wallys 发表于 2023-2-15 14:37
Wallys\\\\5g industrial router/IPQ6010 IPQ6018 openwrt QCN9074 QCN9024
Wallys\\5g industrial router/IPQ6010 IPQ6018 openwrt QCN9074 QCN9024
https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html
Wallyshas been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Absolute Maximum Rating
Parameter
RatingUnitSupply Voltage
24V~48V(DC Jack)VOperating Temperature Range
-40 to +70oCStorage Temperature Range
-45 to +105oCOperating Humidity Range
5 to +95 (non-condensing)%
Hardware Specifications
Symbol
ParameterCPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
125mm x 105mm x 20mm
Boot Config Switch
Boot_Config Switch1(S7)Boot_ConfigBoot up InterfaceSelectS7AS7BS7C
000SPI NOR. (Default)001eMMC010QPIC, Parallel NAND011USB3.0100SPI-NOR-GPTS7DBoot up InterfaceSelect0Boot from code ram.(Default)1Boot from ROMBoot_Config Switch2(S9)Boot_ConfigBoot up InterfaceSelect0No auth.(Default)1Auth is required
Interface MAP
                                                    https://www.wallystech.com/ueditor/php/upload/image/20211124/1637738459752443.png
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective router boards , wireless network cards,antenna ,enclosure and etc., Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.Skype/EMAIL/Teams:sales@wallystech.comWEB:https://www.wallystech.com/
bidinghong 发表于 2023-2-15 15:39
heming2216 发表于 2023-2-16 03:22
清心如水 发表于 2023-2-16 08:02
huangchang 发表于 2023-2-16 08:05
power3 发表于 2023-2-16 08:11
chinachen 发表于 2023-2-16 08:28
luoyj1999 发表于 2023-2-16 08:40
谢谢分享
brilliance 发表于 2023-2-16 08:47
sekisan 发表于 2023-2-16 08:55
页: [1] 2 3
查看完整版本: Wallys\\5g industrial router/IPQ6010 IPQ6018 openwrt QCN9074 QCN9024
