RTL8211F-CG + Au5426 +CH482D 做的底板PCB和原理图
NamePart TypePCB DecalValue
CN14A1SD_SOCKET_0TF-CKT01-009DTF_SD_SOCKET
D1DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D2DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D3DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D4DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D5DIODE_3SOD_323B5819WS
D14DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D15DIODE_2DO_214ACSS54
D16DIODE_ZENER1SOD_123SMFJ18A
D17DIODE_3SOD_323B5819WS
D26DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D27DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D28DIODE_1DO_214AASMBJ58A
D30DIODE_2DO_214ACSS54
D31DIODEDO214ACSS34
D32DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D33DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D34DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D35DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
D36DIODE_DOUBLESOT_23BAT54C
D37DIODE_3SOD_1235819
D38DIODE_3SOD323NC
ED18DIODE_BI_DIR_TRIG_0ESD0402_1XD5BTR04G02
FB1BEADL0603120R-100MHz
FB2BEADL0603120R-100MHz
FB3FERRITE_BEADR0402FB120R
FB4R-PACK4_1_2GMDG-4PIN_ESDBCMF122P900H
FB5R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB6R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB7FBR0402FB120R
FB8FBR0402FB120R
FB9R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB10RES_1BR0603FB120R
FB11R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB12R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB13R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB14R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
FB15R-PACK4_3GMDG-4PIN_ESDBCMF122P900H
FB16R-PACK4_0_2GMDG-6PIN_ESDBCMEF122P900H
GND_1TESTTP32GND
H2HOLEHOLE_R6_3D2MMHOLE
H3HOLEHOLE_R6_3D2MMHOLE
H4HOLEHOLE_R6_3D2MMHOLE
H6HOLEHOLE_R6_3D2MMHOLE
J1CON3_1X3DIP3_1X3D5CON_3P_3D5_DIP
J3CON4_0DIP4_1X3D5DIP4_1X3D5
J4CON15_5FPC15PIN-1.0MM-LSCON15
J5CON3_1X3DIP3_1X3D5CON_3P_3D5_DIP
J6CN_9DF40C_100DSPCIE
J7CN_10DF40C_100DSI/O
J8CON15_5FPC15PIN-1.0MM-LSCON15
J14HEADER_1X4P4PINX2_54_DIP_XIAO4PHEADER_1X4P
J15SIM-SPPN08-X0-1X80_0MICRO_SIMMICRO_SIM
J16SATA_DIP_1SMD_SATA_7P_50_180SATA_7P_H_SMD
J19HDMI_AHDMIA19SHDMI_A
J20CON1HOLE_5D5X2D7MMHOLE
J21HR911130C_1RJ45_HRK11000MHz_POE
J23CON4_1DIP_POE_AG5412POE_AG5412_12V
J28CON6_1FPC6-0.5MM-2660HCON6
J32CON1HOLE_5D5X2D7MMHOLE
J33CON1HOLE_5D5X2D7MMHOLE
J35DC091-5521DC091-5521DC091-5521
J90036HR911130C_1RJ45_HRK1HRK1-1B71G59-36A1BB-1R
L1INDUCTORS_OF_FERRITE_2IND-4X44.7uH
L2INDUCTORS_OF_FERRITE_2IND-4X44.7uH
L3INDUCTORS_OF_FERRITEIND-5020SPM5020T-2R2M-LR
