armclub 发表于 2026-6-21 18:49
TI AM5728挂4个DDR3 开发板PCB文件共享 12层PCB设计TPS6590374ZWSR+KSZ9031RNX+TUSB8041+TLV320AIC3104+CDCM9102RHBR
BAT1BATT_HOLD_BH501_BATT2_78X492_CRCR1220MFRFV, DNIBATT2_78X492
D1DIO_ZEN_DDZ9678-7_1.8V_DO221AC_SK54AFL-TPDO221AC
D2DIO_ZEN_DDZ9678-7_1.8V_DO221AC_SK54AFL-TPDO221AC
D3LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D4LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D5LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D6LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D7LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D8PROT_PESD0603_240_603_PESD0603-PESD0603-240603
D9PROT_PESD0603_240_603_PESD0603-PESD0603-240603
D10PROT_PESD0603_240_603_PESD0603-PESD0603-240603
D11PROT_PESD0603_240_603_PESD0603-PESD0603-240603
D22IC_TPD2E001DRL_U_5_DRL_TPD2E001TPD2E001DRLU_5_DRL
D23IC_TPD2E001DRL_U_5_DRL_TPD2E001TPD2E001DRLU_5_DRL
D24DIO_ZEN_DDZ9678-7_1.8V_DO221AC_SK54AFL-TPDO221AC
D25IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D26IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D27IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D28IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D29IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D30IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D31IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D32IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D33IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D34IC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B062XSON
D35IC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B062XSON
D36IC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B062XSON
D37IC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B062XSON
D38IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D40IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1TPD2EUSB30ADRSOT3_DRT_1P0XP8MM
D41LED_LTST_C150GKT_LED_603_DISCRELTST-C191KFKTLED_603
D42IC_TPD1E05U06_2XSON_TPD1E10B06TPD1E10B062XSON
F1FUSE_4A_QUICK_FU250_200X400SMD_5A_SlowBlowFU250_200X400SMD
FB1FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB2RES_0_1/16W_1%_0402_805_0,1%,080,1%,0805805
FB3FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB4FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB5FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB6RES_0_1/16W_1%_0402_805_0,1%,080,1%,0805805
FB7FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB8FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB9FERRITE_180_800_0805_805_150OHM150OHM800mA805
FB10FERRITE_180_800_0805_1206_DNIDNI1206
FB11FERRITE_180_800_0805_1206_DNIDNI1206
FB12FERRITE_180_800_0805_402_BLM15BBLM15BD182SN1402
FB13FERRITE_180_800_0805_402_BLM15BBLM15BD182SN1402
FB14FERRITE_180_800_0805_402_BLM15BBLM15BD182SN1402
FB15FERRITE_180_800_0805_402_BLM15BBLM15BD182SN1402
FL1CHOKE_DLW21SN121HQ2_3_CHOKE4_08DLW21SN900HQ2CHOKE4_0805-2
FL2CHOKE_DLW21SN121HQ2_3_CHOKE4_08DLW21SN900HQ2CHOKE4_0805-2
FL3CHOKE_DLW21SN121HQ2_3_CHOKE4_08DLW21SN900HQ2CHOKE4_0805-2
FL4CHOKE_DLW21SN121HQ2_3_CHOKE4_08DLW21SN900HQ2CHOKE4_0805-2
FL5CM2021Y330R-10_CMC_CM2021Y_CM20CM2021Y330R-10CMC_CM2021Y
J1HDR_1X1_M_0.1_CON2_49LS_DNIDNICON2_49LS
J3HDR_1X3_0.1_SIP3_HDR_1X3HDR_1x3SIP3
