[/free]
DRC错误标记由带有两个字母的“领结”符号组成。字母代码指示违反了哪种约束类型。
Net-to-Net Spacing DRC错误标记代码为大写;相反,Same Net Spacing代码是小写的。
DRC错误标记代码定义
下表列出了每种DRC错误标记代码组合及其关联的约束违例。该列表根据DRC错误标记中的字母按字母顺序排列。
[free]
本主题需向作者支付 1 枚金币 才能浏览 购买主题
DRC错误标记代码定义
| Code | ConstraintViolation |
| A – A | Acuteangle to cavity edge |
| B – B | BondPad to Bond Pad |
| B – L | BondPad to Line |
| B – S | BondPad to Shape |
| C – C | Componentto cavity edge |
| Package to package | |
| Soldermask to soldermask | |
| D – C | DFAPackage to package |
| D – D | MechanicalDrill Hole to Mechanical Drill Hole |
| Mechanical Drill Hole to Drill Hole | |
| D – I | Negativeplane islands |
| D – L | MechanicalDrill Hole to Cline |
| Drill Hole to Cline | |
| D – P | PhaseTolerance Tolerance |
| Mechanical Drill Hole to Pin | |
| D – S | MechanicalDrill Hole to Shape |
| Drill Hole to Shape | |
| D – V | MechanicalDrill Hole to Via |
| Drill Hole to Via | |
| E – D | MaxFinal Settle Max |
| Min First Switch Min | |
| Noise Margin Min | |
| Overshoot Max | |
| Propagation Delay Max | |
| Propagation Delay Min | |
| Propagation Delay Path Type | |
| Relative Propagation Delay Delta | |
| Relative Propagation Delay Path Type | |
| Relative Propagation Delay Scope | |
| E – L | LayerSets |
| Max Exposed Length | |
| Total Etch Length Max | |
| Total Etch Length Min | |
| E – P | Parallelism |
| E – S | MaxStub Length |
| E – T | VerifySchedule |
| E – V | MaxVia Count |
| E – X | ActiveWindow |
| Max Xtalk | |
| Max Peak Xtalk | |
| Sensitive Window | |
| Maximum Inter Crosstalk | |
| Maximum Intra Crosstalk | |
| F – C | Bondfinger to component |
| Bond Pad to Component Edge | |
| Bond Finger to cavity edge | |
| F – F | BondPad to Bond Pad (same net) |
| Bond Pad to Bond Pad (different net) | |
| I – M | Single-lineImpedance Target and Tolerance |
| J – N | AllowTs |
| K – B | BondPad to Route Keepin |
| Bond Pad to Route Keepout | |
| Bond Pad to Via Keepout | |
| K – C | Packageto place keepin |
| Package to place keepout | |
| K – L | Lineto Route Keepin |
| Line to Route Keepout | |
| K – P | ThruPin to Route Keepin |
| Thru Pin to Route Keepout | |
| SMD to Route Keepin | |
| SMD to Route Keepout | |
| Test Pin to Route Keepin | |
| Test Pin to Route Keepout | |
| Test Pin to No Probe | |
| K – S | Shapeto Route Keepin |
| Shape to Route Keepout | |
| K – V | Viato Route Keepin |
| Via to Route Keepout | |
| Via to Via Keepout | |
| BB Via to Route Keepin | |
| BB Via to Route Keepout | |
| BB Via to Via Keepout | |
| Test Via to Route Keepin | |
| Test Via to Route Keepout | |
| Test Via to Via Keepout | |
| Test Via to No Probe | |
| L – L | Lineto Line |
| L – S | Shapeto Line |
| L – W | LineWidth Max |
| Line Width Min | |
| Neck Max Length | |
| Neck Min Width | |
| M – A | Soldermaskalignment |
| Pad Soldermask Alignment | |
| Symbol Soldermask Alignment | |
| M – C | SymbolSoldermask to Pad Soldermask |
| Minimum Cavity Size | |
| M – L | Soldermaskto pad and cline |
| M – M | PadSoldermask to Pad Soldermask |
| Any Metal to Any Metal Spacing | |
| M – P | Soldermaskto Pin |
| M – S | Soldermaskto shape |
| M – V | Soldermaskto Via |
| Matched Via count violation | |
| N – S | NegativePlane to Sliver |
| O – C | Objectexposure to cavity |
| P – B | BondPad to SMD Pin |
| Bond Pad to Test Pin | |
| Bond Pad to Thru Pin | |
| P – D | MechanicalPin Antipad to Drill Hole |
| P – L | Lineto SMD Pin |
| Line to Test Pin | |
| Line to Thru Pin | |
| Mechanical Pin Antipad to Cline | |
| P – M | Pastemaskpad to pastemask pad |
| Pastemask to package pastemask | |
| P – P | SMDPin to SMD Pin |
| SMD Pin to Test Pin | |
| Test Pin to Test Pin | |
| Thru Pin to SMD Pin | |
| Thru Pin to Test Pin | |
| Thru Pin to Thru Pin | |
| Mechanical Pin Antipad to Pin | |
| P – S | Shapeto SMD Pin |
| Shape to Test Pin | |
| Shape to Thru Pin | |
| Mechanical Pin Antipad to Shape | |
| P – V | SMDPin to BB Via |
| SMD Pin to Test Via | |
| SMD Pin to Thru Via | |
| Test Pin to BB Via | |
| Test Pin to Test Via | |
| Test Pin to Thru Via | |
| Thru Pin to BB Via | |
| Thru Pin to Test Via | |
| Thru Pin to Thru Via | |
| Mechanical Pin Antipad to Via | |
| R – C | Packageto room |
| S – N | AllowEtch |
| S – S | Shapeto Shape |
| T – C | Testpointloc. to component |
| Testpoint pad to component | |
| Testpoint under component | |
| V – B | BondPad to BB Via |
| Bond Pad to Test Via | |
| Bond Pad to Thru Via | |
| V – G | AllowPad-Pad Connect |
| BB Via Stagger Max | |
| BB Via Stagger Min | |
| Min BB Via Gap | |
| V – L | Lineto BB Via |
| Line to Test Via | |
| Line to Thru Via | |
| V – N | Vias |
| Vialist constraint violation | |
| V – S | Shapeto BB Via |
| Shape to Test Via | |
| Shape to Thru Via | |
| V – V | BBVia to BB Via |
| BB Via to Test Via | |
| Test Via to Test Via | |
| Thru Via to BB Via | |
| Thru Via to Test Via | |
| Thru Via to Thru Via | |
| W – A | Min.bonding wire length |
| Wire to die edge angle | |
| W – D | Bondingwire diameter |
| W – C | Wireto Cavity Edge Spacing |
| Wire End to Cavity Edge Spacing | |
| W – E | Wireend to wire end |
| W – F | Wireto bond finger |
| W – I | Max.bonding wire length |
| W – P | Wireto pin |
| W – W | Wireto wire (same profile) |
| W – X | Wireto wire (different profile) |
| X – D | ExternallyDetermined Violation |
[free]
回 tz小智 的帖子
tz小智: (2024-01-23 09:15) images/back.gif回 tz小智 的帖子
