sii9000 发表于 2026-7-23 16:58
NXP MK60 MK60DN512VLQ10开发板PCB和原理图
PCB原理图。回复可见
**** Hidden Message *****
B1BEEP_HC12085P_PS1240P02BT_PS124PS1240P02BTPS1240P02BT
D1LED_0_LED0805_LED_GREENLED_GREENLED0805
D2LED_0_LED0805_LED_GREENLED_GREENLED0805
D3LED_0_LED0805_LED_GREENLED_GREENLED0805
D4LED_0_LED0805_LED_GREENLED_GREENLED0805
D5DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
D6DIODE13_7_SOD-123_1N4148W-TP1N4148W-TPSOD-123
F1FUSE_SMD-1210_SMD1210-6V2ASMD1210-6V2ASMD-1210
J1CON20_0_HEADER10X2_2R54_HEADER1HEADER10X2_2R54HEADER10X2_2R54
J2CONNRCPT 9X2_OV2640_OV7620OV7620OV2640
J3CONNRCPT 4_HEADER4X1_2R54_HEADHEADER4X1_2R54HEADER4X1_2R54
J4CONNRCPT 2_KF7R62-2P_KF7R62-2PKF7R62-2PKF7R62-2P
J5CONNRCPT 2_KF7R62-2P_KF7R62-2PKF7R62-2PKF7R62-2P
J6HR911105A_HR911105A_HR911105AHR911105AHR911105A
L1IND_BEAD_0805_600OHM_1_LC0805_BBEAD_GZ2012D102TFLC0805
L3IND_BEAD_0805_600OHM_1_LC0805_BBEAD_GZ2012D102TFLC0805
L5IND_BEAD_0805_600OHM_200MA_LC08BEAD_BLM21PG600LC0805
MH1HOLD_1_HOLD250D134_HOLD-M3HOLD-M3HOLD250D134
MH2HOLD_1_HOLD250D134_HOLD-M3HOLD-M3HOLD250D134
MH3HOLD_1_HOLD250D134_HOLD-M3HOLD-M3HOLD250D134
MH4HOLD_1_HOLD250D134_HOLD-M3HOLD-M3HOLD250D134
Q1L14G1/TO_2_SOT23_123_S9013LT1S9013LT1SOT23_123
Q2L14G1/TO_2_SOT23_123_S9013LT1S9013LT1SOT23_123
Q3L14G1/TO_1_SOT23_123_S8050S8050SOT23_123
RP1RESISTORVAR_0_VISHAY_RES_VAR_6M64W104KB40VISHAY_RES_VAR_64W
SW1SWITCH-SPST-4P_SW-6X6X6-SMD_KEYKEYSW-6X6X6-SMD
SW2SWITCH-SPST-4P_SW-6X6X6-SMD_KEYKEYSW-6X6X6-SMD
SW3SWITCH-SPST-4P_SW-6X6X6-SMD_KEYKEYSW-6X6X6-SMD
SW4SWITCH-SPST-4P_SW-6X6X6-SMD_KEYKEYSW-6X6X6-SMD
T1TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T2TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T3TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
T4TOUCHPAD_TOUCHPAD_TOUCHPADTouchPadTOUCHPAD
TP1TESTPOINT_TP-0R75_TESTPOINTTestPointTP-0R75
TP2TESTPOINT_TP-0R75_TESTPOINTTestPointTP-0R75
TP3TESTPOINT_TP-0R75_TESTPOINTTestPointTP-0R75
U1NRF24L01PACK_NRF24L01PACK_NRF24NRF24L01PACKNRF24L01PACK
U2CEIT_C5000_0_SOIC-8_208_W25Q128W25Q128FVSIGSOIC-8_208
U3CH340G_SOIC16_CH340GCH340GSOIC16
U4K60_LQFP-144_MK60DN512VLQ10MK60DN512VLQ10LQFP-144
U5HS0038_HS0038_HS0038HS0038HS0038
U6AMS1117-3.3_SOT-223_AMS1117-3.3AMS1117-3.3SOT-223
U7ADXL345_0_LGA-14_ADXL345BCCZ-RLADXL345BCCZ-RL7LGA-14
U8AT24C512_SOIC8_AT24C02C-SSHM-TAT24C02C-SSHM-TSOIC8
U9BATTERY_CR1220_BATTERY_CR1220BATTERY_CR1220CR1220
U10IS61LV25626_TSOP-44_IS61LV25616IS61LV25616AL-10TLTSOP-44
U11TFCARD_1_TFCARD_TFCARDTFCARDTFCARD
U12LM2904VQDR_SOIC8_LM2904VQDRLM2904VQDRSOIC8
U13MAX3485ESA_0_SOIC8_MAX3485EESAMAX3485EESASOIC8
U14TJA1050_SOIC8_TJA1050T/CMTJA1050T/CMSOIC8
U15TFT-3R2_TFT-3R5_TFT-3R5TFT-3R5TFT-3R5
U16XPT2046_TSSOP-16_XPT2046XPT2046TSSOP-16
U17KSZ8041NL_MLF-32_KSZ8041NLIKSZ8041NLIMLF-32
USB1USB-MICRO_USB-MICRO_USB-MICROUSB-MICROUSB-MICRO
USB2USB-MICRO_USB-MICRO_USB-MICROUSB-MICROUSB-MICRO
Y1X322525MOB4SI_X-4P-3R2X2R5-SMD_X322512MOB4SIX-4P-3R2X2R5-SMD
Y2SMD_OSC_3_X-4P-5R0X3R2-SMD_SG50SG5032CAN-50M-TJGAX-4P-5R0X3R2-SMD
Y3XTAL_5032_0_X-2P-3R2X1R5-SMD_FCFC-135R32.768kHzX-2P-3R2X1R5-SMD
November1227 发表于 2026-7-23 19:02
感谢分享
AIY 发表于 2026-7-23 19:22
谢谢分享
ZuoYou17 发表于 2026-7-23 20:18
haley.xu 发表于 2026-7-23 23:16
感谢分享
杰克黄 发表于 2026-7-24 06:47
感谢分享
bidezhi7777 发表于 2026-7-24 07:53
bingshuihuo 发表于 2026-7-24 08:52
好东东,谢谢分享!!!
ymq0225 发表于 2026-7-24 08:52
:loveliness:
bailuweixi 发表于 2026-7-24 08:56
赞赞👍👍赞赞👍👍赞赞👍👍赞赞👍👍赞赞👍👍
查看完整版本: NXP MK60 MK60DN512VLQ10开发板PCB和原理图
