kinoma Marvell PXA168/PXA166方案做的物联网平板电脑PCB和原理图生产资料等
261D28SS14FairchildSS14DIODE SCHOTTKY 1A 40V SMASMA
271D31DiodeMicrosemiLSM115JE3/TR13DIODE SCHOTTKY 15V 1A DO214BADO214BA
289FB4,FB5,FB6,FB15,FB45,FB46,FB48,FB49,FB50FB/3AMurataBLM18KG121TN1FERRITE CHIP 120 OHM 3000MA 0603L-0603
294FB8,FB9,FB10,FB11BEADMurataBLM18BA470SN1FERRITE CHIP 47 OHM 300MA 0603L-0603
301J1USB micro ABHiroseZX62RD-AB-5P8CONN RCPT MCR USB AB SMD TH SHLLUSB-MICRO-AB-HIROSE
311J72x8-0.1in-SMDSamtecHLE-108-02-F-DVCONN SOCKET 2.54MM 16POS GOLDSKT2x8_100MIL_SMD
323J8,J32,J34Molex-52806-0510Molex52806-0510CONN FFC/FPC 5POS 1MM VERT T/HMolex_52806_0510
331J27PHJSTS2B-PH-SM4-TB(LF)(SN)CONN HEADER PH SIDE 2POS 2MM SMDJST_PH2P_2MM
341J30uSD SLOTAmphenol101-00660-68-6CONN MINI MICRO-SD 8PIN PCB GOLDuSDCARD-push
351J33USB mini BMOLEX513870530CONN RCPT MINIUSB B 5POS SMD R/AUSB-MINI-B-MOLEX
361J35BSW25x2SamtecBSW-125-04-L-DCONN RCPT 50POS .100" DBLGOLD BOTTOM ENTRYRCPT25x2_100mil_BOT
372J36,J39HDR1x8SamtecSSM-108-F-SVCONN HEADER FEMALE 8POS .1"GOLDHDR1x8_100milSMT
381J48FPC 51C 0.3mm topHIroseFH35-51S-0.3SHW(50)CONN FPC 51POS 0.3MM SMDFH35_51_0_3MM
391J50PHR3JSTS3B-PH-SM4-TB(LF)(SN)CONN HEADER PH SIDE 3POS 2MM SMDJST_PHR3P_2mm
402J51,J52ACH2PJSTBM02B-ACHSS-GAN-TF(LF)(SN)CONN HEADER ACH SIDE 2POS 1.2MMJST_ACHSS_2P1_2MM
411LED13GreenLiteonLTST-C191KGKTLED GREEN CLEAR THIN 0603 SMDLED-0603
421L25.1nHMurataLQG15HS5N1S02DINDUCTOR 5.1NH 300MA 0402L-0402
431L101.0uHTDKFLF3215T-1R0NINDUCTOR 1.0UH 2.0A 30% SMDFLF3215
441L111.2uHTDKVLC5020T-1R2NINDUCTOR POWER 1.2UH 3.8A SMDVLC5020T
451L121.5uHVishayIFSC1008ABER1R5M01INDUCTOR POWER 1.5UH 2.6A SMDINDUCTOR_MDT2520_CN_SERIES
461L34CMCTaiyoCM04RC01TCHOKE COMMON MODE 800OHMS SMDCMC
471L351.0uHVishayIFSC1008ABER1R0M01INDUCTOR POWER 1UH 2.6A SMDINDUCTOR_MDT2520_CR_SERIES
481L362.7uHBournsSDR0302-2R7MLINDUCTOR POWER 2.7UH 1.5A 0302SDR0302
491NTC110KPanasonicERT-J0EM103JTHERMISTOR NTC 10K OHM 5% 0402R-0402
802SW5,SW13FSM2JSMATycoFSM2JSMATRSWITCH TACTILE SPST-NO 0.05A 12VFSM2JSMATR
811U1PXA166SA0Marvell88AP166SA0-BJD2C008IC App Processor SOCfbga-18x18-320
821U2DDR3_X16_BGA96NanyaNT5CB64M16FP-CFIC DDR3 1Gbit-64Mx16DDR3-96
831U888CE156Marvell88CE156A0NAJ2C000IC CODEC HP STEREO HP SPKR DRVRQFN32p-0_5-5X5X1MM
841U1688PG867Marvell88PG867-HB0-NNY2C00IC Power, Dual 3A/1A buck3x4QFN24
851U2332.768KHzTXC7XZ3270008OSCILLATOR 32.768KHZ 1.8V SMDsmy4p-3_2x2_5x1mm
861U99AW-NH387AzureWaveAW-NH387MODULE WIFI 8787 2.4GLGA-88
