Wallys/QSDK/IPQ4019 and IPQ4029 chipsets support 20 km remote transmission
The IPQ4019 and IPQ4029 chipsets from Qualcomm are designed for high-performance Wi-Fi networks, providing advanced features such as MU-MIMO, beamforming, and enhanced spectral efficiency. These chipsets are suitable for a wide range of applications, including enterprise, industrial, and residential wireless networks.When combined with the Wallys WiFi5 Industrial Wireless AP DR-AP40X9-A, these chipsets can provide exceptional long-range connectivity. The DR-AP40X9-A is designed for outdoor use and is equipped with high-power radios and antennas, allowing it to cover a large area with a strong Wi-Fi signal. With the IPQ4019 or IPQ4029 chipset, the DR-AP40X9-A can deliver reliable and high-speed wireless connectivity over long distances, making it an ideal solution for industrial applications, remote locations, and outdoor environments.
Description
DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Panel Antenna
■2 x 5G Antenna
■5G: 17dbi
DRA25 Antenna
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
Enclosure
■Dimension: 275x140x48mm
■UV Protected and Durable ABS Radome
■IP67 Waterproof Level
■Support WallysDR4029
DR-AP4029(Outdoor) is a high-power radio AP router that operates on both 2.4GHz and 5GHz frequencies. It comes with a DR40X9 board, an Omni antenna, a POE adapter, and an enclosure. The panel antenna of DR-AP4029 includes 2x 5G antennas with a gain of 17dbi. Additionally, the DRA25 antenna has a frequency range of 2.42.5&5.155.85GHz, a peak gain of 6±0.5dBi, and a linear vertical polarization. The antenna is connected using RG-141 cable and N-type plug connectors. It can operate within a temperature range of -40℃~+65℃ and can withstand cable temperatures of less than +250℃.
The enclosure of DR-AP4029 has dimensions of 275x140x48mm and is made of UV-protected and durable ABS Radome material. It has an IP67 waterproof level and supports Wallys DR4029.