J4HDR_1X3_0.1_SIP3_HDR_1X3HDR_1x3SIP3
J5HDR_1X1_M_.1_SIP2_HDR_1X1_M_.1,HDR_1x1_M_.1,DNISIP2
J6HDR_1X3_0.1_SIP3_HDR_1X3HDR_1x3SIP3
L1INDUCTOR_IND130_208X216_4.7UH4.7uHIND130_208X216
L2INDUCTOR_IND130_208X216_3.3UH,73.3uH,7AIND130_208X216
L3IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L4IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L5IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L6IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L7IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L8IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L9IND_PWR_1.0UH_4.2A_SMD_IND130_11.0uH,4.2AIND130_160X175
L10FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
L11FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
L12FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
L13FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L14FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L15FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L16INDUCTOR_IND130_208X216_4.7UH4.7uHIND130_208X216
L17FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L18FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L19FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L20FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L21FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
L22FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
L23FERRITE_220_0805_IND_0805_BLM21BLM21PG221SN1DIND_0805
L24FLT_HIFREQ_.47UF_FLT3SMD_0805-2FLT_HIFREQ_.47UFFLT3SMD_0805-2
MH1TESTPOINT_MTGH250C125D_PL_MOUNTMOUNT_HOLEMTGH250C125D_PL
MH2TESTPOINT_MTGH250C125D_PL_MOUNTMOUNT_HOLEMTGH250C125D_PL
MH3TESTPOINT_MTGH250C125D_PL_MOUNTMOUNT_HOLEMTGH250C125D_PL
MH4TESTPOINT_MTGH250C125D_PL_MOUNTMOUNT_HOLEMTGH250C125D_PL
MH5TESTPOINT_MTGH200C102D_PL_MOUNTMOUNT_HOLEMTGH200C102D_PL
P1CONNMOD 8-8_J_7_JACK_PJ-063-08PJ-0XXBHJACK_PJ-063-080BH
P4HDR_JTAG_20P_HEADER10X2_SMD_2020Pin JTAGHEADER10X2_SMD
P5CONN_RJ45_DUAL_GIGABIT_1_RJ45_2LPJG17561BGNLDual RJ45 10/100/1000RJ45_2X1_XFRM_LED
P6CONN_11P_ESATA_ESATA-USB_COMBO_eSATAESATA-USB_COMBO_RA
P7CONN_MINI-USB-AB_1_USB5_FCI-101MicroUSB-BUSB5_FCI-10103594
P8CONN_STEREO_3.5MM_1SW_JACK5-472SJ1-3524NGJACK5-472X551-SJ1-3524NG
P9CONN_STEREO_3.5MM_1SW_JACK5-472SJ1-3524NGJACK5-472X551-SJ1-3524NG
P10HEADER6_SIP6_HEADER 6HEADER6SIP6
P11HDMI-RA-19_0_HDMI-SMT-W-FLANGE_HDMI-RA-19-TYPEAHDMI-SMT-W-FLANGE
P12MICROSD_CONN_0_SD-MICRO-SCHA5B0SCHA5B0200SD-MICRO-SCHA5B0300
P13CONN_USB3_3.0_A_USB9RA_2SHIELDECONN_USB3.0_AUSB9RA_2SHIELDED
P15CONN_USB3_3.0_A_DUAL_USB18RA_4SGSB311231HRUSB18RA_4SHIELDED
P16CONN_30X2_5.27MM_HDR2X30SMD_FX1CONN_30x2_0.8HDR2X30SMD_FX18-60P-0P8SV
P17CONN_30X2_5.27MM_HDR2X30SMD_FX1CONN_30x2_0.8HDR2X30SMD_FX18-60P-0P8SV
P18CONN_30X2_5.27MM_HDR2X30SMD_FX1CONN_30x2_0.8HDR2X30SMD_FX18-60P-0P8SV
P19CONN_30X2_5.27MM_HDR2X30SMD_FX1CONN_30x2_0.8HDR2X30SMD_FX18-60P-0P8SV
Q1IRF5210S/SM_0_SOT223-1_FDT434PFDT434PSOT223-1
Q2IRF5210S/SM_0_SOT223-1_FDT434PFDT434PSOT223-1
Q3TRN_DMC56404_SMINI6-F3-B_DMC564DMC56404SMINI6-F3-B
Q4TRN_DMC56404_SMINI6-F3-B_DMC564DMC56404SMINI6-F3-B
Q5TRN_NTA4153N_SC75_NTA4153NNTA4153NSC75
Q6TRN_BSS138_0_SC70_BSS138BSS138SC70
Q8TRN_1_SOT23-3_TRN_2N2907TRN_2N2907SOT23-3
