Cyclone V GT 5CGTFD9E5F35 16层DEMO 开发板PCB和原理图
本帖最后由 armclub 于 2026-7-15 11:56 编辑REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME
BT1BATTERY_0_KEYSTONE_BT-2994_BATTBatteryKEYSTONE_BT-2994
CN1CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
CN2CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
CN3CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
CN4CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
CN5CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
CN6CAP_ARRAY_CAP_PACK_4_1206_0.1UF0.1uFCAP_PACK_4_1206
D1LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
D30LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
D31LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D32LED_LUMEX_LED0805_GREEN_LEDGreen_LEDLUMEX_LED0805
D33LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D34LED_LUMEX_LED0805_YELLOWLEDYELLOWLEDLUMEX_LED0805
D35LED_LUMEX_LED0805_YELLOWLEDYELLOWLEDLUMEX_LED0805
D36DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
D37DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
D38D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D39MMBD1205_SOT23_MMBD1205MMBD1205SOT23
D40D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D41DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
D42DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
D43DIODE,SCHOTTKY CMDSH-3_SOD323_CMDSH-3SOD323
D44LED_LUMEX_LED0805_YELLOWLEDYELLOWLEDLUMEX_LED0805
D45LED_LUMEX_LED0805_YELLOWLEDYELLOWLEDLUMEX_LED0805
J1QSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01SAMTEC_QSHDP120CUSTOM
J2QSH_HSM_SAMTEC_QSHDP120CUSTOM_AASP-122953-01SAMTEC_QSHDP120CUSTOM
J3SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J4SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J5USB_CON_TH_MOLEX_MINI-AB_USB_THUSBMINI-ABMOLEX_MINI-AB_USB_TH
J6SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J7SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J8CONNJACK PWR_3_RAPC712_CONN JACONNJACK PWRRAPC712
J9HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02ERJ45
J10LCD_HEADER_NEWHAVEN_LCD_LCD_HEALCD_HEADERNEWHAVEN_LCD
J11CONN,MINI SMB, THM, RA_SMB_RA_MiniSMBSMB_RA_JACK_RECEP
J12CONN,MINI SMB, THM, RA_SMB_RA_MiniSMBSMB_RA_JACK_RECEP
J1370247-1051_MLX_SHROUD_VRT_HDR_170246-1004MLX_SHROUD_VRT_HDR_10PIN
J14SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J15CON2_MLX_22_23_2021_MLX_22_23_222_23_2021MLX_22_23_2021_VRT_HDR_2P
J16PCIE_BRACKET_X4_PCIX-4PORT_PCIEPCIE_SlotPCIX-4PORT
J17CON6A_SAMTEC_HDR_2X3_2MM_SMT_DNDNISAMTEC_HDR_2X3_2MM_SMT
J182X5_HDR2X5_100MIL_SMT_DNIDNIHDR2X5_100MIL_SMT
L1IND1.2UH IR=6.5A CUBE SMD_IND_1.2uHIND_SUSUMU_PCMC_BTYPE
L2IND1.2UH IR=6.5A CUBE SMD_IND_1.2uHIND_SUSUMU_PCMC_BTYPE
L3INDUCTOR_IND_WURTH_744325120_1.1.2uHIND_WURTH_744325120
L4INDUCTOR_IND_WURTH_744325120_1.1.2uHIND_WURTH_744325120
L5BEAD_FERRITE_SM_IND_0603_3A,303A,30 Ohm FBIND_0603
L6IND0.47UH IR=18A ISAT=20A SMD_0.47uHIND_WURTH_744314047
L7IND0.47UH IR=18A ISAT=20A SMD_0.47uHIND_WURTH_744314047
L8IND1.2UH IR=6.5A CUBE SMD_IND_1.2uHIND_SUSUMU_PCMC_BTYPE
L9INDUCTOR_0402_3.9NH3.9nH402
L10BEAD_FERRITE_SM_0603_120OHM FB120Ohm FB603
L11INDUCTOR_0402_5.6NH5.6nH402
L12INDUCTOR_0402_5.6NH5.6nH402
L13BEAD_FERRITE_SM_IND_0603_3A,303A,30 Ohm FBIND_0603
Q1RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBLFPAK-4
Q2RJK0301DPB_LFPAK-4_BUK7Y7R0-40HBUK7Y7R0-40HXLFPAK-4
Q3RJK0301DPB_LFPAK-4_BUK7Y7R0-40HBUK7Y7R0-40HXLFPAK-4
Q4RJK0301DPB_LFPAK-4_RJK0305DPBRJK0305DPBLFPAK-4
Q5PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
RN6RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
RN7RES_PACK_0_RES_PACK_8_S1+S2+S3+51RES_PACK_8
S1TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S2TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S3TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S4TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S5TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S6TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
S7TS-A02SA-2-S100_0_WURTH_6X3P5_TPBSwitchWURTH_6X3P5_TACT_SWITCH
