ADF7023BCPZ + ADUCM4050BCPZ做的一个射频板PCB和原理图 汇源光通讯
BAT1JMP-2_0_ER14250_ER14250ER14250ER14250
D1LED_4_LED0603_GREEN-0603GREEN-0603LED0603
D3LED_4_LED0603_GREEN-0603GREEN-0603LED0603
J1DC3-10P-Z-L_DC3-10P-Z_DC3-10P-ZDC3-10P-ZDC3-10P-Z
J2CONNRCPT 2_CN1X2-2P54-Z_CN1X2-CN1X2-2P54-ZCN1X2-2P54-Z
J3CONNRCPT 2_HX25035-2A_HX25035-HX25035-2AHX25035-2A
J4CONNRCPT 2_CN1X2-2P54-Z_CN1X2-CN1X2-2P54-ZCN1X2-2P54-Z
J5SMA-KHD_SMA-KHD_SMA-KHDSMA-KHDSMA-KHD
J6CONNRCPT 6_CN1X6-2P54-Z_CN1X6-CN1X6-2P54-ZCN1X6-2P54-Z
J7CONNRCPT 4_CN1X4-2P54-Z_CN1X4-CN1X4-2P54-ZCN1X4-2P54-Z
L1IND_BEAD_0805_600OHM_1_L0402_LQLQW15AN40NG00L0402
L2IND_BEAD_0805_600OHM_1_L0402_BLBLM15AX102SN1L0402
L3IND_BEAD_0805_600OHM_1_L0402__1LQW15AN33NG00L0402
L4IND_BEAD_0805_600OHM_1_L0402__2LQW15AN82NG00L0402
L5IND_BEAD_0805_600OHM_1_L0402__1LQW15AN33NG00L0402
L6IND_BEAD_0805_600OHM_1_L0402__3LQW15AN30NG00L0402
L7IND_BEAD_0805_600OHM_1_L0402__4LQW15ANR10J00L0402
L8IND_BEAD_0805_600OHM_1_L0402__5LQW15AN13NG00L0402
L9IND_BEAD_0805_600OHM_1_L0402_BLBLM15AX102SN1L0402
MH1HOLD_1_HOLE6R90X3R40_HOLE-M3/NIHOLE-M3/NIHOLE6R90X3R40
MH2HOLD_1_HOLE6R90X3R40_HOLE-M3/NIHOLE-M3/NIHOLE6R90X3R40
MH3HOLD_1_HOLE6R90X3R40_HOLE-M3/NIHOLE-M3/NIHOLE6R90X3R40
MH4HOLD_1_HOLE6R90X3R40_HOLE-M3/NIHOLE-M3/NIHOLE6R90X3R40
SW3SWITCH-SPST-4P_K2-1112SW-A4SW-0K2-1112SW-A4SW-04K2-1112SW-A4SW-04
TP1TESTPOINT_TP-0R75_TP/NITP/NITP-0R75
U1ADUCM3029BCPZ_LFCSP64-9X9X0R5-4ADUCM4050BCPZLFCSP64-9X9X0R5-4R5X4R5
U4ADF7023BCPZ_0_LFCSP32-5X5X0R5-3ADF7023BCPZLFCSP32-5X5X0R5-3R3X3R3
U5TMP117AIDRVR_WSON6-2R0X2R0X0R65TMP117AIDRVRWSON6-2R0X2R0X0R65-1R6X1R0
U29SPX3819M5-L-1-2_SOT23-5_SPX3819SPX3819M5-L-3-3/TRSOT23-5
USB1TYPE-C_0_TYPE-C-31-M-12_TYPE-C-TYPE-C-31-M-12TYPE-C-31-M-12
X1TSX-3225_X-4P-3R2X2R5-SMD_NX322NX3225SA-26.000000MHZ-G4X-4P-3R2X2R5-SMD
X2XTAL_5032_0_X-2P-3R2X1R5-SMD_ABABS07-32.768KHZ-6-TX-2P-3R2X1R5-SMD
X3TSX-3225_X-4P-3R2X2R5-SMD_NX322NX3225SA-26.000000MHZ-G4X-4P-3R2X2R5-SMD
这个资料很不错,来学习学习,谢谢分享 好东西 感谢 谢谢分享。 非常感谢 看看:loveliness: 感谢分享 谢谢分享
