MTK6762(MT6762) 10层2介盲埋孔智能手持终端机PCB和原理图
NamePart TypePCB DecalValue
ANT1ANTENNA_11P-JS-TTB25ANT / 92138100010F
ANT2POGO_2_2MM_0_5MMPOGO_2_2MM_0_5MMANT / 92138100010F/ NC
ANT3POGO_2_2MM_0_5MMPOGO_2_2MM_0_5MMANT / 92138100010F/ NC
ANT4POGO_2_2MM_0_5MMPOGO_2_2MM_0_5MMANT / 92138100010F/ NC
ANT9ANTENNA_11ANTENNA_11ANT / 92138100010F
ANT10ANTENNA_11ANTENNA_11ANT / 92138100010F
ANT11ANTENNA_11ANTENNA_11ANT / 92138100010F
ANT12ANTENNA_11ANTENNA_11ANT / 92138100010F
ANT13POGO_2_2MM_0_5MMPOGO_2_2MM_0_5MMANT / 92138100010F/ NC
ANT5002ANTENNA_11ANTENNA_11ANT / 92138100010F
B4701BED-0402-1K04021K@100M
B5101RES-0402-4K704020R
B5102RES-0402-4K704020R
C9009C0402-4.7UFC0402-4.7UF4.7uF / 6.3V
CON2SMT_2P_0_8MMSMT_0_8MM_2PSMTH_2P_1_25MM
CON4SMT_2P_0_8MMSMT_0_8MM_2PSMTH_2P_1_25MM
D1DS520-30LED02WBFBP-02CPMEG3005EJ
D2103D_PZ3D4V2HD_PZ3D4V2HZener_5.1V
D2201DS520-30LED02WBFBP-02CPMEG3005EJ
D4601DS520-30LED02WBFBP-02CPMEG3005EJ
E4910EXC14CE900UEXC14CE900UEXC14CE900U
F4701TRPX_/_TP2012-A1255DAT/LFFILTER/SMD/LFD211G57ME3F09-TP2012A1255DAT
FB5BEAD_0603B0603BLM18PG300SN1
FB6BEAD_0603B0603BLM18PG300SN1
HOLE1PTH1.4TP30MIL
HOLE2TP1.9TP3.502/1.905BAA
HOLE3TP1.9TP3.502/1.905BAAA
HOLE4TP1.9TP3.502/1.905BAC
HOLE5TP1.9TP3.502/1.905
HOLE8TP1.9TP3.502/1.905BAB
HOLE9TP1.9TP3.502/1.905BAD
J1SMD_RF_CABLESDM_RF_CABL_CUP
J2SMT_1MM_18PSMT_1M_18PBAR_SCAN
J4BTB-03F030-04BTB-03F030-04ABTB-OK-03F030-04
J5OK-06F060-40BTB-OK-06F060-04CON / 30 / 24-5804-030-000-829+
J6BAR_SCANBAR_SCANBAR_SCAN
J7MAIN_BAT_3MMMAIN_BAT_3MMMAIN-BAT
J8TPY5B-6P-SMTTP
J9TPY5B-6P-SMTTP
J10TPY5B-6P-SMTTP
J11SMD_RF_CABLESDM_RF_CABL_CUP
J12TPY5B-6P-SMTTP
J13MAIN_BAT_3MMMAIN_BAT_3MMMAIN-BAT
J14BAR_SCANBAR_SCANBAR_SCAN
J15SMT_1_25MM_5P_HSMT_1_25MM_5P_HSMTH_4P_1_25MM
J1620369C320369C3
J17FH26-27S-0.3SHWAFH26-27S-0.3SHWAFH26S-025
J18SMT_1_25MM_5P_HSMT_1_25MM_5P_HSMTH_4P_1_25MM
J19SMD_RF_CABLESDM_RF_CABL_CUP
J21SMT_1_25MM_7P_HSMT_1_25MM_7PSMTH_4P_1_25MM
J145FH26-39SFH26-39S-0_3SHWFH26S-039
J1701BTB-03F030-04BTB-03F030-04BBTB-OK-03F030-04
J5401CON-RF-SWITCH-MM8030CON-RF-SWITCH-MM8030
J540220369C320369C3
J5501CON-RF-SWITCH-MM8030CON-RF-SWITCH-MM8030
L1FERRITE_BEAD_SMD_0402L/IND/SMD/0603L / 160 / nH / 0603
L2FERRITE_BEAD_SMD_0402L/IND/SMD/0603L / 160 / nH / 0603
L3L_/_MDMK2020T1R0MM_/_SMD2520L/IND/SMD/2520PL / 2.2 / uH / 2520
L5PL_/_1_/_UH_/_2520L/IND/SMD/DFE252010F1uH
L6IND0201P_4.3NHIND0201NC
L7IND0201_NCIND0201NC
L15L_/_MDMK2020T1R0MM_/_SMD2520L/IND/SMD/2520PL / 2.2 / uH / 2520
L307BB0402BLM15BB750SN1
L308BB0402BLM15BB750SN1
L1300SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02SL02015.6NH
L1303SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02SL02016.8NH
L1309SL0201-3.9NH-+/-0.3NH-SDCL0603Q3N9ST02SL02013.9NH
L1312SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02SL02012.7NH
