老吴 发表于 2024-11-26 15:58
TI TDA4VM88TGBALFR+LPDDR4_X32 BeagleBone_AI-64_Rev_B1 PCB 文件
PCB文件。回复可见
**** Hidden Message *****
D1DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D2DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D3DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D4DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D5ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D6TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D7BZX84C6V8LT1G_SOT23_6.8V6.8VSOT23
D8TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D9TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D10TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D11TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D12TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D13ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D14ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D15ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D16ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D17ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D18ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D19DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D20D_DO_214AC_SMA_B130L-13-FB130L-13-FDO_214AC_SMA
D21D_DO_214AC_SMA_B130L-13-FB130L-13-FDO_214AC_SMA
D22DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D36TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D37TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D38TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D39TPD1E05U06DPY_D0402_1C2A_TPD1E0TPD1E05U06DPYRD0402_1C2A
D40ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D41D_SCHOTTKY_SOD_323_PMEG3010CEJPMEG3010CEJSOD_323
D42ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D43ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D44ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D45ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D46ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D47ESD122DMX_X2SON3_0D3_0_6X1X0_4MESD122DMXRX2SON3_0D3_0_6X1X0_4MM
D48DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D49DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
D50D_SCHOTTKY_SOD_323_PMEG3010CEJPMEG3010CEJSOD_323
D51D_SCHOTTKY_SOD_323_PMEG3010CEJPMEG3010CEJSOD_323
D52DIODETVS BI-DIR_D0402_TPD1E1B0TPD1E1B04DPYRD0402
J1HEADER_4+2P_HEADER4_2P_1D25_SMDHeader4P 1.25MMHEADER4_2P_1D25_SMD_10X5_3X3_6MM
J2SIP3_CON3B35X60_B3B-ZR(LF)(SN)B3B-ZR(LF)(SN)CON3B35X60
J3SIP3_CON3B35X60_B3B-ZR(LF)(SN)B3B-ZR(LF)(SN)CON3B35X60
