老吴 发表于 2022-10-30 19:49
microchip VSC7558 方案最高支持25G 以太网光纤交换机PCB文件ZL30
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1LED_LED-0805_LED_REDLED_REDLED-0805D2LED-GR_LED-0805_LED-GRLED-GRLED-0805D3LED-GR_LED-0805_LED-GRLED-GRLED-0805D4BAV23_SOT23_BAS70-04BAS70-04SOT23D5BAV23_SOT23_BAS70-04BAS70-04SOT23D6LED-GR_LED-0805_LED-GRLED-GRLED-0805D7DIALIGHT-551-3007-R/G_DIALIGHT_551-3007FDIALIGHT_551-XX07D8DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD9DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D10DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD11DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD12DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D13DIALIGHT_568-0704-444_DIALIGHT_568-0704-444DIALIGHT_568-0102-XXXD14DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D15DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D16DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD17DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD18DIALIGHT-553-0744-YL/G_DIALIGHT553-0744FDIALIGHT_553-XXXXD19DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D20DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D21DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D22DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D23BAV23_SOT23_BAS70-04BAS70-04SOT23D24BAV23_SOT23_BAS70-04BAS70-04SOT23D25DIALIGHT-551-3107-YL/G_DIALIGHT551-3107FDIALIGHT_551-XX07D26DIODE_COM_KAT_SOT23_BAR43CBAR43CSOT23D27DIODE_COM_KAT_SOT23_BAR43CBAR43CSOT23D28LED-GR_LED-0805_LED-GRLED-GRLED-0805D29ECLAMP2357_QFN16_3X3_ECLAMP2357ECLAMP2357NQQFN16_3X3D30MBRS140T3_DIO_SMB_SS24SS24DIO_SMBH1SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH2SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH3SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH4SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH5SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH6SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH7SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH8SFP_CAGE_CONN_SFP_CAGE_2007198-2007198-1CONN_SFP_CAGEH9SCREWHOLE-3_5MM_8VIA_1_SCREWHOL3_5mm_8viaSCREWHOLE-3_5MM-8VIAH34SCREWHOLE-3_5MM_8VIA_1_SCREWHOL3_5mm_8viaSCREWHOLE-3_5MM-8VIAH35SOLDER-SPACER-THREADED_MECH_SOLSolderspacer M2.5MECH_SOLDER_SPACER_M2_5H36SOLDER-SPACER-THREADED_MECH_SOLSolderspacer M2.5MECH_SOLDER_SPACER_M2_5H37NO_BOX_SER_BOX_SER_NO_BOXSer_no_BoxSER_BOXH38ECO_BOX_ECO_BOX_ECO_BOXECO_BoxECO_BOXH39LOGO_MCHP_LOGO_MCHP_LOGO_MCHPLogo_MCHPLOGO_MCHPH40ECO_BOX_ECO_BOX_ECO_BOXECO_BoxECO_BOXH41LOGO_MCHP_LOGO_MCHP_LOGO_MCHPLogo_MCHPLOGO_MCHPH42NO_BOX_SER_BOX_SER_NO_BOXSer_no_BoxSER_BOXH43LOGO_MCHP_LOGO_MCHP_LOGO_MCHPLogo_MCHPLOGO_MCHPH44NO_BOX_SER_BOX_SER_NO_BOXSer_no_BoxSER_BOXH45ECO_BOX_ECO_BOX_ECO_BOXECO_BoxECO_BOXH46SOLDER-SPACER-THREADED_MECH_SOLSolderspacer M2.5MECH_SOLDER_SPACER_M2_5H47SOLDER-SPACER-THREADED_MECH_SOLSolderspacer