L1315SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02SL02013.3NH
L1318SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02SL02012.7NH
L1321SL0201-2.2NH-+/-0.3NH-SDCL0603Q2N2ST02SL02012.2NH
L1324SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1326SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1327SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1330SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1331SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1332SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02SL02016.2NH
L1334SL0201-10NH-+/-5%-SDCL0603Q10NJT02SL020110NH
L1335SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1338SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1340SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1341SL0201-7.5NH-+/-5%-SDCL0603Q7N5JT02L02017.5NH
L1343SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02SL02016.8NH
L1344SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1354SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1411SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1412SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1420SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1426SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L1429SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02SL02016.2NH
L1431SL0201-33NH-+/-5%-SDCL0603Q33NJT02SL020133NH
L1432SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L1433SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02SL02011.8NH
L1438SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02SL02014.3NH
L1441SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02SL02015.6NH
L1442SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1444SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02SL02013.3NH
L1445SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1446SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02SL02016.2NH
L1447SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02SL02014.3NH
L1448SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1449SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1450SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1453SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02SL02014.3NH
L1454SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1456SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02SL02013.3NH
L1458SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02SL02015.1NH
L1459SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1460SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1461SL0201-6.2NH-+/-0.3NH-SDCL0603Q6N2ST02SL02016.2NH
L1462SL0201-2.7NH-+/-0.3NH-SDCL0603Q2N7ST02SL02012.7NH
L1464SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1465SL0201-5.6NH-+/-0.3NH-SDCL0603Q5N6ST02SL02015.6NH
