NVIDIA 高端显卡 GTX1660TI 挂8个GDDR6 PCB文件
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBK1BRACKET_ATX_2X_2P-BRKT_DUAL_ATX_2TAB_PG161,151-XXXX-XXX-151-XXXX-XXX BRKT_ATX_2TAB_1_DVID_DP_DP_2_HDMI_3_DPCN1CON_PCI_EXPRESS_NONPHY-X16-CON_PCIEXP_X16_EDGE,EDGEFINGER,1MM,N/A,N/A,N/A,N/A,NO,NO,50V,1.1A,065-00044-0000-000-065-00044-000A CON_FINGER_PEX_164D1D_3PIN_CC_SOT23-BAT54C,1PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0016-000-091-0016-000 SOT23D2D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D3D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D4D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D5D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D6D_SOT323-BAT54W,SINGLE,30V,0.6A,1V@0.1A,0.2A,090-0106-000-090-0106-000 SOT323D501D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D502D_ESD_NORM-AZ5725-01F,1LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000 DIODE_SMD_010X060D503D_SOD523-1N4148WT,SINGLE,80V,0.25A,0.75V@50MA,0.25A,090-0105-000-090-0105-000 DIODE_SMD_SOD523_BD504D_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 DIODE_SMD_SOD523_BD505D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 SOT323D506D_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000 DIODE_SMD_SOD523_BD507D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 SOT323D508D_3PIN_AA_SOT323-BAS70-06W,1PAIR - COMMON ANODE,70V,0.1A,1V@15MA,70MA,090-0287-000-090-0287-000 SOT323G1U_GPU_GB4B_256_BGA2228-TU104-400-A1,GPU- DESKTOP,TU104-400-A1-TU104-400-A1 BGA_2228_P070_375X375J1CON_DISPLAYPORT_NORM-G3167CE04-010-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,N/A,N/A,080-1143-000-080-1143-000 CON_DP_020_SMT_RA_F_BJ2CON_DISPLAYPORT_NORM_4GND-CONNDPF01505-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,40.0V,0.5 A,080-1377-000-080-1377-000 CON_DP_020_SMT_RA_F_CJ3CON_DISPLAYPORT_NORM_4GND-CONNDPF01505-H,RECEPTACLE,0.5MM,90,YES,YES,YES,YES,YES,40.0V,0.5 A,080-1377-000-080-1377-000 CON_DP_020_SMT_RA_F_CJ4CON_HDMI_HDMI_A_SMD-CONNSMD HDMI FEMALE RA 19 POS 0.50MM PITCH W/SPRING,RECEPTACLE,0.5MM,90,YES,NO,YES,YES,YES,N/A,N/A,080-1B CON_HDMI_019_SMT_RA_F_P005_GJ5CON_DVI_D_DVI_D_SHLD-DVI-D_BEIGE,FEMALE,1.905MM,90,YES,YES,NO,NO,NO,N/A,N/A,065-0500-000-065-0500-000 CON_DVID_024_RA_F_SHDJ6HDR_1X4_NORM-HDR_1M4,MALE,2.0MM,VERTICAL,YES,YES,YES,800VAC,1A,074-0098-000-074-0098-000 CON_WAFER232_004_TH_ST_P020J7HDR_2X4_PCIEPWR_8P-CONNTHRU PCI-E POWER FEMALE RA 8 POS 4.20MMPITCH,RECEPTACLE,4.2MM,90,NO,YES,YES,N/A,N/A,075-0286-000-075-A CON_PWR_002X004_TH_RA_M_P042L1L_SMD_5X5-4.7UH,FERRITE,20%,2.5A,2.8A,0.074OHM,[]@[ ],[ ],N/A,130-1260-000-130-1260-000,4.7UH4.7uHIND_NONRKO_SMD_050X050_FL2L_SMD_5X5-4.7UH,ALLOYCORE,20%,3.4A,4.1A,0.07992OHM,0@0HZ,0HZ,N/A,130-1241-000-130-1241-000,4.7UH4.7uHIND_NONRKO_SMD_057X052L3L_SMD_5X5-4.7UH,ALLOY,20%,3.5A,4A,0.085OHM,40@300KHZ,[],N/A,130-1138-000-130-1138-000,4.7UH4.7uHIND_NONRKO_SMD_055X052L4L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L5L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L6L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L7L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L8L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L9L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L10L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L11L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L12L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L13L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L14L_TH-0.22UH,[],20%,35A,58A,0.000739OHM,[ ]@[ ],[ ],[ ],131-0569-000-0.22UH,131-0569-0000.22uHIND_NONRKO_TH_108X080L15L_TH-0.22UH,FERRITE,20%,35A,58A,0.737OHM,0@0HZ,0HZ,0DECIBEL,130-0148-000-0.22UH,130-0148-0000.22uHIND_NONRKO_TH_105X075L16L_TH-1UH,IRON,20%,25A,35A,0.0024OHM,999@999KHZ,999MHZ,N/A,130-1261-000-130-1261-000,1UH1uHIND_NONRKO_TH_100X100_BL17L_TH-1UH,IRON,20%,25A,35A,0.0024OHM,999@999KHZ,999MHZ,N/A,130-1261-000-130-1261-000,1UH1uHIND_NONRKO_TH_100X100_BL18L_SMD_5X5-1UH,ALLOYPOWDER,20%,8A,9A,0.017OHM,43@300KHZ,[ ],N/A,130-1139-000-130-1139-000,1UH1uHIND_NONRKO_SMD_055X052L19L_7_6X7_6-1UH,IRON,20%,7A,14A,0.0183OHM,[]@[ ],[ ],[ ],130-1025-000-130-1025-000,1UH1uHIND_NONRKO_SMD_073X067L20L_7_6X7_6-1UH,IRON,20%,7A,14A,0.0183OHM,[]@[ ],[ ],[ ],130-1025-000-130-1025-000,1UH1uHIND_NONRKO_SMD_073X067L21L_TH-1UH,[],20%,16A,18A,0.00324OHM,[ ]@[ ],[ ],[ ],131-0652-000-131-0652-000,1UH1uHIND_NONRKO_TH_082X082LB1L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB2L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB3L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB4L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB5L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB6L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB7L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB8L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmIND_SMD_0402LB501L_BEAD_0603-30OHM,FERRITE,25%,5A,5A,0.01OHM,[],N/A,N/A,100-0049-000-100-0049-000,30OHM30ohmIND_SMD_0603LB502L_BEAD_0603-30OHM,FERRITE,25%,5A,5A,0.01OHM,[],N/A,N/A,100-0049-000-100-0049-000,30OHM30ohmIND_SMD_0603M1U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M2U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M3U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M4U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M9U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M10U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M11U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140M12U_MEM_SG_GDDR6_FBGA180-3GHZ,OTHER,32BIT,1.3095V,MT61K256M32JE-12:A,161-0324-900-161-0324-900 BGA_0180_P075_120X140MEC1MOUNTING_HOLE_X8-PG161_MOUNTING_HOLES MECH_PEX_01447X01112_HOLE_PG161MEC501STIFFENER_4PIN-GPU_STIFFENER_PG161,320-XXXX-XXX-320-XXXX-XXX HSB_GPU_TU106_B_ST_1Q1Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q2Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q3Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 SOT23Q4Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q5Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q6Q_FET_N_ENH_SOT323_1G1D1S-PJC138K,50V,1600MOHM@10V/ 2500MOHM@4.5V / 4500MOHM@2.5V,0.36A,1.2A,20V,0.236W,0NC@10V / 1NC@4.5V / B SOT323Q7Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q8Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 SOT23Q9Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q10Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q11Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q12Q_FET_N_ENH_SOT323_1G1D1S-PJC138K,50V,1600MOHM@10V/ 