L4INDUCTORS_OF_FERRITE_2IND-4X44.7uH
L6R-PACK4_1RCMF7060RCMF7060F-701-2P-T
L7INDUCTORS_OF_FERRITE_2IND-4X44.7uH
L10INDUCTORS_OF_FERRITEIND-4X44.7UH/2A
L6801INDUCTOR_COMRP2_0405BCMF122P900H
L6803INDUCTORS_OF_FERRITE_2IND_2520102.2uH
LCD1EDP_020455-040E-TOPFPC-40P-0.5MM
LCD2EDP30PINFPC30-0.5MMFPC30-0.5MM
LED2LEDLED0603NC
Q1NPNSOT_23S8050
Q2MOSFET_P_2SOT23NC/WPM2301
Q3P-MOSFETS0T-23NC/AO3401
Q4N-MOSFETS0T-23NC/WNM2021-3/TR
Q5NPNSOT_23S8050
Q6MOSFET_P_2SOT23WPM2301
Q7NPNSOT_23S8050
Q8NPNSOT_23S8050
Q9NPNSOT23S8050
Q10NPNSOT23S8050
Q11MOSFET_P_2SOT23WPM2015-3/TR
Q12NPNSOT23S8050
Q13MOSFET_PSOT_23WPM2015-3/TR
Q14NPN4SOT23S8050
Q15MOSFET_N_2SOT23AO3416
Q16N-MOSFETSOT_3232SK3018
Q17MOSFET_NSOT_3232SK3018
Q18N-MOSFETSOT_3232SK3018
Q19MOSFET_PSOT_23WPM2015-3/TR
Q20NPN4SOT23S8050
RP1R-PACK4RN8P4RC22RX4
RP2R-PACK4RN8P4RC22RX4
SW1KEY_0SW_4_DIPRECOVERY_KEY
SW3LED_0DIP_SWITCHCB-031-DWZ-16P-13S-01
T1TESTTP3212V
TP1TPTP_0R70TP_0.7
TP2TPTP_0R70TP_0.7
TP8TPTP_0R70TP_0.7
TP9TPTP_0R70TP_0.7
U1XR21V1410_0SSOP20_1SP3222EEA-L/SSOP20
U2MAX3485_0SOP8_5R00X4R00X1R75_TSIT3485E
U3TJA1051T_0SOP8_5R00X4R00X1R75_TTCAN1044V-Q1
U6M_5.2_NGFF_EKEY_SOCKETM2_NGFF_KEY_M_1M2-MKEY
U7M_6.2_NGFF_EKEY_SOCKETM2_NGFF_KEY_B-GXM2-BKEY
U8DCDC_SY8113SOT_23_6SY8113B/SM8103ADC
U9DCDC_SY8113SOT_23_6SY8113B
U10LDO_PT5108SOT_23_5RT9193-33GB
U11AU5426_DEVICEAU5426_QFN32Au5426_device
U12CH482XQFN20-2D5X4D5CH482D
U14OSC_4PIN_1CRY4_3R20X2R50X0R80NC/SOC_24MHz
U17DCDC_NB679QFN12_2R00X3R00X1R00NB679GD
U18CON3_7DIP2_1X3D5DIP2_1X3D5
U20DCDC_SY8113SOT_23_6SY8113B/SM8103ADC
U21ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U22ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U23SWITCH_SY6280SOT_23_5SY6280AAC/TCS9163
U24M_8.2_NGFF_EKEY_SOCKETM2_NGFF_KEY_E_42X30M2_NGFF_KEY_E
U25DCDC_SY8113SOT_23_6SY8113B/SM8103ADC
U26ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U27ESD_ESD5304DSON10_2R50X1R00X0R50ESD5344D
U31AO4409_0SOP8-50-150AO4409
U32RECTIFIER_BSOP4_1D27_4HD06-T
U33RECTIFIER_BSOP4_1D27_4HD06-T
U34MP3202-QFN8_1DFN10P_3X3SY7203
U35CON_BATTERY-20MM_0BAT_CR1220CR1220-3V
U36RTC_HYM8563MSOP8HYM8563TS
U37CON3_6SMD_1D25X2PIN_90SMD_1D25X2PIN_90
U38HETER_4DF40C-200DS-70X40_MZ_3D5J1000
U39CON3_0DIP_14PIN-2_54MMDIP_2D54MM_14PIN_180
U41ETHERNET_RTL8211FQFN40_5R00X5R00X0R90_TRTL8211F-CG
U42LCD39P_03LCD39PIN-OKLCD39P_03
USB6USB30_TYPE_AUSB30-L1USB30_A
USB2503USB20_TYPE_AUSB20A4_USB_AF_01_001USB-HUB_PORTBA
Y17W50000024_4CRY4_3R20X2R50X0R80100MHz,3.3V,3225
Y3CRYSTAL_2P_0CRY-321532.768KHz
Y4CRYSTAL_4PCRY4_3R20X2R50X0R8025MHz
路过, 学习 谢谢分享 学习学习 感谢分享 ::loveliness: 谢谢分享
