1500W 电池管理板PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON3XT30_P_XT30U-M_XT30_PXT30_PXT30U-MCON5DIP_1_DIP-4-2_54MM_12V+12V+DIP-4-2_54MMD1DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D2DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D3DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D4DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D38BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMAD39BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMAD40BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMAD42DIO_5_SMA_SS54SS54SMAD48BZX84C16/SOT_5_SMA_TVS_30VTVS_30VSMAD57BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMAD58BZX84C16/SOT_5_SMA_SMAJ15CASMAJ15CASMAD61TLP3023_0_LEDC1608X60N_GLED/NCGLED/NCLEDC1608X60ND62TLP3023_0_LEDC1608X60N_GLED/NCGLED/NCLEDC1608X60ND63DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D64DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D65DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D66DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D74PMOS_3PIN_SOT-23_AO3401AO3401SOT-23D108DI-XI-S_0_SOD-323_IC_3.6V/NC3.6V/NCSOD-323D354BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23D359DIO_6_PS-277B_ST2045ST2045PS-277BD360DIO_6_PS-277B_ST2045ST2045PS-277BD361DIO_6_PS-277B_ST2045ST2045PS-277BD362BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23D364BZX84C16/SOT_15_SMA_DO-214AC_SMAJ25CASMAJ25CASMA_DO-214ACD365BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D366BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D367BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D368BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D369BZX84C16/SOT_14_SMA_DO-214AC_SMAJ25CASMAJ25CASMA_DO-214ACD370BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D371BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D372BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D373BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D374DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D375DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D376DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D377DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D378DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D379DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D380DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D381DIO_4_SOD-323_1N4148WS1N4148WSSOD-323D383DIO_5_SMA_SS34SS34SMAD384DIO_5_SMA_SS34SS34SMAD386PMOS_3PIN_SOT-23_AO3401AO3401SOT-23D387DIO_5_SMA_SS34SS34SMAD389DIO_5_SMA_SS34SS34SMAD390BZX84C16/SOT_12_SMB_SMBJ33CASMBJ33CASMBD391DI-XI-S_0_SOD-323_IC_3.6V3.6VSOD-323D392BZX84C16/SOT_12_SMA_SMAJ33CASMAJ33CASMAD397DIO_6_PS-277B_ST2045ST2045PS-277BD398DIO_6_PS-277B_ST2045ST2045PS-277BD399BZX84C16/SOT_5_SOD-323_SOD323SOD323SOD-323D402BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23D403BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23D404BZX84C16/SOT_12_SMA_SMAJ13CASMAJ13CASMAD408DIO_4_SOD-323_1N58191N5819SOD-323D409DIO_5_SOD-323_IN4148WSIN4148WSSOD-323D410DIO_5_SOD-323_IN4148WSIN4148WSSOD-323D411DIO_5_SOD-323_IN4148WSIN4148WSSOD-323D413DIO_5_SOD-323_IN4148WSIN4148WSSOD-323D414DIO_5_SOD-323_IN5819IN5819SOD-323D415BZX84C16/SOT_5_SMA_SMAJ25CASMAJ25CASMAD416BAS70-04/SOT_SOT-23_BAV99BAV99SOT-23D417BZX84C16/SOT_5_SMA_TVS_30VTVS_30VSMAD418BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