2500MOHM@4.5V / 4500MOHM@2.5V,0.36A,1.2A,20V,0.236W,0NC@10V / 1NC@4.5V / B SOT323Q13Q_FET_N_ENH_PWR_PHASE-QM3816N6,30V/ 30V,7.3MOHM,1.9MOHM@10V / 11.7MOHM,2.9MOHM@4.5V / [ ],[ ]@2.5V,10A /22A,102A / 234A,20V B MULTI_DFET_010_SMD_050X060Q14Q_FET_N_ENH_PWR_PHASE-QM3816N6,30V/ 30V,7.3MOHM,1.9MOHM@10V / 11.7MOHM,2.9MOHM@4.5V / [ ],[ ]@2.5V,10A /22A,102A / 234A,20V B MULTI_DFET_010_SMD_050X060Q501Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q502Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q503Q_NPN_SOT323_1B1C1E-MMBT3904WT1G,60V,[],0.2A,0.2A,6V,0.15W,305-0031-000-305-0031-000 SOT323Q504Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 SOT23Q505Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q506Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q507Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q508Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q509Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q510Q_FET_P_ENH_DFN3X3_DUAL-EMF20B02V,-20V/ -20V,[ ],[ ]@10V / 20MOHM,20MOHM@4.5V / 25MOHM,25MOHM@2.5V,25MOHM /-6A,-34A / -34A,1B MULTI_DFET_SMD_030X030Q511Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q512Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q513Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q514Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q515Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q516Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q517Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q518Q_NPN_SOT363-MMBT3904D,60V,[],0.2A,0.2A,6V,0.15W,305-0057-000-305-0057-000 SC70_6Q519Q_FET_N_ENH_SOT363-2N7002DW,60V,-1000MOHM@10V/ -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.5A,20V,0.225W,[ ]@10V /9999NC@4.5V /B SC70_6Q520Q_FET_N_ENH_SOT323_1G1D1S-2N7002W,60V,5000MOHM@10V/ 7500MOHM@4.5V / 0MOHM@2.5V,0.115A,0.8A,20V,0.12W,[ ]@10V / 0.7NC@4.5V / 0B SOT323Q521Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 SOT23Q522Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,1V,0.6A,[],6V,0.35W,300-0878-000-300-0878-000 SOT23RS1R_SENSE_1206_4PIN-0.005OHM,1%,1W,100PPM,215-0327-000-0.005OHM,215-0327-0000.005ohmRES_04_SMD_032X016RS2R_SENSE_2512_VIRTUAL_4PIN-0.005OHM,1%,2W,100PPM,215-0139-000-0.005OHM,215-0139-0000.005ohmRSENSE_VIRTUAL_04_SMD_2512_CRS501R_SENSE_2512_VIRTUAL_4PIN-0.005OHM,1%,2W,100PPM,215-0139-000-0.005OHM,215-0139-0000.005ohmRSENSE_VIRTUAL_04_SMD_2512_CRT1THERMISTOR_0402-1K_B25/100=0K,50%,0.999W,PTC,093-0032-000-093-0032-000,1K_B25/100=0K1k_B25/100=0K402RT2THERMISTOR_0603-100K_B25/85=4550K,5%,[],NTC,093-0014-000-093-0014-000,100K_B25/85=4550K100k_B25/85=4550K603RT3THERMISTOR_0603-100K_B25/85=4550K,5%,[],NTC,093-0014-000-093-0014-000,100K_B25/85=4550K100k_B25/85=4550K603RT4THERMISTOR_0402-100K_B25/50=4250K,1%,35MW,NTC,093-0042-000-093-0042-000,100K_B25/50=4250K100k_B25/50=4250K402TP1LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP2LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP3LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP4LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP5LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP6LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP501LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP502LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP503LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PTP504LABTESTPOINT_B28-LABTESTPOINT