黑金AX4010 FPGA开发板流水灯例程 EP4CE10F17C8
`timescale 1ns / 1psmodule LED
input clk, // system clock 50Mhz on board
input rst_n, // reset ,low active
output reg led // LED,use for control the LED signal on board
//define the time counter
reg timer;
// cycle counter:from 0 to 4 sec
always@(posedge clk or negedge rst_n)
begin
if (rst_n == 1'b0)
timer <= 32'd0; //when the reset signal valid,time counter clearing
else if (timer == 32'd199_999_999) //4 seconds count(50M*4-1=199999999)
timer <= 32'd0; //count done,clearing the time counter
else
timer <= timer + 32'd1; //timer counter = timer counter + 1
end
// LED control
begin
if (rst_n == 1'b0)
led <= 4'b0000; //when the reset signal active
else if (timer == 32'd49_999_999) //time counter count to 1st sec,LED1 lighten
led <= 4'b0001;
else if (timer == 32'd99_999_999) //time counter count to 2nd sec,LED2 lighten
led <= 4'b0010;
else if (timer == 32'd149_999_999) //time counter count to 3rd sec,LED3 lighten
led <= 4'b0100;
else if (timer == 32'd199_999_999) //time counter count to 4th sec,LED4 lighten
led <= 4'b1000;
end
endmodule 666666