Q9TRN_1_SOT23-3_TRN_2N2907TRN_2N2907SOT23-3
Q112N2222_0_SOT-23_MMBT2222AMMBT2222ASOT-23
S1SWPUSH_TH_SW4_EVQF004R_SW PUSHSWPUSH_THSW4_EVQF004R
S2SWPUSH_TH_SW4_EVQF004R_SW PUSHSWPUSH_THSW4_EVQF004R
TP4TESTPT1_TP1-8040_TESTPT1TESTPT1TP1-8040
U1IC_TPS54331,3A_0_DDA-8_TPS54531TPS54531DDDA-8
U2TPS22965DSG_1_WSON-8_TPS22965DSTPS22965DSGWSON-8
U3IC_TPS54331,3A_0_DDA-8_TPS54531TPS54531DDDA-8
U4IC_TMP102AIDRL_SOT563_SOT563_TMTMP102AIDRLTSOT563
U5IC_TPS659039_8_BGA169_N13_P8_TPTPS6590374ZWSRBGA169_N13_P8
U6IC_MCP79410_DFN8_2X3MM_MCP79410MCP79410,TFDNDFN8_2X3MM
U7IC_CDCM9102RHBR_0_QFN32_CDCM910CDCM9102RHBRQFN32
U8MEM_24WC256_0_SOIC_8_MEM_24WC25MEM_24WC256_8SOICSOIC_8
U9IC_SN74LVC1G11_DRY_SC70-6_SN74LSN74LVC1G11DBVSC70-6
U10IC_SN74LVC1G08_DCK_SC70-5_SN74LSN74LVC1G08DCKSC70-5
U11IC_AM572X_BGA_34_SKTBGA-ZKK-633AM5728SKTBGA-ZKK-6334-P760
U12PWR_TPS3808G09DBVR_SOT23_0_SOT2TPS_3808G09SOT23-6
U13PWR_TPS3808G09DBVR_SOT23_0_SOT2TPS_3808G09SOT23-6
U14IC_KSZ9031RNX_QFN48_9_QFN48_KSZKSZ9031RNXQFN48
U15IC_KSZ9031RNX_QFN48_9_QFN48_KSZKSZ9031RNXQFN48
U16PWR_TPS74801_SON_DRC10-11X33_TPTPS74801DRC10-11X33
U17IC_TUSB8041_2_VQFN64S9X9P5_TUSBTUSB8041VQFN64S9X9P5
U18IC_TLV320AIC3104_5_QFN32_TLV320TLV320AIC3104QFN32
U19PWR_TPS7018DBV_SOT23_5_SOT23-5_TPS77018DBVSOT23-5
U20IC_SN74LVC2G241_1_U_8_DCU_SN74LSN74LVC2G241U_8_DCU
U21IC_TPD12S016_QFN24S_2X4P4_TPD12TPD12S01624UQFNQFN24S_2X4P4
U22MEM_MNAND_1_BGA153_P14_P5_11P5XMEM_MNAND_4GBBGA153_P14_P5_11P5X13
U23MEM_DDR3L_256MBX16_0_BGA96_T9_P256MBx16DDR3LBGA96_T9_P8_9X14
U24MEM_DDR3L_256MBX16_0_BGA96_T9_P256MBx16DDR3LBGA96_T9_P8_9X14
U25MEM_DDR3L_256MBX16_0_BGA96_T9_P256MBx16DDR3LBGA96_T9_P8_9X14
U26MEM_DDR3L_256MBX16_0_BGA96_T9_P256MBx16DDR3LBGA96_T9_P8_9X14
U27IC_TPS51200_10S0N_DRC10-11X33_TTPS51200_10SONDRC10-11X33
U28IC_TPS54331,3A_0_DDA-8_TPS54531TPS54531DDDA-8
U29PWR_TPS2560_DRC_0_DRC10-11X33_TTPS2561DRCDRC10-11X33
U30PWR_TPS2560_DRC_0_DRC10-11X33_TTPS2561DRCDRC10-11X33
U31IC_PI2DBS212ZHE_TQFN_9_TQFN28S_PI2DBS212_TQFNTQFN28S_3P5X5P5P5
U32TC648_0_SO8-25X75_TC648TC648SO8-25X75
U33IC_SN75LVCP412A_1_QFN20S4X4P5-2SN75LVCP412AQFN20S4X4P5-2
U34IC_SN74LVC2G132DCU_U_8_DCU_SN74SN74LVC2G132DCUU_8_DCU
U35MA735/TO_0_SOT23-3_TLVH431TLVH431SOT23-3
U43MA735/TO_0_SOT23-3_TLVH431TLVH431SOT23-3
Y1CRYS_32_768KHZ_SMD_XTAL_CFS-206CFS206-32.768KDZBXTAL_CFS-206
Y2CRYS_20MHZ_12.5PF_2P_3.2X1.5_XT20MHz,SMDXTAL2_6X3P5_SMD
Y3CRYS_22.5792MHZ_7PF_4P_3.2X2.5_22.5792MHZXTAL4_3P2X2P5_SMD
Y5CRYS_25MHZ_18PF_2P_5.0X3.2_XTAL25MHzXTAL_3P2X5SMD
Y6CRYS_25MHZ_18PF_2P_5.0X3.2_XTAL25MHzXTAL_3P2X5SMD
Y7CRYS_24MHZ_2PIN_OSC4_87-146SMD_24MHzOSC4_87-146SMD_126X197-1
Y8CRYS_25MHZ_8PF_4P_3.2X2.5_XTAL425MHz,8pFXTAL4_3P2X2P5_SMD
Y9CRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM16.384MHzXTAL4_3P2X2P5_SMD
Y10CRYS_24MHZ_SCC_OSC4_2P5X2P0XP5_16.384MHzOSC4_2P5X2P0XP5
zhang_tao_08 发表于 2026-6-21 19:36
感谢楼主分享
a6682100 发表于 2026-6-21 23:57
谢谢
jjkks2020 发表于 2026-6-22 00:50
kanxue_nmg 发表于 2026-6-22 02:18
电路PCB爱好者 发表于 2026-6-22 06:25
学习一下
电路PCB爱好者 发表于 2026-6-22 06:38
学习一下
江波波 发表于 2026-6-22 07:32
学习学习
bidezhi7777 发表于 2026-6-22 07:53
飞扬11 发表于 2026-6-22 08:04
感谢分享
页: [1] 2 3 4 5 6 7
查看完整版本: TI AM5728挂4个DDR3 开发板PCB文件共享 12层PCB设计TPS6590374ZWSR+KSZ9031RNX+TUSB8041+TLV320AIC3104+CDCM9102RHBR