L1466SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1468SL0201-3.0NH-+/-0.3NH-SDCL0603Q3N0ST02SL02013.0NH
L1469SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02SL02011.8NH
L1471SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02SL02016.8NH
L1472SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02SL02014.3NH
L1473SL0201-27NH-+/-5%-SDCL0603Q27NJT02SL020127NH
L1474SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L1508SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1511SL0201-NCSL0201NC
L1513SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1514SL0201-NCSL0201NC
L1515SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1516SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1517SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02SL02013.3NH
L1519SL0201-NCSL0201NC
L1521SL0201-NCSL0201NC
L1522SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L1523SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1524SL0201-NCSL0201NC
L1531SL0201-8.2NH-+/-5%-SDCL0603Q8N2JT02SL02018.2NH
L1532SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1533SL0201-4.7NH-+/-0.3NH-SDCL0603Q4N7ST02SL02014.7NH
L1538SL0201-NCSL0201NC
L1539SL0201-NCSL0201NC
L1540SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1542SL0201-4.7NH-+/-0.3NH-SDCL0603Q4N7ST02SL02014.7NH
L1544SL0201-NCSL0201NC
L1545SL0201-NCSL0201NC
L1548SL0201-4.3NH-+/-0.3NH-SDCL0603Q4N3ST02SL02014.3NH
L1550SL0201-NCSL0201NC
L1551SL0201-NCSL0201NC
L1552SL0201-1.5NH-+/-0.3NH-SDCL0603Q1N5ST02SL02011.5NH
L1554SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02SL02015.1NH
L1558SL0201-2.2NH-+/-0.3NH-SDCL0603Q2N2ST02SL02012.2NH
L1560SL0201-5.1NH-+/-0.3NH-SDCL0603Q5N1ST02SL02015.1NH
L1561SL0201-1.8NH-+/-0.3NH-SDCL0603Q1N8ST02SL02011.8NH
L1565SL0201-3.3NH-+/-0.3NH-SDCL0603Q3N3ST02SL02013.3NH
L1570SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L1573SL0201-2.4NH-+/-0.3NH-SDCL0603Q2N4ST02SL02012.4NH
L1578SL0201-15NH-+/-5%-SDCL0603Q15NJT02SL020115NH
L3218L_/_3.4_/_NH_/_0201IND02013.4nH 450 mA
L3219L_/_9.1_/_NH_/_0201C02019.1nH 250 mA
L3222L_/_4.7_/_NH_/_0201C02014.7nH 350 mA
L4601PL_/_10_/_UH_/_2520L/IND/SMD/CIGT252012LMR47MNE10uH/ 252000
L4602PL_/_2.2_/_UH_/_2520L/IND/SMD/DFE252010F2.2uH/252010
L4611IND0201P_4.3NHIND02015.6nH
L4701IND0201_NCIND0201NC
L4702IND0201P_4.3NHIND02019.1nH
L4703IND0201P_4.3NHIND0201NC
L4704IND0201_NCIND02018.2nH
L4705IND0201P_4.3NHIND02011.4nH
L4706IND0201_NCIND0201NC
L4707IND0201_NCIND0201NC
L4708IND0201P_4.3NHIND020182nH
L4709IND0201P_4.3NHIND020156nH
L4710IND0201P_4.3NHIND0201NC
L4711IND0201_NCIND0201NC
L5434IND0201P_4.3NHIND02013.3nH
L5435IND0201P_4.3NHIND0201NC
L5436IND0201P_4.3NHIND0201NC
L5437IND0201P_4.3NHIND02011nH
L5438IND0201P_4.3NHIND020147nH
L5439IND0201P_4.3NHIND0201NC