J4PCIE_M.2_KEYE_75PIN_CON_MINIPEAS0BC27-S40BE-7HCON_MINIPEX_067_SMT_RA_M2_KEYE_C
J5USB3.0_TYPEC_24+4P_USB_MTCONN_UBF31-2347-1USB_MTCONN_UBF31-2347-1
J6POWERJACK_CONN3-PWR-DC630_DC63DC630-20D01CONN3-PWR-DC630
J7MINIDISPLAY PORT_20PIN_DP20_0D3VM11201-D730-7HDP20_0D6_9_8X11_8X5_9MM
J8USB3.0_DUALTYPE A_18+4P_USB3_1UAA111C-84161-4HUSB3_1_2D0_17_5X13_6X15_69MM
J9RJ45_LPJG0933HENL_RJ45_18P_LPJGLPJG0933HENLRJ45_18P_LPJG0801HBNL
J10HEADER2X8 1357_HEADER2X8_SMD_1Header2x8 1.27mmHEADER2X8_SMD_1D27
J11HEADER2X5_1_CONNECT10_1D27_12_TC2050-IDCCONNECT10_1D27_12_4X6_7MM
J12MICROSDCARD_10+4P_MICRO_SD_15XYL004-030-001MICRO_SD_15X14_3X1_8MM
J13FPC22+2P_FPC22_0D5_15_4X5_25X2FPC22P 0.5mmFPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB
J15FPC22+2P_FPC22_0D5_15_4X5_25X2FPC22P 0.5mmFPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB
J16FPC22+2P_FPC22_0D5_15_4X5_25X2FPC22P 0.5mmFPC22_0D5_15_4X5_25X2MM_0D5_DX_NPWB
L1CL_L2012_90R90RL2012
L2L_L7572_XAL7070_1.8UH1.8uHL7572_XAL7070
LED5SINGLELED_LED0603_GREENGreenLED0603
LED6SINGLELED_LED0603_GREENGreenLED0603
MH1MHOLE_MTGH200C125D_PL_HOLE3.17Hole3.175MMMTGH200C125D_PL
MH2MHOLE_MTGH200C125D_PL_HOLE3.17Hole3.175MMMTGH200C125D_PL
MH3MHOLE_MTGH200C125D_PL_HOLE3.17Hole3.175MMMTGH200C125D_PL
MH4MHOLE_PTH_4_45MM_6D5_SMSR3066MTSMSR3066MTJPTH_4_45MM_6D5
MH5MHOLE_PTH_4_45MM_6D5_SMSR3066MTSMSR3066MTJPTH_4_45MM_6D5
MH6MHOLE_PTH_4_45MM_6D5_SMSR3066MTSMSR3066MTJPTH_4_45MM_6D5
MH7MHOLE_PTH_4_45MM_6D5_SMSR3066MTSMSR3066MTJPTH_4_45MM_6D5
MH8MHOLE_PTH_4_2MM_5D8_2E0BC21-A402E0BC21-A40TP-7HPTH_4_2MM_5D8
MH9MHOLE_MTGH200C125D_PL_HOLE3.17Hole3.175MMMTGH200C125D_PL
P8HEADER2X23_HEADER2X23P_2D54_SMHeader2x23 2.54mmHEADER2X23P_2D54_SMD_PTH
P9HEADER2X25_SPE_HEADER2X25P_2D5Header2x25 2.54mmHEADER2X25P_2D54_SMD_PTH
Q1PMOS_123_SOT23_IRLML6402TRPBFIRLML6402TRPBFSOT23
Q2NMOS_5P_1S2S3S4G5D_VSON8_0D65_3CSD17575Q3VSON8_0D65_3_3X3_3X1MM
Q3NMOS_5P_1S2S3S4G5D_VSON8_0D65_1CSD17308Q3VSON8_0D65_3_3X3_3X1MM
Q4NMOS_123_SOT-323-3_BSS138WBSS138WSOT-323-3
Q5NMOS_123_SOT-323-3_BSS138WBSS138WSOT-323-3
Q6NMOS_123_SOT-323-3_BSS138WBSS138WSOT-323-3
U1TPS2121_VQFN12_0D5_2X2_5X1MM_TPTPS2121RUXRVQFN12_0D5_2X2_5X1MM
U2TXS0104E_QFN14_0D5_3_5X3_5X1MM_TXS0104ERGYRQFN14_0D5_3_5X3_5X1MM
U3LM5141RGE_VQFN24_0D5_4X4X1MM_LMLM5141RGERVQFN24_0D5_4X4X1MM
U4TPS2561_VSON10_0D5_3X3X1MM_TPS2TPS2561DRCRVSON10_0D5_3X3X1MM
U5TPS22918DBV_SOT23_6_TPS22918DBVTPS22918DBVRSOT23_6
U6SN74LVC1G08DCKR_DCK5_2P15X1P4_SSN74LVC1G08DCKRDCK5_2P15X1P4
U7MEM_24LC32_SOT23-5_SOT23-5_24FC24FC04HT-I/OTSOT23-5