877U120,U131,U132,U141,U142,U147,U148RT9715EGBRichtekRT9715EGBIC PWR SW USB 1.1A SOT23-5SOT23-5
881U126W25Q128WinbondW25Q128FVEIGFlash Mem Serial-SPI 3.3V128M-Bit 16M x 8 8ns 8-Pin VDFPN EPqfn-8x6-8s
891U13388PG8211Marvell88PG8211A2-NXS2C000IC power, 500mA buck 50mA LDO4X3QFN16_PAD_LENGTH_0P8MM_32MIL
901U134FT234FTDIFT234XD-RIC USB SERIAL BASIC UART 12DFNDFN12
912U135,U143PIC16F1508microchipPIC16F1508-I/MLIC microcontroller 20 pinQFN20
924U136,U137,U144,U14574HC4094NXP74HC4094PW,118IC 8STAGE SHFT/STORE BUS 16TSSOPTSSOP16
931U146MAX17058GmaximMAX17058G+IC gas gauge m3TDFN8
941U150MAX17112MaximMAX17112ETB+IC CONV DC-DC STEP UP 10TDFNTDFN10EP
951U151PCA9543NXPPCA9543AD,118IC I2C SWITCH 2CH 14-TSSOPsoic14-50-157
961U154AP7333DoidesAP7333-33SRG-7IC LDO 3.3v .3A SOT23RSOT23R
976U155,U156,U170,U171,U172,U173TPD8E003TITPD8E003DQDRIC 8CH ESD PROT 8WSONWSON8EP
981U159PIC12F508MicrochipPIC12F508I/MCIC microcontrollerDFN8EP
991U169RT9525RichtekRT9525GQWIC charger linear Li-PolyWQFN16EP
1002U175,U176CM1293AOnsemiCM1293A-04SOESD PROT LOW CAP 4CH SC74SC-74
1011VR188PG839Marvell88PG839-A1-NAE2C000IC Power Switching DFN-12
1021Y126MHzTXC7M26070013CRYSTAL 26.000 MHZ 18PF SMDo-3_2X2_5-4g
UnpopulatedParts
1032CM1,CM2*CML201212T-121MMurataCML201212T-121MIND common mode choke 2 linesFIL-2X1_2-4
1043C188,C367,C369*2.2uFTDKC1005X5R1A225KCAP CER 10UF 10V 10% X5R 0603C-0402
1051C328*4.7uFMurataGRM188R60J475KE19DCAP CER 4.7UF 6.3V 10% X5R 0603CAP_0603
1061C334*9pFMurataGRM1555C1H9R0DZ01DCAP CER 9PF 50V C0G 0402C-0402
1073C337,C384,C385*33pFTDKC1005C0G1H330J050BACAP CER 33PF 50V 5% NP0 0402C-0402
1081C361*560pFTDKC1005C0G1E561JCAP CER 560PF 25V 5% NP0 0402C-0402
1094D12,D14,D29,D30*ESDVishayMSE1PB-M3/89ADIODE ESD PROT 1A 100V MICROSMPMicroSMP
1101FB47*FB/3AMurataBLM18KG121TN1FERRITE CHIP 120 OHM 3000MA 0603L-0603
1111J6*U.FLHiroseU.FL-R-SMTConn coax rfUSB_SINGLEBAND_A
1121L3*1.2nHVishayILC0402ER1N2SIND 1.2nH 300mA 0.12ohm Q=8 SMD0402 GPL-0402
1132Q1,Q108*FDV301NFAIRCHILDFDV301NMOSFET N-CH 25V 220MA SOT-23SOT-23a
1141Q3*MMBT3904On SemiMMBT3904LT1GTransistor NPN MMBT3904SOT23
16C1,C2,C3,C4,C5,C61uFTaiyoTMK107BJ105KA-TCAP CER 1UF 25V 10% X5R 0603
22C322,C3230.1uFTDKC1005X7R1A104KCAP CER .10UF 10V X7R 0402
33D1,D2,D3B0540WS-7DiodesB0540WS-7DIODE SCHOTTKY 40V 0.5A SOD323
42D15,D16REDLite-OnLTST-C193KRKT-5ALED RED RECT CLEAR 0603
53J1,J4,J7FPC 51C 0.3mm topHIroseFH35-51S-0.3SHW(50)CONN FPC 51POS 0.3MM TOP SMD
