新塘N3292x DevelopmentBoard 开发板PCB 原理图BOM GERBER等
BT1CR1220_CR1220_CR1220CR1220CR1220
CON1P35-157-P1Z9_ETH_P35-157-P1Z9P35-157-P1Z9ETH
CON2USB-MINI-B_MINIUSBB_USB-MINI-BUSB-MINI-BMINIUSBB
CON3HEADER32X2_254MM-64PIN-2_2.54M2.54mm-180D-32x2254MM-64PIN-2
CON4HEADER32X2_254MM-64PIN-2_2.54M2.54mm-180D-32x2254MM-64PIN-2
CON5HEADER30X2_200MM-60PIN-2_2.00M2.00mm-180D-30X2200MM-60PIN-2
CON6CONNRCPT 12X2/SM_200MM-24PIN-B2.00mm-180D-12X2200MM-24PIN-BT-NORMAL
CON7PANASONIC-STANDARD-SD_SD-SOCKETPanasonic-Standard-SDSD-SOCKET-PANASONIC-AUTO
CON8PANASONIC-STANDARD-SD_SD-SOCKETPanasonic-Standard-SDSD-SOCKET-PANASONIC-AUTO
CON9CON20_254MM-20PIN-2_2.54MM10X22.54MM10x2254MM-20PIN-2
CON10DSUB9M_DSUB9_DSUB9DSUB9DSUB9
CON11POWERJACK_POWERJACK_POWERJACKPowerJACKPOWERJACK
J1SW-BIT-3_SW-BIT-3_MIC_LINE-INMIC_LINE-INSW-BIT-3
J2CON2_254MM-2PIN-1_SPEAK8OHMSpeak8ohm254MM-2PIN-1
J3SW-BIT-S_SW-BIT_SW-BIT-SSW-BIT-SSW-BIT
J4SW-BIT-3_SW-BIT-3_CHANNELSELECChannelselectSW-BIT-3
J5CONNTRBLK 3_200MM-3PIN-1_2.00M2.00mm-1x3-Jump200MM-3PIN-1
J6SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J7SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J8SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J9SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J10SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J11SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J12SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J13SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J14SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J15SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J16SW-BIT-S_SW-BIT_EMAC-INTEMAC-INTSW-BIT
J17CON8A_200MM-8PIN-2_2.00MM-4X2J2.00mm-4x2Jump200MM-8PIN-2
J18SW-BIT_SW-BIT_WPWPSW-BIT
J19SW-BIT_SW-BIT_PREPRESW-BIT
J20SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J21SW-BIT-3_SW-BIT-3_SW-BIT-3SW-BIT-3SW-BIT-3
J22SW-BIT-S_SW-BIT_HOLDHOLDSW-BIT
J23SW-BIT-S_SW-BIT_SW-BIT-SSW-BIT-SSW-BIT
J24SW-BIT-S_SW-BIT_WPWPSW-BIT
J25CON12A_200MM-12PIN-2_2.00MM-6X22.00mm-6x2-Jump200MM-12PIN-2
J26SW-BIT-3_SW-BIT-3_RTC_POWERRTC_PowerSW-BIT-3
J27SW-BIT-S_SW-BIT_SW-BIT-SSW-BIT-SSW-BIT
J28SW-BIT-S_SW-BIT_SW-BIT-SSW-BIT-SSW-BIT
L1FB_0603L_FBFB0603L
L2FB_0603L_FBFB0603L
L3FB_0603L_FBFB0603L
L4FB_0603L_FBFB0603L
L5FB_0805L_FBFB0805L
L6FB_0805L_FBFB0805L
L7FB_0805L_FBFB0805L
L8INDUCTORFERRITE_1210L_2.2UH2.2uH1210L
L9INDUCTORFERRITE_1210L_2.2UH2.2uH1210L
L10INDUCTORFERRITE_1210L_2.2UH2.2uH1210L
L11FB_0805L_FBFB0805L
L12FB_0805L_FBFB0805L
L13FB_0402L_FBFB0402L
LED1LED_D0603_BLUE-0603Blue-0603D0603
LED2LED_D0603_YELLOW-0603Yellow-0603D0603
LED3LED_D0603_YELLOW-0603Yellow-0603D0603
LED4LED_D0603_RED-0603Red-0603D0603
LS1HEADPHONE-3_HEADPHONE-3_HEADPHOHeadPhone-3HEADPHONE-3
M1CON2_MIC-4MM_4MM-MICROPHONE4mm-MicrophoneMIC-4MM
Q12N9012_SOT23S_2N90122N9012SOT23S
Q2SI2301_SOT23S_SI2301SI2301SOT23S
Q3SI2301_SOT23S_SI2301SI2301SOT23S
S1KEY-M1_STS-035A_RESETRESETSTS-035A
S2KEY-M1_STS-035A_ON/OFFON/OFFSTS-035A
S3KEY-M1_STS-035A_CUT-OFF-POWERCut-Off-PowerSTS-035A
TP1TP_TPS_LINE-INLine-InTPS
TP2TP_TPS_AGNDAGNDTPS
TP3TP_TPS_SD2WPSD2WPTPS
U1ISD8101_SO8-150E_ISD8101ISD8101SO8-150E
U2APL3511A_SOT-23-5_APL3511AAPL3511ASOT-23-5
U3RTL8201F-QFN-32_QFN-32_RTL8201FRTL8201F-QFN-32QFN-32
U4W55FA92DDN_LQFP-128_W55FA92DDNW55FA92DDNLQFP-128
U5HY27US08121A_TSOP4805_HY27US081HY27US08121ATSOP4805
U6W25QXXX-16_SO16-300_W25QXXX-16W25QXXX-16SO16-300
U7W25XXX_SO8-208_W25XXXW25XXXSO8-208
U8ICL-232E_ICL232_ICL-232EICL-232EICL232
U9APL3203_TDFN-8_APL3203APL3203TDFN-8
U10APW7176_TDFN-10_APW7176APW7176TDFN-10
U11APW7102_SOT-23-5_APW7102APW7102SOT-23-5
U12APL5537_SOT-23-6_APL5537APL5537SOT-23-6
U13HD74LV1G08A_SOT-23-5_HD74LV1G08HD74LV1G08ASOT-23-5
X1XTAL_9HT9_32.768K32.768K9HT9
X2XTAL_H49S_12MHZ12MHzH49S
X3XTAL_H49S_25MHZ25MHzH49S
:):):):) 感谢分享 学习 谢谢分享 感谢分享 感谢分享