L5501IND0201P_4.3NHIND0201NC
L5502IND0201P_4.3NHIND0201NC
L5526IND0201P_4.3NHIND0201NC
L6202L_/_LQM18NN82NM00402L / LQM18NN82NM00
M1306SL0201-6.8NH-+/-5%-SDCL0603Q6N8JT02SL02016.8NH
M1307SC0201-NC-+/-0.25PF-25VSC0201NC
M1308SC0201-1.8PF-+/-0.25PF-25VSC02011.8PF
MOTO2BAT-PADBAT/SMD/XH414HG-IV01EVIBRATOR
NTC1301RES-NTC-47K-0402R0402NTC-100K
NTC1302RES-NTC-47K-0402R0402NTC--100K
PL1L_SMD8085SMD8085PL / 1.5 / uH /8.0*8.5*3.0
PL2001L/IND/SMD/CIGT252012LMR47MNEL/IND/SMD/CIGT252012LMR47MNEPL / 0.47 / uH
PL2002L/IND/SMD/CIGT252012LMR47MNEL/IND/SMD/CIGT252012LMR47MNEPL / 0.47 / uH
PL2003L/IND/SMD/MEMK2520L/IND/SMD/MEMK2520PL / 1 / uH
PL2004L/IND/SMD/MEKK2016L/IND/SMD/MEKK2016PL / 1 / uH
PL2006L/IND/SMD/MEMK2520L/IND/SMD/MEMK2520PL / 1 / uH
PL2801L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.33 / uH
PL2802L/IND/SMD/VLS201610EL/IND/SMD/VLS201610EPL / 0.33 / uH
PL2803PL_/_1_/_UH_/_2016L/IND/SMD/VLS201610E1uH /2016
Q4MMBT3904SOT-7233904
Q5MMBT3904SOT-7233904
Q9MMBT3904SOT-7233904
Q12MMBT3904MSOT-723MMBT3904M
Q141PNP-SOT-723SOT-723S9012
R14155SR0201-NC-5%-1/20WSR0201NC
SH2NC/MMD/10MILNC/MMD/L1/10MILSHORT / 10MIL
SW1MARKMARKNC
SW2MARKMARKNC
SW3MARKMARKNC
SW4MARKMARKNC
T4501ESD_/_AZ5825-01FVR0402ESD / AZ5825-01F
T4502TVS_0402TVS_0402M1005C080MTAAB
T5106ESD_/_AZ5885-01F.R7GRESD/2P/P0.85/SMD/AZ5885-01F/MTK0760
TP9905TP30TP30TP / 30 / mil
TV3TVS_0402TVS_0402M1005C080MTAAB
TV4TVS_0402TVS_0402M1005C080MTAAB
TV5TVS_0402TVS_0402M1005C080MTAAB
TV6TVS_0402TVS_0402M1005C080MTAAB
TV9TVS_0402TVS_0402M1005C080MTAAB
TV10TVS_0402TVS_0402M1005C080MTAAB
TV1905TVS_0402TVS_0402M1005C080MTAAB
TV1907TVS_0402TVS_0402M1005C080MTAAB
TV1908TVS_0402TVS_0402M1005C080MTAAB
TV1909TVS_0402TVS_0402M1005C080MTAAB
TV1910TVS_0402TVS_0402M1005C080MTAAB
U1TXB0104RUTRUQFN_12TXB0104RUTR
U2TXB0104RUTRUQFN_12TXB0104RUTR
U4WK2132VSSOP16
U5PN553VFBGA64_PN553
U7RT9080ZQFN-4L
U8RT9080ZQFN-4L
U9RT9080ZQFN-4L
U10TPS61088VQFN20L
U13BS3406ADJ/RT8096CSOT_25BS3406ADJ/RT8096C
U14RT9080ZQFN-4L
U15RT9080ZQFN-4L
U16RT9080ZQFN-4L
U17SGM66052SGM66052
U22CJM1216DFNWB2X2-6LAP4435GM
U23PCA9306S-PDSO-G8PCA9306DC1
U143AP4435GMSOP-8_208MILAP4435GM
U902MT6631/WSQFN40/SMD/P0.4/5X5MT6631/WSQFN40/SMD/P0.4/5X5QFN40/MT6631N
U1001MT6762/VCPMT6762/VFBGA558/P0.4/B0.24/11.4X11.0U / MT6762
U1301LPF-4PIN-1608-RFBPF16081G9DM1T79LPF-4PIN-1608BF1608-L1R9NDC
U1302SAW-5P-1411-SFDG35AQ102SAW-5PIN-1109-UNBALANCESAFFB2G35MA0F0A
U1303SAW-5P-1411-SFDG26AQ102SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAFFB2G59MA3F0A
U1401SAW-8P-1814-SFX897BYF02DUPLEXER-8PIN-1814/2016SAYEY897MBA0B0A
U1402LPF-4PIN-1608-RFBPF16081G9DM1T79LPF-4PIN-1608RFBPF16081G9DM1T79
U1403SAW-8P-1814-SFX806BYH02DUPLEXER-8PIN-1814/2016SAYEY806MBA0F0A
U1404LPF-4PIN-0605-RFLPF06050G9D0TLPF-4PIN-0605RFLPF06050G9D0T