62J2,J5FPC 45C 0.5mm botAVX046240054005800+CONN FPC ONE-TOUCH LCK .5MM 54
71J3FPC 6C 0.5mm BOTFCISFV6R-1STE1HLFCONN FPC/FFC 6POS BOT .5MM R/A SMD
82J50,J74PHR3JSTS3B-PH-SM4-TB(LF)(SN)CONN HEADER PH SIDE 3POS 2MM SMD
92J55,J75KS1042SMDKeystone1042HOLDER BATTERY 1CELL 18650 SMD
101J76FPC 10C 0.5mm topFCISFV10R-2STE1HLFCONN FPC/FFC 10POS .5MM R/A SMD
113L1,L2,L322uHTaiyoNR4012T220MINDUCTOR 22UH 20% SMD
127Q6,Q66,Q67,Q68,Q69,Q70,Q71FDV301NFAIRCHILDFDV301NMOSFET N-CH 25V 220MA SOT-23
133R3,R6,R74.99RVishayCRCW04024R99FKEDRES 4.99 OHM 1/16W 1% 0402 SMD
147R27,R389,R391,R392,R414,R419,R42410KPanasonicERJ-2GEJ103XRES 10K OHM 1/10W 5% 0402 SMD
154R29,R388,R390,R393220RPanasonicERJ-2RKF2200XRES 220 OHM 1/10W 1% 0402 SMD
161R4070RPanasonicERJ-2GE0R00XRES 0.0 OHM 1/10W 0402 SMD
171R4271.5KPanasonicERJ-2GEJ152XRES 1.5K OHM 1/10W 5% 0402 SMD
183U1,U2,U3AP5724WG-7DiodesAP5724WG-7IC LED DRVR WHITE BCKLGT SOT23-6
192U5,U6S8211CSIIS-8211CAD-M5T1GIC Lithium Battery Pack Protection
Unpopulated Parts
201C110*0.1uFTDKC1005X7R1A104KCAP CER .10UF 10V X7R 0402
211C111*1uFTDKC1608X7R1A105KCAP 1uF 10% 0603 10V X7R
224C115,C116,C117,C118*1000pFKemetC0402S102K3RACTUCAP 1nF 10% 0402 25V X7R
231FB5*FB/3AMurataBLM18KG121TN1FERRITE CHIP 120 OHM 3000MA 0603
241J8*SMD60_0.3MMPCB fabN/APCB foot print
251J9*SMD60_0.5mmPCB fabN/APCB foot print
261J10*TH34PCB fabN/APCB foot print 2x17 x 28mil hole
271J11*TH60PCB fabN/APCB foot print 2x30 28mil hole
281J12*TH14PCB fabN/APCB foot print 1x14 x 28mil hole
291J13*SMD14_1mmPCB fabN/APCB foot print
301J14*SMD14_0.5MMPCB fabN/APCB foot print
311J15*TH12PCB fabN/APCB foot print 2x6 x 28mil hole
323J16,J17,J77*TH1PCB fabN/APCB foot print 28mil hole
331J52*RTOUCHN/APCB TH 100mil D28mm
3414R102,R395,R396,R397,R398,R399,R400,R401,R402,R403,R404,R405,R406,R408*0RPanasonicERJ-2GE0R00XRES 0.0 OHM 1/10W 0402 SMD
352R115,R429*0RPanasonicERJ-3GEY0R00VRES 0.0 OHM 1/10W 0603 SMD
362R386,R394*1MPanasonicERJ-2GEJ105XRES 1M OHM 1/10W 5% 0402 SMD
3715R409,R410,R411,R412,R413,R415,R416,R417,R418,R420,R421,R422,R423,R425,R426*10KPanasonicERJ-2GEJ103XRES 10K OHM 1/10W 5% 0402 SMD
381R428*4.99RVishayCRCW04024R99FKEDRES 4.99 OHM 1/16W 1% 0402 SMD
3911TP1,TP3,TP5,TP6,TP7,TP8,TP9,TP10,TP11,TP12,TP13*T_POINTTestNASMT Test Point
401U4*TSC2003TSSOPTITSC2046IPWRIC resistove touch controller
1111111111111111111111 好好地学习。。。 感谢分享 谢谢分享!! 感谢分享 :loveliness: 平板电脑优秀