M2.5MECH_SOLDER_SPACER_M2_5J1PINROW_2_CONN-2MM54-1X02L_PINROpinrow_2CONN-2MM54-1X02LJ2SAMTEC_QSE-020_SOCKET_CONN-SAMTSamtec_QSE-020_SocketCONN-SAMTEC-QSE-020-01-L-D-AJ3PINROW_2X5_0_1_FRAME_CONN-HEADE61201021621CONN-HEADER-2X05LJ4SMA_LEADED_SMA_SMD_SMA_SMDSMA_SMDSMA_SMDJ5SMA_LEADED_SMA_SMD_SMA_SMDSMA_SMDSMA_SMDJ6USB-MICRO-B_USB-MICRO-B_USB_MICUSB_micro_BUSB-MICRO-BJ7SMA_LEADED_SMA_SMD_SMA_SMDSMA_SMDSMA_SMDJ8SMA_LEADED_SMA_SMD_SMA_SMDSMA_SMDSMA_SMDJ9PINROW10X2_0.1E_FRAME_CONN-HEAD61202021621CONN-HEADER-2X10LJ10PINROW_2X5_1.27_HEADER-P7_SMD_FFTSH-105-01-F-DV-007-KFTSH-105-01-L-DVJ11RJ45_RJHS5380_RJHS_5380_RJHS-53RJHS-5380RJHS_5380J12RJ45_RJHS5380_RJHS_5380_RJHS-53RJHS-5380RJHS_5380J13SMA_EDGE_PCB_SMA_EDGE_LOCOST_SMSMA_edge_PCB_1_57SMA_EDGE_LOCOSTJ14SMA_EDGE_PCB_SMA_EDGE_LOCOST_SMSMA_edge_PCB_1_57SMA_EDGE_LOCOSTJ15SFPPLUS_2X2_MOLEX_76045_CONN_SFSFPplus_2x2CONN_SFPPLUS_2X2_MOLEX_76045J16SFPPLUS_2X2_MOLEX_76045_CONN_SFSFPplus_2x2CONN_SFPPLUS_2X2_MOLEX_76045J17SFPPLUS_2X2_MOLEX_76045_CONN_SFSFPplus_2x2CONN_SFPPLUS_2X2_MOLEX_76045J18SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J19SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J20SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J21SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J22SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J23SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J24SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J25SFPPLUS_PT20_CONN_SFP_PT20_SFP2SFP28_PT20CONN_SFP_PT20J26PINROW_6_CONN-HEADER-1X6L-P2_54pinrow_6CONN-HEADER-1X6L-P2_54MMJ27SMA_EDGE_PCB_SMA_EDGE_LOCOST_SMSMA_edge_PCB_1_57SMA_EDGE_LOCOSTJ28PINROW_2X5_1.27_HEADER_SMD_FTSHC44-10-BSB1-GFTSH-105-01-L-DVJ29SMA_EDGE_PCB_SMA_EDGE_LOCOST_SMSMA_edge_PCB_1_57SMA_EDGE_LOCOSTJ30SAMTEC_QSE-040_SOCKET_CONN-SAMTSamtec_QSE-040_SocketCONN-SAMTEC-QSE-040-01-L-D-AJ31TC2050_TC2050_TC2050TC2050TC2050J32RJ45_RJHS5380_RJHS_5380_RJHS-53RJHS-5380RJHS_5380J33PINROW_3_LOCK_CONN-2MM54-1X03L-pinrow_3_LockCONN-2MM54-1X03L-LOCKJ34PINROW_3_LOCK_CONN-2MM54-1X03L-pinrow_3_LockCONN-2MM54-1X03L-LOCKJ3520PIN_PC-POWER_CON_CON_20PIN-4239-28-1203CON_20PIN-420J36MINI-FIT_2X2PIN_CON_MINI_FIT_2Xmini-fit_2x2CON_MINI_FIT_2X2J37MM70-314-310B1-1-R300_LX1046_COMM70-314-310B1-1-R300CONN_MM70-314-310B1-2-R300J38SAMTEC_QTE-020_HEADER_CONN-SAMTQTE-020-01-L-D-ACONN-SAMTEC-QTE-020J39PCIE_MIDBUS_FS_PCIE_MIDBUS_FS_PPE047UIA-XPCIE_MIDBUS_FSJ40PINROW_3_FTR-S-103_FTR-103-02-SFTR-103-02-S-SFTR-S-103J41PINROW_2X5_0_1_FRAME_CONN-HEADE61201021621CONN-HEADER-2X05LJ42USD_CARD_CONN_AMPHENOL_101-0066uSD_cardCONN_AMPHENOL_101-00660-68-6J43PINROW_2X5_1.27_HEADER-P7_SMD_FFTSH-105-01-F-DV-007-KFTSH-105-01-L-DVJ44SAMTEC_QTE-020_HEADER_CONN-SAMTQTE-020-01-L-D-ACONN-SAMTEC-QTE-020J45PCIE_MIDBUS_FS_PCIE_MIDBUS_FS_PPE047UIA-XPCIE_MIDBUS_FSJ46USB3-A_VERT_USB3-A-SMD_6921203069212030100USB3-A-SMDJ47PINROW_3_FTR-S-103_FTR-103-02-SFTR-103-02-S-SFTR-S-103J48PINROW_2X5_1.27_HEADER_SMD_FTSHC44-10-BSB1-GFTSH-105-01-L-DVJ49RJ45_RJHS5380_RJHS_5380_RJHS-53RJHS-5380RJHS_5380J50PINROW_2_CONN-2MM54-1X02L_PINROpinrow_2CONN-2MM54