U8MAX6817EUT_SOT23_6_MAX6817EUT+TMAX6817EUT+TSOT23_6
U9TPS74801DRCR_VSON10_0D5_3X3X1MMTPS74801DRCRVSON10_0D5_3X3X1MM
U10TPS3808G33DBV_SOT23_6_TPS3808G3TPS3808G33DBVRSOT23_6
U11SN74LVC1G07DCK_DCK5_2P15X1P4_SNSN74LVC1G07DCKRDCK5_2P15X1P4
U12SN74LVC1G07DCK_DCK5_2P15X1P4_SNSN74LVC1G07DCKRDCK5_2P15X1P4
U13TPD4E05U06DQAR_USON10_0D5_2D5X1TPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U14SN74LVC2G74_SO8_0D5_2_3X2X0_9MMSN74LVC2G74DCURSO8_0D5_2_3X2X0_9MM
U15DP83867CRRGZ_QFN48_0D5_7X7MM_DPDP83867CRRGZRQFN48_0D5_7X7MM
U16SN74LVC1G08DCKR_DCK5_2P15X1P4_SSN74LVC1G08DCKRDCK5_2P15X1P4
U17TPD4E05U06DQAR_USON10_0D5_2D5X1TPD4E05U06DQARUSON10_0D5_2D5X1X0D5MM
U18TPS74801DRCR_VSON10_0D5_3X3X1MMTPS74801DRCRVSON10_0D5_3X3X1MM
U19TDA4VM_FCBGA827_0D8_24X24X2_8MMTDA4VM88TGBALFRFCBGA827_0D8_24X24X2_8MM
U20TUSB8041_QFN64_0D5_9X9X1MM_TUSBTUSB8041RGCRQFN64_0D5_9X9X1MM
U21TUSB322IRWBR_X2QFN12_0D4_1_6X1_TUSB322IRWBRX2QFN12_0D4_1_6X1_6X0_4MM
U22TPS2553DBV_SOT23_6_TPS2553DBVRTPS2553DBVRSOT23_6
U23TPS22965DSG_WSON8_0D5_2X2X0_8MMTPS22965DSGRWSON8_0D5_2X2X0_8MM
U24SN74AUP1T17DCKR_SC70_5_SN74LVC1SN74LVC1G17DCKRSC70_5
U25LPDDR4_X32_VFBGA200_BGA200_0D65Q3222PM1WDGTK-UBGA200_0D65_15X10X1MM
U26EMMC_5_1_153-BALL_WFBGA_BGA153_EMMC16G-TB29-PZ90BGA153_P14_P5_11P5X13
U27SN74LVC1G07DCK_DCK5_2P15X1P4_SNSN74LVC1G07DCKRDCK5_2P15X1P4
U28TPS62813-Q1_VQFNHR9_0D55_3X2X1MTPS62813QWRWYRQ1VQFNHR9_0D55_3X2X1MM
U29TPS65941-Q1_VQFN56_0D5_8X8X0_9MTPS65941111RWERQ1VQFN56_0D5_8X8X0_9MM
U30TPS65941-Q1_VQFN56_0D5_8X8X0__1TPS65941213RWERQ1VQFN56_0D5_8X8X0_9MM
U31SN74LVC2G241_U_8_DCU_SN74LVC2G2SN74LVC2G241DCURU_8_DCU
U32TXS0108E_VQFN-20_TXB0108RGYRTXB0108RGYRVQFN-20
U33SN74LVC2G241_U_8_DCU_SN74LVC2G2SN74LVC2G241DCURU_8_DCU
U34SN74CBTLV1G125DBVR_SOT23-5_SN74SN74CBTLV1G125DBVRSOT23-5
X1XTAL_4P_X4_SMD_2_5X2_0MM_25MHZ25MHz18pFX4_SMD_2_5X2_0MM
X2XTAL_4P_X4_SMD_2_5X2_0MM_19.20019.2000MHz8PFX4_SMD_2_5X2_0MM
X3XTAL_4P_X4_SMD_2_5X2_0MM_22.57922.5792MHz8PFX4_SMD_2_5X2_0MM
X4XTAL_4P_X4-SMD-3_2X2_5X1_0MM_2424MHz18pFX4-SMD-3_2X2_5X1_0MM
X5XTAL_2P_X2_SMD_3_2X1_5MM_32.76832.768kHz12.5pFX2_SMD_3_2X1_5MM
maoquantum 发表于 2024-11-26 18:23
hello, i want to study it !
zheshiwo 发表于 2024-11-26 22:32
谢谢分享!
小小路人甲 发表于 2024-11-27 08:43
muyi270920 发表于 2024-11-27 08:46
lf2k2022 发表于 2024-11-27 09:20
shuszhao 发表于 2024-11-27 09:47
老吴出品,必属精品
kerry 发表于 2024-11-27 09:56
学习学习
kingweison 发表于 2024-11-27 11:13
学习学习
周永峰 发表于 2024-11-27 11:45
666666666666666
页: [1] 2 3
查看完整版本: TI TDA4VM88TGBALFR+LPDDR4_X32 BeagleBone_AI-64_Rev_B1 PCB 文件
