万兆10G 交换机PCB文件 RTL9311BR+DDR4+RTL8218E+RTL8231+RTL8363SC
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON1MINIPCIE GOLD FINGER_MINI_PCIEMINIPCIE Gold fingerMINI_PCIE_GOLDFINGER7_11D1DIODE_SCHOTTKY_SMC_B320-13-FB320-13-FSMCD2DIODE_12_MLL34_LL4148LL4148MLL34D3LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602D4DIODE_ZENER_SOD-523_NI_BZT52C9VNI_BZT52C9V1TSOD-523D5LED1X1_LED-3MM_LED_1X1_Yled_1x1_YLED-3MMD9LED1X1_LED0603_LED_1X1_Rled_1x1_RLED0603D10LED1X1_LED0603_LED_1X1_Rled_1x1_RLED0603D11LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602D37LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602D38LED1X1_LED_SMD_0602_LED_1X1_GREled_1x1_greenLED_SMD_0602D39ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323D40ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323D41ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323D42ONE-LINE_BI_TVS_SOD-323_NC-TVS_NC-TVS_SPD9103WSOD-323EC1CAP_P_E_EC8X12R5-3R5_470UF/25V470uf/25vEC8X12R5-3R5EC2CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMDEC3CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC4CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC5CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMDEC6CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC7CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC8CAP_P_E_EC8X10P5_SMD_220UF/25V220uf/25vEC8X10P5_SMDEC9CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC10CAP_P_E_EC8X11R5-3R5_560UF/4V560uf/4vEC8X11R5-3R5EC11CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CEC12CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CEC13CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CEC14CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CEC15CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CEC16CAP_P_E_EC1P2C_100UF/25V100uf/25vEC1P2CFB1L_L0402_120OHM@100MHZ/1.2A120ohm@100MHz/1.2AL0402H1MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH2MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH3MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH4MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH5MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH6MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH7MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH8MOUNTHOLE_1PIN_HOLE_M3_5_PAD_33_5_holeHOLE_M3_5_PADH16MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLDH17MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLDH18MOUNTHOLE_1PIN_5_7MMHOLD_5.7MM5.7mmhole5_7MMHOLDHS1HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MMHS2HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MMHS3HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MMHS5HEAT_SINK_HS_60X60X30-70MM_HS_6HS_60X60X30mmHS_60X60X30-70MMHS6HEAT_SINK_HS_35X35X28MM_HS_35X3HS_35X35X28mmHS_35X35X28MMJ1HEADER_4X1_XH2P5_4X1_XH-4AW_2.5XH-4AW_2.5mmXH2P5_4X1J2POWERJACK_3P_ROUND_POWERJACK_3PDCJACK_3P_ROUNDPOWERJACK_3PJ3CONN_8P_PWR_PW8P_396MM_CONN_8P_CONN_8P_PWR_3.96MMPW8P_396MMJ4BUTTON_RESET_BUT_DTS-62K-VDTS-62K-VRESET_BUTJ5JTAG_10X2_1.27MM_JS10X2-50MIL_JJTAG2x10PIN 1.27mmJS10X2-50MILJ6PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROWJ7PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROWJ8PHJ8-2ROW_RJ45-PHJ8-2ROW_2X4POR2X4PORT_RJ45RJ45-PHJ8-2ROWL1CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L2CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L3CHOKE_L2220_550OHM@100MHZ_4A550ohm@100Mhz_4AL2220L4CHOKE_POWER_L6R0X6R0X4R5_4.7UH/4.7uh/3.37AL6R0X6R0X4R5L5CHOKE_L2220_550OHM@100MHZ_4A550ohm@100Mhz_4AL2220L6CHOKE_POWER_WE744311_1.0UH/15A1.0uH/15AWE744311L7CHOKE_POWER_L10X10X5_0.72UH/22A0.72uH/22AL10X10X5L8CHOKE_POWER_L4R5X4R0_2.2UH/3A2.2uH/3AL4R5X4R0L9CHOKE_POWER_L10R5X10R2X5R0_3.3U3.3uH/12AL10R5X10R2X5R0L10CHOKE_POWER_L10X10X5_0.72UH/22A0.72uH/22AL10X10X5L11CHOKE_L0402_120OHM100MHZ L0402120ohm100MHZ L0402L0402L12CM_CHOKE_4PIN_L1220_4PIN_NI_RFCNI_RFCMF1220100M4TL1220_4PINL13CHOKE_L1206_120OHM100MHZ L1206120ohm100MHZ L1206L1206L14CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L15CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L16CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L19CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L20CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L21CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L22CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L23CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L24CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L25CHOKE_L0603_120OHM100MHZ L0603120ohm100MHZ L0603L0603L26CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L27CHOKE_L0603_120OHM@100MHZ_2.5A120ohm@100Mhz_2.5AL0603L29CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L30CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L31CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L32CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L33CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L34CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L35CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805L36CHOKE_L0805_120OHM100MHZ L0805120ohm100MHZ L0805L0805LED1GS2011AR-G_SMD10-1E44-7R20X10R0GS2011AR-GSMD10-1E44-7R20X10R0P1USB20A_LIE90_USB20A_LIE90_F_USBUSB20AX1_RECEPTACLEUSB20A_LIE90_FPIC1CAP_NP_C0402_0.1UF/25V-Y5V0.1uF/25V-Y5VC0402PIC2CAP_NP_C0603_1UF/6.3V-X5R1uF/6.3V-X5RC0603PIC3CAP_NP_C0805_10UF/6.3V-X5R10uF/6.3V-X5RC0805PIC4CAP_NP_C0402_0.01UF/25V-X7R0.01uF/25V-X7RC0402PIC5CAP_NP_C0805_10UF/6.3V-X5R10uF/6.3V-X5RC0805PIC6CAP_NP_C0402_0.1UF/25V-Y5V0.1uF/25V-Y5VC0402PIL1INDUCTOR_LVS505040_2.2UH/2.5A2.2uH/2.5ALVS505040PJ1PHJ1-1ROW_RJ45-PHJ1-1ROW_1X1POR1X1PORT_RJ45RJ45-PHJ1-1ROWPJ3PHJ1-1ROW_RJ45-PHJ1-1ROW_1X1POR1X1PORT_RJ45RJ45-PHJ1-1ROWQ1MOS_N-CHANNEL_SOT-23_2N7002K-72N7002K-7SOT-23Q2MOS_N-CHANNEL_SOT-23_2N7002K-72N7002K-7SOT-23RV1RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5RV2RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5RV3RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5RV4RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5RV5RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5RV6RV_1_RES_VA_7D5_FNR-10K271HSFNR-10K271HSRES_VA_7D5SW1DIP_SW-4_0_SWDIP_4_NDSR-4-VNDSR-4-VSWDIP_4T11X1PIN_JP1X1_NI_1X1PIN2.54MMNI_1X1PIN2.54mmJP1X1T2TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T3TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T4TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T5TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T6TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T7TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T8TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T9TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1T102X6PIN_JP6X2_2X6PIN2.54MM2X6PIN2.54mmJP6X2T112X6PIN_JP6X2_2X6PIN2.54MM2X6PIN2.54mmJP6X2T122X5PIN_JP5X2_2X5PIN2.54MM2X5PIN2.54mmJP5X2T131X7PIN_JP7X1_1X7PIN2.54MM1X7PIN2.54mmJP7X1T141X6PIN_JP6X1_1X6PIN2.54MM1X6PIN2.54mmJP6X1T161X4PIN_JP4X1_1X4PIN2.54MM1X4PIN2.54mmJP4X1T18TEST_POINT_JP1X1_NI_1X1PIN2.54NI_1X1PIN2.54mmJP1X1U16_TOP1DDR4X16_4_FBGA96_0R8_DDR4DDR4FBGA96_0R8U18_TOP1DDR4X16_3_FBGA96_0R8_DDR4DDR4FBGA96_0R8U1RT7294C_SOT-23-6_RT7294CGJ6FRT7294CGJ6FSOT-23-6U2MP1653_SOT23-6_0_5_MP1653MP1653SOT23-6_0_5U3TPS5331X_LSON-CLIP_22_TPS53319DTPS53319DQPLSON-CLIP_22U4MP20073DH_0_SOP8_4_9_0_65_EP_MPMP20073DH_5SOP8_4_9_0_65_EPU5MP1653_SOT23-6_0_5_MP1653MP1653SOT23-6_0_5U6TPS54821_VQFN14_3R5X3R5_0R5_TPSTPS54821VQFN14_3R5X3R5_0R5U7TPS5331X_LSON-CLIP_22_TPS53319DTPS53319DQPLSON-CLIP_22U10MAX706_SOP8_MAX706RESAMAX706RESASOP8U1174LV08_SOP14_74LV08PW74LV08PWSOP14U1274LV08_SOP14_74LV08PW74LV08PWSOP14U14SPI_NAND_SOP16_SOP16-SPIF-SKT_FFLASH_16PIN_SKTSOP16-SPIF-SKTU15SPI_FLASH_SOP16_SOP16-SPIF-SKT_FLASH_16PIN_SKTSOP16-SPIF-SKTU18TVS_4LINE_SOT-23-6_TVS_AZ1013-0TVS_AZ1013-04SSOT-23-6U19SPI_FLASH_SOP8_SOP8-SPIF-SKT_MXMX25L12835FMI-10GSOP8-SPIF-SKTU20SPI_FLASH_SOP8_SOP8-SPIF-SKT_MXMX25L12835FMI-10GSOP8-SPIF-SKTU2174HC125D_SOP14_74HC125D74HC125DSOP14U23MAX3232_TSSOP16_MAX3232CPWRMAX3232CPWRTSSOP16U2474HC125D_SOP14_74HC125D74HC125DSOP14U25RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5U26RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5U27RTL8218E_LQFP128_LQFP128_20X14_RTL8218ELQFP128_20X14_EPAD_0R5U30SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1U31SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1U32SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1U33SFP1X1_SFP-CAGE-1X1_SFP_CAGE_1XSFP_CAGE_1x1SFP-CAGE-1X1U34RTL8231_GPIO_LQFP48_RTL8231RTL8231LQFP48U35RTL8231_SHIFT_LQFP48_RTL8231RTL8231LQFP48U36PARALLEL_NAND_TSOP48_TSOP48_PARW29N08GVSIADTSOP48_PARALLELFLASHU37RTL9311BR_DDR4_DEMO_BGA841C50P2RTL9311BRBGA841C50P29X29_1500X1500X250U38G2404DG_G2404DG_G2404DGG2404DGG2404DGU40VRTL8363SC_QFN56_1_QFN56_7X7_0_RTL8363SC-VB_MQFNT56QFN56_7X7_0_4MMX1QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX18QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX20QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX22QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX23QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX24QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX25QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX26QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX27QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX28QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX29QP2093Q_QP2093Q_QP2093QQP2093QQP2093QX30QP2093Q_QP2093Q_QP2093QQP2093QQP2093QY1CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49USY2CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49USY3CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49USY4CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49USY6CRYSTAL_XTAL_49US_25MHZ_CRYSTAL25MHZ_CrystalXTAL_49US PCB文件。回复可见下载。
**** Hidden Message ***** 感谢老吴的无私分享。。谢谢 !!!!!! 牛逼 下载学习
