U3974LVC1G32GF_6P_UDFN6_1X1P5MM_IC74AUP1G09GMUDFN6_1X1P5MMU4074LVC1G32GF_6P_UDFN6_1X1P5MM_IC74AUP1G09GMUDFN6_1X1P5MMU41VR5510_QFN56P_EP_QFN56_0P5_8X8_PVR5510AMDAHESQFN56_0P5_8X8_EP217X199U42MT53B768M32D4NQ_200P_BGA200_0P6MT53D1024M32D4DT-046AUT:DBGA200_0P65X0P8_10P1X14P6U43S32G275_BGA525_A_BGA525_0P8_19XS32G274ABGA525_0P8_19X19MMU44MAX4886E_42P_EP_QFN42_0P5_9X3P5MAX4886ETO+QFN42_0P5_9X3P5_EP2P1X7P5U46SJA1110_BGA256_B_BGA256_0P8_14XSJA1110(RHINE)BGA256_0P8_14X14MMU47DIODEZ_SOT23_SOT23_A_IC_1.1MM_4BZX84-A7V5SOT23_AU48CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U49NC7SZ14_SC70-5_IC_1.1MM_312-81974LVC1G04GW-Q100SC70-5U5025WP_8P_SO8_1P27_4X5_IC_1.75MM_IS25LP080D-JNLESO8_1P27_4X5U51CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U5374CBTLV3253DS_QSOP16-16X70_IC_174CBTLV3253DSQSOP16-16X70U5474LVC1G32GF_6P_UDFN6_1X1P5MM__174AUP1G08GMUDFN6_1X1P5MMU56AR8035_QFN40_A_QFN40_0P4_5P1X5PAR8035QFN40_0P4_5P1X5P1U57AR8035_QFN40_A_QFN40_0P4_5P1X5PAR8035QFN40_0P4_5P1X5P1U58KSZ9031RNXUA_48P_EP_WQFN48_0P5_KSZ9031RNXVB-VAOWQFN48_0P5_7X7_EP5P05U59SI5332-GM1_QFN32_S142EP_IC_0.9MSi5332DD12454-AM1QFN32_S142EPU6274CBTLV3253DS_QSOP16-16X70_IC_174CBTLV3253DSQSOP16-16X70U67TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU68TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU69TJA1153ATK_HVSON14_HVSON14_0P65TJA1153HVSON14_0P65_4P6X3P1_EPU70TJA1153ATK_HVSON14_HVSON14_0P65TJA1153HVSON14_0P65_4P6X3P1_EPU71TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU72TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU73TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU74TJA1043TK_14P_HVSON14_0P65_4P6XTJA1043TKYHVSON14_0P65_4P6X3P1_EPU75CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U76CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U7874LVC1G32GF_6P_UDFN6_1X1P5MM__174AUP1G08GMUDFN6_1X1P5MMU80FPF1321_6P_WLCSP6_0P5_0P98X1P48FPF1321UCXWLCSP6_0P5_0P98X1P48U82NX3DV3899GU_XQFN_16P_PQFN16_0P4NX3DV3899GUPQFN16_0P4_2P65X1P85U83PCA8565TS_TSSOP8_TSSOP8_A_IC_1.PCA85073ATSSOP8_AU84KSZ9031RNXUA_48P_EP_WQFN48_0P5_KSZ9031RNXVB-VAOWQFN48_0P5_7X7_EP5P05U8574LVC1G32GF_6P_UDFN6_1X1P5MM__174AUP1G08GMUDFN6_1X1P5MMU86AQR113C-BGA64_BGA64_0P8_7P1X7P1AQR113C-B0-CBGA64_0P8_7P1X7P1U87NTS0102_XSON8_0P5_3P1X2P1_IC_0.NTS0102XSON8_0P5_3P1X2P1U89AT45DB041D-SU_SO8_1P27_4X5_IC_1AT45DB041E-SSHN2B-BSO8_1P27_4X5U90PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0PUSB3AB6XSON7_0P5_2P2X1P2U92IC_PMIC_QFN_PQFN24_0P5_3P5X4P5MBUCK_CONVERTERPQFN24_0P5_3P5X4P5MMU93MOSFET_DUAL_NMOS_6P_A_LFPAK56_1BUK9K18-40ELFPAK56_1P