-1X02LJ51PINROW_2X5_0_1_FRAME_CONN-HEADE61201021621CONN-HEADER-2X05LJ52PINROW23X2_0-1E_SMD_CONN-HEADERpinrow23x2_2-54mmCONN-HEADER-2X23J53PINROW_2_CONN-2MM54-1X02L_PINROpinrow_2CONN-2MM54-1X02LL53BLM21B601S_0805_MPZ2012S601AMPZ2012S601A805L54BLM21B601S_0805_MPZ2012S601AMPZ2012S601A805L55INDUCTOR_IND_HCM1104_560N560nIND_HCM1104L56INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L57INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L58INDUCTOR_IND_HCM1104_1.5U1.5uIND_HCM1104L59INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L60INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L61INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L62INDUCTOR_MPL73_4U74u7MPL73L63BLM21B601S_FB0805_MPZ2012S601AMPZ2012S601AFB0805L64INDUCTOR_IND_IHLP1212BZ-11_680N680nHIND_IHLP1212BZ-11L65BLM21B601S_FB0805_MPZ2012S601AMPZ2012S601AFB0805L66BLM21B601S_0805_MPZ2012S601AMPZ2012S601A805Q1NPN-BC847B_SOT23_BC847BBC847BSOT23Q2TDSON-8_TDSON-8_CSD17581Q5ACSD17581Q5ATDSON-8Q3TDSON-8_TDSON-8_CSD17581Q5ACSD17581Q5ATDSON-8Q4FDV305N/SOT23_SOT23_FDV305NFDV305NSOT23Q5FDV305N/SOT23_SOT23_FDV305NFDV305NSOT23Q6NPN-BC847B_SOT23_BC847BBC847BSOT23Q7NPN-BC847B_SOT23_BC847BBC847BSOT23SW1RA-PUSH-BUTTON_RA-PUSH-BT_RA-PURA-push-btRA-PUSH-BTSW2SW_DIP-2_SMD_HALF_PITCH_DILSW-24.16131E+11DILSW-2POL-SMT-HPSW3RA-PUSH-BUTTON_RA-PUSH-BT_RA-_1RA-push-bt-8.35mmRA-PUSH-BTSW4ITTCANAON_DPDT_SWITCH_7101J1ABE611-DA101J11S2APQFDPDT_611-DA101J11S2APQFSW5SW_DIP-2_SMD_HALF_PITCH_DILSW-24.16131E+11DILSW-2POL-SMT-HPSW6SW_DIP-2_SMD_HALF_PITCH_DILSW-24.16131E+11DILSW-2POL-SMT-HPT1PULSE_H5004_H5062_H5004NLH5004NLH5062U1NC7S08M5_SOT23-5_NC7S08M5NC7S08M5SOT23-5U2VSC7558_BGA888_P0MM8_25MM_VSC75VSC7558BGA888_P0MM8_25MMU3MAX811TEUS-T_SOT143_MIC6315-31DMIC6315-31D3UYSOT143U4TPS3808_SOT23-6_TPS3808G01TPS3808G01SOT23-6U5SPI-FLASH_SO16W_SO16W_MX66L1G45MX66L1G45GMI-10GSO16WU6AT25080A_SO08_M25P10M25P10SO08U7MCP2221_SO14_MCP2221AMCP2221ASO14U8MIC5203-5.0YM5_SOT-23-5_MIC5504MIC5504-3.3YM5SOT-23-5U9ISL3180E_SO14_ISL3180EISL3180ESO14U10ISL3180E_SO14_ISL3180EISL3180ESO14U11ISL3180E_SO14_ISL3180EISL3180ESO14U1274HC4051_TSSOP16_74HC405174HC4051TSSOP16U13TVS3V3L4U_SC74_TVS3V3L4UTVS3V3L4USC74U14TVS3V3L4U_SC74_TVS3V3L4UTVS3V3L4USC74U15TVS3V3L4U_SC74_TVS3V3L4UTVS3V3L4USC74U16DDR4-SDRAM-1GX8_78_BALL_FBGA78-MT40A512M8RH-083EFBGA78-0MM8_9MMX10MM5U17DDR4-SDRAM-1GX8_78_BALL_FBGA78-MT40A512M8RH-083EFBGA78-0MM8_9MMX10MM5U18DDR4-SDRAM-1GX8_78_BALL_FBGA78-MT40A512M8RH-083EFBGA78-0MM8_9MMX10MM5U19DDR4-SDRAM-1GX8_78_BALL_FBGA78-MT40A512M8RH-083EFBGA78-0MM8_9MMX10MM5U20DDR4-SDRAM-1GX8_78_BALL_FBGA78-MT40A512M8RH-083EFBGA78-0MM8_9MMX10MM5U2174HC165_TSSOP16_74HC16574HC165TSSOP16U2274HC165_TSSOP16_74HC16574HC165TSSOP16U2374HC165_TSSOP16_74HC16574HC165TSSOP16U2474HC165_TSSOP16_74HC16574HC165TSSOP16U2574HC165_TSSOP16_74HC16574HC165TSSOP16U2674HC165_TSSOP16_74HC16574HC165TSSOP16U2774HC165_TSSOP16_74HC16574HC165TSSOP16U2874HC165_TSSOP16_74HC16574HC165TSSOP16U2974AHC594_0_SO16_74AHC59474AHC594SO16U3074AHC594_0_SO16_74AHC59474AHC594SO16U3174AHC594_0_SO16_74AHC59474AHC594SO16U3274AHC594_0_SO16_74AHC59474AHC594SO16U3374AHC594_0_SO16_74AHC59474AHC594SO16U3474AHC594_0_SO16_74AHC59474AHC594SO16U3574AHC594_0_SO16_74AHC59474AHC594SO16U3674AHC594_0_SO16_74AHC59474AHC594SO16U3774HC240_TSSOP20-P065MM_74HC24074HC240TSSOP20-P065MMU3874HC240_TSSOP20-P065MM_74HC24074HC240TSSOP20-P065MMU3974HC240_TSSOP20-P065MM_74HC24074HC240TSSOP20-P065MMU4074LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU4174LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU4274LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU4374LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU4474LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU4574LV164_TSSOP14-P065MM_74HC164P74HC164PWTSSOP14-P065MMU46ZL30772_LGA80_11X11_ZL30772ZL30772LGA80_11X11U47EMMC_LFBGA153_BGA153-P0MM5_11X1IS21ES04G-JCLIBGA153-P0MM5_11X13MMU48VSC8211_LBGA117_P1MM0_10X14MM_VVSC8211LBGA117_P1MM0_10X14MMU49SPI-NAND-FLASH-SOP16_SO16W_MX35MX35LF2GE4AB-MISO16WU50LX7302_QFN40P300X300X80-21N_LX7LX7302QFN40P300X300X80-21NU51LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU52NX9548_VQFN-32L-5MM_NX9548ILQNX9548ILQVQFN-32L-5MMU53LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU54LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU5574HC125_SO14_74HC12574HC125SO14U56LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU57LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU58TPS51200_VSON10_TPS51200TPS51200VSON10U59SPI-FLASH_SO16W_SO16W_MX25L2563MX25L25635FMI-10GSO16WU60PCA9306DCTR_TSSOP08-P065MM_4MM_PCA9306DCTRTSSOP08-P065MM_4MMU61SPI-FLASH_SO16W_SO16W_MX25L2563MX25L25635FMI-10GSO16WU62MAX3221E_SSOP16-P065MM_MAX3221EMAX3221ESSOP16-P065MMU63LX7104_SOT23-6_LX7104LX7104SOT23-6U64ZL30251_32_LEAD_QFN_(S1+S2)_ZL3ZL3025132_LEAD_QFNU65LX7167A_DFN50P200X200X80-9N_LX7LX7167ADFN50P200X200X80-9NU66742G125_TSSOP08-P065MM_4MM_74LV74LVC2G125TSSOP08-P065MM_4MMU67NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U68NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U69NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U70NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U71NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U72NC7SZ125M5_SOT23-5_NC7SZ125M5NC7SZ125M5SOT23-5U73NC7SZ04M5_SOT23-5_NC7SZ04M5NC7SZ04M5SOT23-5Y1OSC_20.00MHZ_OCXO_G287D_OX-5011OX-501125.0MHzG287DY2OSC_20.00MHZ_M5627LF_RAKON_M562OX-60125.0MHzRAKON_M5627LFY3OSC_125MHZ_IQD_SM091_VCC1-1545-VCC1-1545-49M152SM091Y4CRYSTAL_25MHZ-HC49S_XTAL-HC49S_25MHzXTAL-HC49SY5CS023_XTAL320X250X80_57.1425MHZ57.1425MHzXTAL320X250X80
老吴 发表于 2022-10-30 19:54
PCB文件。8层设计。赚5RMB
罗塘阮经天 发表于 2022-10-30 22:54
牛
lf2k2022 发表于 2022-10-31 00:02
nj20044 发表于 2022-10-31 06:03
longxuekai 发表于 2022-10-31 06:36
来看看吧看吧
767955407 发表于 2022-10-31 07:22
root_2022 发表于 2022-10-31 07:48
huangchang 发表于 2022-10-31 07:50
kanxue_nmg 发表于 2022-10-31 07:52
页: [1] 2 3 4 5 6 7 8
查看完整版本: microchip VSC7558 方案最高支持25G 以太网光纤交换机PCB文件ZL30
