armclub 发表于 2023-4-27 15:02
ALLEGRO17.4 PCB封装库(BCM53202+BCM5482S+sfpx1-sh)
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1DIODE_3_SMB_S1GS1GSMBD2LED_3_TVS7650_B3D090LB3D090LTVS7650D3LED_3_TVS7650_B3D090LB3D090LTVS7650D4LED_3_TVS7650_B3D090LB3D090LTVS7650D5LED_3_TVS7650_B3D090LB3D090LTVS7650D6LED_3_TVS7650_B3D090LB3D090LTVS7650D7LED_3_TVS7650_B3D090LB3D090LTVS7650D8LED_3_TVS7650_B3D090LB3D090LTVS7650D9LED_2_TVS7650_B3D090LB3D090LTVS7650D10LED3X1_2_LED_A694B_2G_LED2X1(DLED2X1(DIP)LED_A694B_2GD14DIODEDIAC_SOD-323_BV03CBV03CSOD-323D27DIODEDIAC_SOD-323_BV03CBV03CSOD-323D28LED3X1_2_LED_A694B-2G_LED2X1(DLED2X1(DIP)LED_A694B-2GD29LED3X1_2_LED_A694B-2G_LED2X1(DLED2X1(DIP)LED_A694B-2GD30DIODEDIAC_SOD-323_BV03CBV03CSOD-323D32CAP_SOD-323_TVSTVSSOD-323D33LED3X1_2_LED_A694B_2G_LED2X1(DLED2X1(DIP)LED_A694B_2GD34DIODEDIAC_SOD-323_BV03CBV03CSOD-323D53LED_LED0603-RF_LEDLEDLED0603-RFD54LED_LED0603-RF_LEDLEDLED0603-RFD55LED_LED0603-RF_LEDLEDLED0603-RFD56LED_LED0603-RF_LEDLEDLED0603-RFD62DIODEPIN_1_SMC_S3Gs3gSMCD63DIODEPIN_1_SMC_S3Gs3gSMCD64DIODEPIN_1_SMC_S3Gs3gSMCD65DIODETVS BI-DIR_SMCJ_SMCJ TVSSMCJTVSSMCJD66DIODEPIN_1_SMC_S3Gs3gSMCD67DIODEPIN_1_SMC_S3Gs3gSMCD68DIODEPIN_1_SMC_S3Gs3gSMCD69DIODETVS BI-DIR_SMCJ_SMCJ TVSSMCJTVSSMCJD70DIODEDIAC_SOD-323_BV03CBV03CSOD-323D91DIODEDIAC_SOD-323_BV03CBV03CSOD-323D92DIODETVS BI-DIR_BS2600N_BS2600BS2600NBS2600ND93DIODETVS BI-DIR_BS2600N_BS2600BS2600NBS2600NF1R_0_FUSE_3216FF-1A3216FF-1AFUSEF2R_0_FUSE_3216FF-1A3216FF-1AFUSEFB7FB_L0603_A600@100MHZA600@100MHzL0603FB8FB_L0603_A600@100MHZA600@100MHzL0603FB9FB_L0603_A600@100MHZA600@100MHzL0603FB10FB_L0603_A600@100MHZA600@100MHzL0603FB15FB_L0603_600600L0603FB16FB_L0805_600OHM600OHML0805FB17FB_L0603_600600L0603FB18FB_L0603_600600L0603FB19FB_L0603_220OHM220OHML0603FB21FB_L0603_600600L0603FB22FB_L0805_600OHM600OHML0805FB30FB_L0603_220OHM220OHML0603FB31FB_L0603_600600L0603H1CON20_1_CON-1X2P-200_CON2_DELAYCON2_delayCON-1X2P-200J1RJ45_21_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLEDJ2HEADER10X2_2_SFPX1-SH_HEADER 1HEADER10X2SFPX1-SHJ3HEADER10X2_2_SFPX1-SH_HEADER 1HEADER10X2SFPX1-SHJ4HEADER4_0_PWR-SIP-4P_HEADER1X4HEADER1x4x200PWR-SIP-4PJ5HEADER4_0_CON-1X4P-200_HEADER1HEADER1x4x200CON-1X4P-200J6HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9J7RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J8HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9J9RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J10CONNEDGE 36X2_2_HD_20X2_SMD_COCON_20x2_PIN_femaleHD_20X2_SMDJ11RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J12HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9J13RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J14RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J15HEADER4_1_CON318-4_HEADER1X4HEADER1x4CON318-4J16HFBR5803_0_SC-ST1X9_HFBR5803HFBR5803SC-ST1X9J17RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J18RJ45_13_RJ45_1X1_SJ_011_RJ45_1XRJ45_1X1RJ45_1X1_SJ_011J25RJ45_15_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLEDJ26RJ45_15_RJ45_1X1_NOLED_RJ45_1X1RJ45_1X1RJ45_1X1_NOLEDL2FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603L3FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603L4FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603L5FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603L6FB_LC1206_1R01R0LC1206L7INDUCTOR_LC0805_600R0805600R0805LC0805L8FB_LC0603_120OHMS@100MHZ120OHMs@100MHzLC0603L9FB_LC0603_120OHMS@100MHZ/NC120OHMs@100MHz/NCLC0603L10FB_LC1206_1R01R0LC1206L11INDUCTOR_LC0805_600R0805600R0805LC0805L12INDUCTOR_LC0805_600R0805600R0805LC0805L13FB_LC1206_1R01R0LC1206L16INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43L17INDUCTOR_0_LC0603_600R300MA600R300mALC0603L18INDUCTOR_0_LC0805_1R01R0LC0805L19INDUCTOR_CC0805_150MA150mACC0805L20INDUCTOR_CC0805_150MA150mACC0805L21INDUCTOR_0_LC0805_1R01R0LC0805L22INDUCTOR_0_LC0603_600R300MA600R300mALC0603L23INDUCTOR_0_LC0805_1R01R0LC0805L24INDUCTOR_0_LC0603_600R300MA600R300mALC0603L25INDUCTOR_CC0805_150MA150mACC0805L26INDUCTOR_0_LC0805_1R01R0LC0805L27INDUCTOR_0_LC0603_600R300MA600R300mALC0603L28INDUCTOR_0_LC0603_600R300MA600R300mALC0603L29INDUCTOR_0_LC0805_1R01R0LC0805L30INDUCTOR_CC0805_150MA150mACC0805L31INDUCTOR_0_LC0805_1R01R0LC0805L32INDUCTOR_0_LC0805_600R300MA600R300mALC0805L33INDUCTOR_0_LC0603_600R300MA600R300mALC0603L34INDUCTOR_0_LC0805_1R01R0LC0805L35INDUCTOR_0_LC0603_600R300MA600R300mALC0603L36INDUCTOR_CC0805_150MA150mACC0805L37INDUCTOR_0_LC0805_1R01R0LC0805L38INDUCTOR_0_LC0603_600R300MA600R300mALC0603L39INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43L40INDUCTOR_CDRH8D43_8.2UH,20MOHM8.2uH,20mOHMCDRH8D43L41INDUCTOR_CC0805_150MA150mACC0805L42INDUCTOR_CC0805_150MA150mACC0805L43INDUCTOR_CC0805_150MA150mACC0805MH1MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MMMH2MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MMMH3MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MMMH4MH-8VIA_MT8-3_5-6_5MM_4-40X3/4I4-40X3/4in-SCREWMT8-3_5-6_5MMQ1PNPBEC_SOT23M2_85508550SOT23M2RLY1RELAYDPDT_5_DIP12-1_TX2-3VTX2-3VDIP12-1T1PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT2PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT3PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT4PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT5PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT6PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT7PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT8PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANT9PE68515_6_SO16W_LAN_HST-0031SCRHST-0031SCRSO16W_LANTP1TP_TP30_REDREDTP30TP2TP_TP30_REDREDTP30TP3TP_TP30_REDREDTP30U1MAX3223_3_SSOP28_SP3243ECASP3243ECASSOP28U2PE68515_9_232_NET_USR-TCP232-SUSR-TCP232-S232_NETU5USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8U7PE68515_13_SO-16_MAX3232MAX3232SO-16U14BCM53242M_BGA400-1_27MM_BCM5320BCM53202BGA400-1_27MMU22BCM5482SKPB_BGA121-1MM_BCM5482SBCM5482SBGABGA121-1MMU23XFMR-H5007-NS_XFMR_SO24_H5007H5007XFMR_SO24U24XFMR-H5007-NS_XFMR_SO24_H5007H5007XFMR_SO24U25USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8U26USB_19_3X7_0_SOT23-8_MP1497MP1497SOT23-8U422504_5_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504U432504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504U442504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504U452504_4_DFN10-TH-2504_RCLPAM3304Rclpam3304DFN10-TH-2504U46TVS_SOD323_BV03CBV03CSOD323U47TVS_SOD323_BV03CBV03CSOD323U48TVS_SOD323_BV03CBV03CSOD323U49TVS_SOD323_BV03CBV03CSOD323U50TVS_SOD323_BV03CBV03CSOD323U51TVS_SOD323_BV03CBV03CSOD323U52TVS_SOD323_BV03CBV03CSOD323U53TVS_SOD323_BV03CBV03CSOD323U54TVS_ANT3216_BS201N/NCBS201N/NCANT3216U55TVS_ANT3216_BS201N/NCBS201N/NCANT3216U5674HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U5774HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U5874HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U5974HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6074HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6174HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6274HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6374HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6474HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6574HC164_0_TSSOP14_74HC164D74HC164DTSSOP14U6674LS244/SO_0_TSSOP20_74LS244/SO74LS244/SOTSSOP20U67AT93C46_1_SO8M1_AT93C46/NCAT93C46/NCSO8M1U68RESET_0_SOT23_MAX809MAX809SOT23Y3XTAL_DY49US-11_05X4_65H3_5_25.025.000625MHzDY49US-11_05X4_65H3_5Y4XTAL_DY49US-11_05X4_65H3_5_25_125.000MHzDY49US-11_05X4_65H3_5
jackychen456 发表于 2023-4-27 15:40
bidinghong 发表于 2023-4-27 19:50
单枪舞九州 发表于 2023-4-27 20:09
加油
nj20044 发表于 2023-4-28 00:08
kanxue_nmg 发表于 2023-4-28 06:33
ilpuyi 发表于 2023-4-28 08:36
lyjunnan 发表于 2023-4-28 08:37
ntpcb3356619 发表于 2023-4-28 08:44
sekisan 发表于 2023-4-28 08:49
页: [1] 2 3 4 5 6
查看完整版本: ALLEGRO17.4 PCB封装库(BCM53202+BCM5482S+sfpx1-sh)