U1405SAW-8P-1814-SAYEY707MBA0F0ADUPLEXER-8PIN-1814/2016SAYEY707MBA0F0A
U1406IC-SP3T-SWITCH-VC1623-11RF1628RF1628A
U1407SAW-8P-1814-SFXG50CY902DUPLEXER-8PIN-1814/2016SAYRH1G95BA0F0A
U1408SAW-8P-1814-SFXG80AYM02DUPLEXER-8PIN-1814/2016SAYEY1G88BC0B0A
U1409SAW-8P-1814-SFXG47AYM02DUPLEXER-8PIN-1814/2016SAYEY1G74BC0B0A
U1410SAW-8P-1814-SAYEY1G73BA0F0AR05DUPLEXER-8PIN-1814/2016SAYEY1G73BA0F0AR05
U1411SAW-8P-1814-SFX836CYA02DUPLEXER-8PIN-1814/2016SAYEY836MBE0F0A
U1412SAW-8P-1814-SFXG35BYN02DUPLEXER-8PIN-1814/2016SAYEY2G53BC0F0A
U1501SAW-5P-1109-SFHG40AA002SAW-5PIN-1109-UNBALANCESAFFB2G14AA0F0A
U1502SAW-5P-1109-SFH942AA002SAW-5PIN-1109-UNBALANCESAFFB842MAN0F0A
U1503SAW-5P-1109-SFHG42AA002SAW-5PIN-1109-UNBALANCESAFFB1G84AB0F0A
U1505SAW-5P-1109-SAFFB2G65AA0F0ASAW-5PIN-1109-UNBALANCESAFFB2G65AA0F0A
U1506LPF-4PIN-1608-RFBPF16081G9DM1T79LPF-4PIN-1608LFB181G91CT9E361
U1507SAW-5P-1109-SFHG05AA002SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAFFB2G60AA0F0A
U1508SAW-5P-1109-SFHG52AA002SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAFFB2G35AA0F0A
U1509LPF-4PIN-0605-RFLPF06050G9D0TLPF-4PIN-0605RFLPF06050G9D0T
U1510SAW-5P-1109-SFH806BA002SAW-5PIN-1109-UNBALANCESAFFB806MAA0F0A
U1512SAW-5P-1109-SFH737AA002SAW-5PIN-1109-UNBALANCESAFFB737MAA0F0A
U2001MT6357/VFBGA209/P0.4/B0.25/7.0X6.6MT6357/VFBGA209/P0.4/B0.25/7.0X6.6U / MT6357CRV/A
U2801WLCSP15/P0.4/B0.25/RT5738WLCSP15/P0.4/B0.25/RT5738U / MT6691OOP/A
U2802WLCSP15/P0.4/B0.25/RT5738WLCSP15/P0.4/B0.25/RT5738U / MT6691OOP/A
U2803U_/_RT5784AGQWFDFN8/SMD/P0.5/RT5784A/SNC/RT5784AGQWF
U2806WL-CSP6/SMD/P0.4/RT9085AWL-CSP6/SMD/P0.4/RT9085AU / MT6680P/A
U2807MP20051QFN8_3X3NC/RT5784AGQWF
U2810UDFN4/SMD/P0.65/NCP114UDFN4/SMD/P0.65/NCP114U / NCP114AMX180TCG
U4001FBGA254/P0.5/B0.27/11.5X13/12X15FBGA254/P0.5/B0.27/11.5X13/12X15U / H9HP52ACPMMDAR-KMM
U4501U_/_MT6371P/ABA-HWLCSP93/P0.4/B0.25/RT5081
U4702SAFEB1G57KA0F00SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAFEB1G57KE0F00
U4703BGU7005TSLP6/SMD/P0.4/BGA725L6/SBGU7005
U4704SAW_SAFEA2G45MC0F0ASAWFILTER/5P/SMD/SAFFB2G14AA0F0AFBAR / ACPF-7124
U5101CPA2232CPA2232_QFN20CPA2232
U5200MT6177MV/BCA-HMT6177M/VFBGA120/P0.4/B0.25/5.0X4.6
U5300PA_/_SKY77590_4SKY77643
U5401ASM_/_SKY13492_7RF5210SKY77916-31
U5500SKY13418SKY13418SKY13418
U5700U_/_AK09918CWLCSP4/P0.4/B0.21/AK09918
U5703KXTJ2-1009KXTJ2-1009bosc
U5706IC_BMI120BST-BMI120-DS001-05BMA250
VR292TVS_0402TVS_0402M1005C080MTAAB
X1TXCO-3225TCXO3225X / 27.12 / MHz / FA-128 / NC
X2201TCVCXO_3TCXO/SMD/2.5X2.0/IT2205BE
X3701TCVCXO_14TCXO322514.7456MHz
Y4701OSC/4P/SMD/KT1612A-KT2016K/2-INOSC/4P/SMD/KT1612A-KT2016K/2-IN-1KT2520P26000ACW28TAA/NC
PCB文件和原理图来了。回复可见下载。
**** Hidden Message *****
:):):):):):):) 感谢分享··············· 谢谢分享,,,, :(:(:(:( :lol:lol:lol :lol:lol:lol:lol:lol:lol 想看资料