27_4P7X5P3U94FS5600_QFN32_HPQFN32_0P5_5X5_EPMFS5600AMMA7ESHPQFN32_0P5_5X5_EP3P6U96PF5020_QFN40_QFN40_0P5_6X6_4P_1PPF5020AMBACESQFN40_0P5_6X6_4P1EPU98TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU99TJA1043ATK_14P_EP_HVSON14_0P65_TJA1463ATKHVSON14_0P65_4P6X3P1_EPU100TJA1021T_SO8_1P27_4X5_IC_1.75MMTJA1021T/20/CSO8_1P27_4X5U101NX5P3290_16P_BGA16_0P5_2P23X2P2NX5P3363UKZBGA16_0P5_2P23X2P23U103CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U104CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U105CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U106CBTL02043ABQ_20P_DHVQFN20_0P5_2CBTL02043ADHVQFN20_0P5_2P6X4P6U107NC7SZ14_SC70-5_IC_1.1MM_312-81974LVC1G04GW-Q100SC70-5U108PF5020_QFN40_QFN40_0P5_6X6_4P1EPPF5020AMBADESQFN40_0P5_6X6_4P1EPU109PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0PUSB3AB6XSON7_0P5_2P2X1P2U110NX30P0121UKZ_WLCSP_12P_WLCSP12_NX30P0121UKWLCSP12_0P4_1P38X1P68MM_SMDPU111NTS0102_XSON8_0P5_3P1X2P1_IC_0.NTS0102XSON8_0P5_3P1X2P1U112NC7SZ14_SC70-5_IC_1.1MM_312-81974LVC1G04GW-Q100SC70-5U11374LVC1G32GF_6P_UDFN6_1X1P5MM_IC74AUP1G09GMUDFN6_1X1P5MMU11574LVC1G32GF_6P_UDFN6_1X1P5MM_IC74AUP1G09GMUDFN6_1X1P5MMU11674AUP1G11GW_SOT-363_0P65_SMT_IC74AUP1G11GWSOT-363_0P65_SMTU119AND_TRIPLE_EP_DHVQFN14_3X2P5MM_74LVC11BQDHVQFN14_3X2P5MMU124NX30P0121UKZ_WLCSP_12P_WLCSP12_NX30P0121UKWLCSP12_0P4_1P38X1P68MM_SMDPU1251G125_SC70-5_IC_1.1MM_315-8095674AUP1G125GWSC70-5U1261G125_SC70-5_IC_1.1MM_315-8095674AUP1G125GWSC70-5U127NX3P1108_4P_WLCSP4_0P5_0P99X0P9NX3P1108WLCSP4_0P5_0P99X0P99U128LED_RGB_6P_LED6_0P85_3P25X2P85_150352M173300LED6_0P85_3P25X2P85_SMU129PUSB3AB6_XSON7_0P5_2P2X1P2_IC_0PUSB3AB6XSON7_0P5_2P2X1P2U131SN74AVC2T45_TSSOP8_A_IC_1.3MM_SN74AVC2T45DCTRTSSOP8_AU132SN74AVC2T45_TSSOP8_A_IC_1.3MM_SN74AVC2T45DCTRTSSOP8_AU1331G17_SC70-5_IC_1.1MM_312-81468_74LVC1G17GWSC70-5U1341G17_SC70-5_IC_1.1MM_312-81468_74LVC1G17GWSC70-5U135NX3P1108_4P_WLCSP4_0P5_0P99X0P9NX3P1108WLCSP4_0P5_0P99X0P99U136INA231_CSP_12P_CSP12_0P4_1P675XINA231CSP12_0P4_1P675X1P418_SMDPU137PCT2075_SON8_EP_HWSON8_0P5_3P1PCT2075HWSON8_0P5_3P1X2P1Y1XTAL_13_XTLOSC4_3P2X2P5MM_SM_IC26MHZXTLOSC4_3P2X2P5MM_SMY2XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I40MHzXTLOSC4_3P2X2P5MM_SMY3XTAL_13_XTLOSC4_3P2X2P5MM_SM__125MHzXTLOSC4_3P2X2P5MM_SMY4XTAL_13_XTAL4_3P3X2P6_SM_FL_IC_50MhzXTAL4_3P3X2P6_SM_FLY6XTAL_13_XTLOSC4_3P2X2P5MM_SM__125MHzXTLOSC4_3P2X2P5MM_SMY7XTAL_13_XTLOSC4_3P2X2P5MM_SM__125MHzXTLOSC4_3P2X2P5MM_SMY10XTAL_13_XTLOSC4_3P2X2P5MM_SM__125MHzXTLOSC4_3P2X2P5MM_SM PCB文件。回复可见
**** Hidden Message ***** 学习学习了