323D419BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323D420BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323D421BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323D422BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323D423BZX84C16/SOT_5_SOD-323_5.1VTVS5.1VTVSSOD-323DC+1TP_0_TEST_MINI_NCNCTEST_MINIEC1C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMEC2C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMEC3C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMEC4C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMEC5C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMEC6C0603_1_EC_DIP_10X12MM_330UF/35V330uF/35VEC_DIP_10X12MMF3FUSE-SMD_R1206_15A15AR1206F4FUSE-SMD_R1206_15A15AR1206F5FUSE-SMD_R1206_15A15AR1206F6FUSE-SMD_R1206_15A15AR1206F7FUSE-SMD_R1206_2A2AR1206F8FUSE-SMD_R1206_0R0RR1206F9FUSE-SMD_R1206_15A15AR1206F10FUSE-SMD_R1206_12A12AR1206FB1RESISTOR_R0603_600R@100M600R@100MR0603J1CON_4_SMD-GH-6P-125MM-L_CON_6PIN_1R27MMCON_6PIN_1R27mmSMD-GH-6P-125MM-LJ7RT9167A-28CB,SOT23_40_SMD-3-2MM-L_WPC_CON_2.0MMWpc_con_2.0mmSMD-3-2MM-LJ16J-HDR-5_DIP-5-2MM_HDR2R0MA-1X5HDR2R0MA-1X5DIP-5-2MMJ17RT9167A-28CB,SOT23_73_TYPEC16_SMD_LM_TYPE-CTYPE-CTYPEC16_SMD_LMJ19RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLMJ20RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLMJ21RT9167A-28CB,SOT23_0_USB2_DIP_4PLM_USBAUSBAUSB2_DIP_4PLMJ25RT9167A-28CB,SOT23_74_TYPEC16_SMD_LM_TYPE-CTYPE-CTYPEC16_SMD_LMJ40RT9167A-28CB,SOT23_67_DIP-3-2_54MM_VIN+VIN+DIP-3-2_54MMJ41RT9167A-28CB,SOT23_67_DIP-3-2_54MM_VIN-VIN-DIP-3-2_54MMJ46CON_1X5PIN_SMD-5-2MM-W_CON_1X5PINCON_1X5PINSMD-5-2MM-WJ50CON_1X5PIN_SMD-5P-2_54MM-L_CON_1X5PIN_2R54CON_1X5PIN_2R54SMD-5P-2_54MM-LJ51CON_4_SMD-6-2_0MM_L_CON_6PIN_2R0MMCON_6PIN_2R0mmSMD-6-2_0MM_LJ52RT9167A-28CB,SOT23_67_DIP-3-2_54MM_12V-12V-DIP-3-2_54MMJ53CON_1X5PIN_SMD-5-2MM-W_CON_1X5PIN_2R0CON_1X5PIN_2R0SMD-5-2MM-WJ55RT9167A-28CB,SOT23_67_DIP-3-2_54MM_24V+24V+DIP-3-2_54MMJ56RT9167A-28CB,SOT23_67_DIP-3-2_54MM_24V-24V-DIP-3-2_54MMJ57RT9167A-28CB,SOT23_40_SMD-3-2MM-L_CON_3PIN_2R54CON_3PIN_2R54SMD-3-2MM-LL1INDUCTOR_INCD_20MMDL_4.7UH4.7uHINCD_20MMDLL5L_0_INCD_20MML_22UH22uHINCD_20MMLL8L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4L9L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4L10L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4L12L_0_INDP8X8X4_PRS8040-6R8MTPRS8040-6R8MTINDP8X8X4L15L_0_INCD_20MMDL_4.7UH4.7uHINCD_20MMDLL17L_0_INCD_20MML_22UH22uHINCD_20MMLL34L_0_INDP8X8X4_5.6UH5.6uHINDP8X8X4L36L_0_INCD_20MML_4.7UH4.7uHINCD_20MMLLB12LB_R1210_30R/100MHZ30R/100MHzR1210LB13LB_R1210_30R/100MHZ30R/100MHzR1210LB14LB_R1210_30R/100MHZ30R/100MHzR1210LB15LB_R1206_30R/100MHZ30R/100MHzR1206LB16LB_R1210_30R/100MHZ30R/100MHzR1210LED2TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60NLED3TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60NLED5TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60NLED6TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60NLED7TLP3023_0_LEDC1608X60N_GLEDGLEDLEDC1608X60NNTC1R_9_R0603_100K/3950B100K/3950BR0603NTC2R_9_R0603_100K/3950B100K/3950BR0603Q0PMOS_3PIN_SOT-23_AO3401AO3401SOT-23Q1RT9167A-28CB,SOT23_70_DFN5X6_BSC032N04BSC032N04DFN5X6Q2RT9167A-28CB,SOT23_70_DFN5X6_BSC059N04BSC059N04DFN5X6Q3NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q4NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