LTPT28C49PU1U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,2.5V..5.5V,2.5V..5.5V,0.72A,SWITCH,315-1014-000-315-1014-000 SOT23_5U2U_PWR_SW_UL_SOT23_5_DP-GS7615STDB-R,2.5V..5.5V,2.5V..5.5V,0.72A,SWITCH,315-1014-000-315-1014-000 SOT23_5U3U_OPENVREG_TYPE2PLUS_QFN3X3-UP1666QQKF,BUCK,2PH,1MHZ,DYNAMICVID,0MV..2V,1%,2V,20V,60A,1.47W,316-0467-000-2V,316-0467-0002VQFN020Q_P040_035X035_T017X017_CU4U_BUCK_FET_1PH_SOT23_8_NOVR-MP1475DJ,BUCK,1PH,500KHZ,NONE,0.807V..5V,2.5%,0.807V,16V,3A,1W,316-0470-000-0.807V,316-0470-0000.807VSOT23_8U5U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U6U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U7U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U8U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U9U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U10U_DRMOS_QFN5X5-NCP302150MNTWG,0.3V..5V,20V,45A,2W,316-0592-000-316-0592-000 QFN033Q_P050_0050_T036X020_T017X011_T014X011U11U_MEM_FL_SER_1MX8_SO_8-50MHZ,1.65V..1.95V,W25Q80EWSNIG,170-0268-000-170-0268-000 SO08_048X038U12U_AND_2IN_SC70-5-NL17SZ08DFT2G,GATES- AND - 2 INPUT,115-1448-000-115-1448-000 SC70_5U13U_BUCK_FET_1PH_QFN23_PIR-GS9216TQ-R,BUCK,1PH,600KHZ,NONE,0.6V..12V,1%,0.6V,22V,8A,2W,316-0630-000-0.6V,316-0630-0000.6VQFN023Q_P050_0040_T028X011_T028X014U14U_SW_LOAD_SOT363-GS7616SC-R,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1566-000-115-1566-000 SC70_6U15U_BUCK_FET_1PH_QFN23_PIR-GS9216TQ-R,BUCK,1PH,600KHZ,NONE,0.6V..12V,1%,0.6V,22V,8A,2W,316-0630-000-0.6V,316-0630-0000.6VQFN023Q_P050_0040_T028X011_T028X014U16U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U501U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U502U_PWR_SW_UL_SOT23_5_EFU-GS7612S5MA-R,2V..5.5V,2V..5.5V,0.55A,SWITCH,315-1048-000-315-1048-000 SOT23_5U503U_PWRMTR_NCP4549_QFN32-NCP45491XMNTWG,0MV..26V,2.7V..5.5V,0.5MA,MONITOR,315-1061-000-315-1061-000 QFN032Q_P040_0040_T027X027U504U_OPENVREG_TYPE4PLUS_QFN5X5-NCP81611MNTXG,BUCK,4PH,1.2MHZ,I2C,0MV..5V,1.5%,2V,20V,316-0641-000-2V,316-0641-0002VQFN040Q_P040_0050_T035X035_VIASU505U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U506U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U507U_LDO_UDFN4_NOVR-NCP114AMX330TCG,LOWDROPOUT/FIXED,0.2V@0.3A,3.3V..3.3V,2%,3.3V,5.5V,0.3A,0.4W,315-0999-000-3.3V,315-0999-0003.3VDFN04_P065_010X010_T005X005_VIASU508U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U509U_AND_2IN_SC70-5-M74VHC1GT08DFT2G,GATES- AND - 2 INPUT,115-0596-000-115-0596-000 SC70_5U510U_LDO_UDFN4_NOVR-NCP114AMX330TCG,LOWDROPOUT/FIXED,0.2V@0.3A,3.3V..3.3V,2%,3.3V,5.5V,0.3A,0.4W,315-0999-000-3.3V,315-0999-0003.3VDFN04_P065_010X010_T005X005_VIASY1XTAL_4PIN_SMD_32X25-27M_NKG,27MHZ,30PPM,2PPM,60PPM,18PF,FUNDAMENTAL,085-0135-000-085-0135-000,27MHZ27MHzXTAL_SMD_4_032X025 PCB文件。回复可见下载
**** Hidden Message ***** 感谢分享 学习下
回 老吴 的帖子
老吴:PCB文件。回复可见下载[内容隐藏]
(2024-01-21 11:19) images/back.gif
有没有原理图?PDF的也行,现在只喜欢研究原理之类,PCB画不动了 感谢版主 感谢分享 一起学习