SW176SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1DIPSWITCH_SMT_OCTAL
SW2SW_SLIDE_DPDT_EG2207_SW_SLIDE_DSW_SLIDE_DPDTEG2207
SW3SPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1DIPSWITCH_SMT_QUAD
SW4SPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1DIPSWITCH_SMT_QUAD
SW5SPST4_DIPSWITCH_SMT_QUAD_TDA04HTDA04H0SB1DIPSWITCH_SMT_QUAD
U1REGSWITCHING, LTC3605EUF_QFN24LTC3605EUFQFN24
U2REGSWITCHING, LTC3605EUF_QFN24LTC3605EUFQFN24
U3IDT5T9306_0_VFQFPN-28_EPAD_IDT5IDT5T9306VFQFPN-28_EPAD
U4CY7C68013A_VFBGA_VFBGA56_CY7C68CY7C68013A_VFBGAVFBGA56
U5TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRT
U6MAX811_SOT-143_MAX811MAX811SOT-143
U7LT3022EDHC_DFN16_EPAD_5X3_LT302LT3022EDHCDFN16_EPAD_5X3
U8MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U9FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8882FDMC8878_VER2
U10LTC3085EDCB_DFN6-3X2_EPAD_LT308LT3085EDCBDFN6-3X2_EPAD
U1188E1111_BCC96_88E111188E1111BCC96
U12MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U135CGTFD9E5F35_F1152_5CGTFD9E5F355CGTFD9E5F35F1152
U14FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8882FDMC8878_VER2
U15MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U16FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8882FDMC8878_VER2
U17FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8882FDMC8878_VER2
U18LT3022EDHC_DFN16_EPAD_5X3_LT302LT3022EDHCDFN16_EPAD_5X3
U19FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8882FDMC8878_VER2
U20MT28EW01GABA1HPC-0SIT_3_HC_TK0_MT28EW01GABA1HPC-0SITHC_TK0_BGA64
U21REGSWITCHING, LTC3608_QFN52_3ELTC3608QFN52_3EPAD
U22MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U23EPM570M100_0_M100_S1,S2,S3_DNIDNIM100
U24LTC3613EWKH_7_QFN56_7X9MM_LTC36LTC3613EWKH_6QFN56_7X9MM
U25REGSWITCHING, LTC3605EUF_QFN24LTC3605EUFQFN24
U26MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U27MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U28MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U29IDTQS3861_QSOP24P_IDTQS3861IDTQS3861QSOP24P
U30MT41J128M16HA_MICRON_DDR3_96_9XMT41K128M16JTMICRON_DDR3_96_9X14
U31FXL5T244_DQFN14_DNIDNIDQFN14
U325M2210ZF256_F256_5M2210ZF2565M2210ZF256F256
U33EPCQ256_SO16_WIDE_MT25QL256ABA8MT25QL256ABA8ESF-0SITSO16_WIDE
U34FXL5T244_DQFN14_DNIDNIDQFN14
U35MAX3023_TSSOP14_MAX3023MAX3023TSSOP14
U36TS5A23157_MSOP10_TS5A23157TS5A23157MSOP10
U37TS5A23157_MSOP10_TS5A23157TS5A23157MSOP10
U38MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U39LTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1DFN6-2X2_EPAD
U40LTC3855_QFN40_LTC3855EUJLTC3855EUJQFN40
U41LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U42LT3009XDC_0_DFN6-2X2_EPAD_LT300LT3009xDCDFN6-2X2_EPAD
U43TPS51200_DRC-10_EPAD_TPS51200TPS51200DRC-10_EPAD
U44LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U45LTC2418_SSOP28_NAR_LTC2418LTC2418SSOP28_NAR
U46LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U47LMH0384_LLP16_EPAD_LMH0384LMH0384LLP16_EPAD
U48MAX3378_0_TSSOP14_MAX3378MAX3378TSSOP14
U49EPM570T100EPM570GT100C3NTQFP100SQ
U50LMH0303_LLP16_EPAD_LMH0303LMH0303LLP16_EPAD
U51RESET,MAX811_SOT-143_DNIDNISOT-143
U52SL18860DC_TDFN-10_SL18860DCSL18860DCTDFN-10
U53TPS51200_DRC-10_EPAD_TPS51200TPS51200DRC-10_EPAD
V1SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V2SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V3SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V4SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V5SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
V6SENSE_PAD_SENSE_SENSE_PADSENSE_PADSENSE
X1OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzXTAL_SG310
X2OSC_ALT_1_XTAL_XG-1000CB_100MHZ100MHzXTAL_XG-1000CB
X3SI571_XTAL_SI570_SI571SI571XTAL_SI570
X4SI570_ALT1_XTAL_SI570_SI570SI570XTAL_SI570
X5635L3C3_XTAL_EG2100_125.0MHZ125.0MHzXTAL_EG2100
X6OSC_ALT_0_ECS3525_50MHZ50MHzECS3525
Y1CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzXTAL_FA-128
好好地学习。TKS... 学习 学习 学习 谢谢分享 学习感谢 junkyoung 发表于 2026-7-15 11:55
好好地学习。TKS...
1111111111111 画出这样的板子需要多少年经验?需要画多久? :)太厉害了,我什么时候能有这样的水平
