armclub 发表于 2024-7-26 16:24
ESP32-C3 做的一个物联网远程WIFI无线开关控制器PCB文件
ANT1PCB_ANT_MINI-ANT-TYPEB_PCB_ANTPCB_ANTMINI-ANT-TYPEB
C1CAP_C0402_15PF15pFC0402
C2CAP_C0402_15PF15pFC0402
C3CAP_C0402_1UF1uFC0402
C4CAP_C0402_10NF10nFC0402
C5CAP_C0402_10UF10uFC0402
C6CAP_C0402_0.1UF0.1uFC0402
C7CAP_C0402_0.1UF0.1uFC0402
C8CAP_C0402_TBDTBDC0402
C9CAP_C0402_TBDTBDC0402
C10CAP_C0402_0.1UF0.1uFC0402
C11CAP_C0402_1UF1uFC0402
C12CAPNP_C0402_1UF 16V1uF16VC0402
C13CAP_C0402_0.1UF0.1uFC0402
C14CAP-2.2UF-400V-8*10_CAP8-12_4.7UF-400V4.7uF-400VCAP8-12
C15C0603_0_C0603_1UF/16V1uF/16VC0603
C16CAP-2.2UF-400V-8*10_CAP8-12_680UF_16V680uF_16VCAP8-12
C22C0603_0_C0603_0.1UF-25V0.1uF-25VC0603
C23C0603_0_C0603_10UF-25V10uF-25VC0603
C24C0603_0_C0603_10UF-25V10uF-25VC0603
CX1CAP_X2_CAP_13MM_0.1UF/275V0.1uF/275VX2_CAP_13MM
D1DIODEBI-DIR TRIG_SOD-523_PESD3V3S1BA-NPESD3V3S1BA-NSOD-523
D2DIODE_0_SOD123_DIODEDiodeSOD123
D3DIO-1N4148-SOD123F_0_DO-214AC_A7A7DO-214AC
D4DIO-1N4148-SOD123F_0_DO-214AC_A7A7DO-214AC
D5LED-4-RG-0805_LED_0805_4P_IC_RG-0805RG-0805LED_0805_4P
D6BZX84C24/SOT_0_SOD123_BZT52C3V3BZT52C3V3SOD123
D7DIO-1N4148-SOD123F_0_DO-214AC_A7A7DO-214AC
D8DIO-1N4148-SOD123F_0_DO-214AC_A7A7DO-214AC
D9DIO-1N4148-SOD123F_0_SOD123_ES2J/SMAES2J/SMASOD123
D10DIO-1N4148-SOD123F_0_SOD123_A7A7SOD123
D11LED2_0_LED0805_REDREDLED0805
J1CON6_HDR_TH_6P_100_VE_CON6CON6HDR_TH_6P_100_VE
J2HEADER1_HOLE-1_5MM_HEADER 1HEADER1HOLE-1_5MM
J4HEADER1_HOLE-1_5MM_HEADER 1HEADER1HOLE-1_5MM
J5HEADER1_HOLE-1_5MM_HEADER 1HEADER1HOLE-1_5MM
J6HEADER1_HOLE-1_5MM_HEADER 1HEADER1HOLE-1_5MM
L1INDUCTOR_L0402_2.0NH2.0nHL0402
L2INDUCTOR_L0402_TBDTBDL0402
L3IND-2.2UH-0805_INDR9-12_150UH150uHINDR9-12
Q1A44NPN_SOT23-3_90139013SOT23-3
Q2NPN_SOT23-3_IC_80508050SOT23-3
Q3NPN_SOT23-3_IC_80508050SOT23-3
R1RESISTOR_0_R0402_00R0402
R2RESISTOR_0_R0402_499499R0402
R3RES_R0402_10K10KR0402
R4RES_R0402_10K10KR0402
R5RES_R0402_10K10KR0402
R6RES_R0402_10K10KR0402
R7RES_R0603_4.7K5%4.7K5%R0603
R8RES_R0603_10K5%10K5%R0603
R9RES_R1206_0.4R0.4RR1206
R10RES_R1206_1.5K1.5KR1206
R11RES_R1206_0.4R0.4RR1206
R12RES_R0402_1K1KR0402
R13R1005_0_R0402_560R-5%560R-5%R0402
R14RES_RES_TH_3_VE_10R10RRES_TH_3_VE
R15RES_R0402_1K1KR0402
R16RES_R0402_1K1KR0402
R17R1005_0_R0402_3K-5%3K-5%R0402
REL1RELAY_HF3FF_HF3FFHF3FFHF3FF
RT1MOV-14D471_RES_TH_5_RO_7D4717D471RES_TH_5_RO
U1X1_1_XTAL3225_40MHZ(10PPM)40MHz(10ppm)XTAL3225
U2ESP32-C3_QFN_32_EP5X5_ESP32-C3ESP32-C3QFN_32_EP5X5
U3CHIP-BP2525F_SOT33_5A_BP2525FBP2525FSOT33_5A
U4LM111733_SOT223_AMS111733AMS111733SOT223
一剑开天门 发表于 2024-7-27 09:16
lf2k2022 发表于 2024-7-27 14:43
xiuyaa 发表于 2024-12-16 15:51
原理图带吗
ctk1314520 发表于 2025-2-1 13:02
好资料,学习学习!
east_genie 发表于 2026-5-27 18:07
感谢分享!
zblin1987 发表于 2026-5-28 08:44
:lol
qq724058972 发表于 2026-5-28 08:48
east_genie 发表于 2026-5-28 20:15
感谢分享!
wangbin88 发表于 2026-5-29 06:33
谢谢分享
查看完整版本: ESP32-C3 做的一个物联网远程WIFI无线开关控制器PCB文件