q5NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q6RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6Q13MMBT2907A/SOT_1_SOT-23_MMBT5401MMBT5401SOT-23Q34RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6Q35RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6Q36NPN-BECNPNSOT-23Q43RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6Q44RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6Q45RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6Q46RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6Q47RT9167A-28CB,SOT23_55_SOT23-6_NMOS-8205NMOS-8205SOT23-6Q48RT9167A-28CB,SOT23_56_SOT23-6_FS112FS112SOT23-6Q50RT9167A-28CB,SOT23_60_SOT23-6_INA181A2IDBVTINA181A2IDBVTSOT23-6Q53PMOS_3PIN_SOT-23_MMBT5401MMBT5401SOT-23Q59RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6Q60RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6Q69RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6Q70RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6Q73RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6Q74RT9167A-28CB,SOT23_70_DFN5X6_TDM3436TDM3436DFN5X6Q75NPN-BEC_0_SOT-23_80508050SOT-23Q84NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23Q85NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23Q86NPN-BEC_0_SOT-23_2N7002K2N7002KSOT-23Q89NMOS_2_SOT-23_S8050S8050SOT-23Q90RT9167A-28CB,SOT23_70_DFN5X6_VS3120VS3120DFN5X6Q91RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6Q92NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q932N7002/SOT_3_DFN5X6_TDM3307TDM3307DFN5X6Q94NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q95NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q96NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q97NMOS_4_DFN5X6_AON7752AON7752DFN5X6Q98NMOS_2_SOT-23_S8050S8050SOT-23Q99NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23Q100NMOS_2_SOT-23_S8050S8050SOT-23Q1012N7002/SOT_1_SOIC-8N_44074407SOIC-8NQ102NMOS_2_SOT-23_S8050S8050SOT-23Q103NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23Q1052N7002/SOT_3_DFN5X6_TDM3307TDM3307DFN5X6Q106NPN-BEC_0_SOT-23_80508050SOT-23Q109NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23Q110RT9167A-28CB,SOT23_71_DFN5X6_PMOSPMOSDFN5X6Q111NMOS_2_SOT-23_S8050S8050SOT-23Q112NMOS_2_SOT-23_S8050S8050SOT-23Q113NPN-BEC_0_SOT-23_NMOS2N7002KNMOS2N7002KSOT-23SW6ST-1187_0_KEY_TS1102S_ST-1187ST-1187KEY_TS1102SU0SC8915_0_QFN32-4X4_SC8815SC8815QFN32-4X4U1SQ33065_3_QFN20_3D5X4D5_MP9928MP9928QFN20_3D5X4D5U5RT9167A-28CB,SOT23_53_LQFP64_GD32F303RGT6GD32F303RGT6LQFP64U10FD6288Q_0_QFN28-4X4_SW3516HSW3516HQFN28-4X4U31MT3608_4_SOP8-EP_SCT2450SCT2450SOP8-EPU32MT3608_3_SOP8-EP_SCT2450SCT2450SOP8-EPU33MT3608_1_SOP8-EP_SCT2450SCT2450SOP8-EPU34PT4115_0_SOT23-6B_PT4121E23FPT4121E23FSOT23-6BU54RT9167A-28CB,SOT23_66_QFN20-4X4_TD8655TD8655QFN20-4X4U56FD6288Q_0_QFN28-4X4_SW3516HSW3516HQFN28-4X4U58LDO_1_SOT-89_ME6203A33PG/SOT89ME6203A33PG/SOT89SOT-89U60TMB12A03_0_BUZZER_12_2-2P_TMB12A03TMB12A03BUZZER_12_2-2PU61LDO_SOT-23_HX6206P182MRHX6206P182MRSOT-23U62MX25L12835EMPQ4430QFN16-3X4U63BT3L_MZ_BLUE_BT3L_BT3LBT3LMZ_BLUE_BT3LU65LDO_1_SOT-89_ME6203A50PG/SOT89ME6203A50PG/SOT89SOT-89Y127MHZ_SMD3225_4P_XTAL_3225_24MHZ24MHzXTAL_3225Z45BZX84C16/SOT_8_SOD323_32V32VSOD323Z46BZX84C16/SOT_8_SOD323_15V15VSOD323 PCB文件来了
**** Hidden Message ***** armclub:
PCB 原理图 立项书,规格书。程序等。 回复可见下载
[内容隐藏]
images/back.gif
感谢楼主分享!!! 谢谢分享
