IMX6的底板PCB和原理图(WM8904CGEFL+GL850G+LAN8720A)
BAT1JMP-2_0_CR1220_CR2032/NICR2032/NICR1220
BAT2JMP-2_0_ER14250_ER14250ER14250ER14250
CON1SIM_CARD_2_SIM_PUSH_50396006965039600696SIM_PUSH
D1LED_4_LED0805_LED_REDLED_REDLED0805
D2LED_4_LED0805_LED_REDLED_REDLED0805
D3BAT54C_SOT23-3_BAT54CBAT54CSOT23-3
D4LED_4_LED0805_LED_GREENLED_GREENLED0805
D5LED_4_LED0805_LED_GREENLED_GREENLED0805
D6DIODE13_6_TO-227A_V10P10V10P10TO-227A
DC1DC005_DC005_DC005DC005DC005
F1FUSE_SMD-1210_SMD1210-200SMD1210-200SMD-1210
F2FUSE_SMD-1210_SMD1210-200SMD1210-200SMD-1210
F3FUSE_FUSE2920_SMD150LSMD150LFUSE2920
J1CONNRCPT 4_HEADER4X1_2R54_HEADHEADER4X1_2R54HEADER4X1_2R54
J2CONNRCPT 4_HEADER4X1_2R54_HEADHEADER4X1_2R54HEADER4X1_2R54
J5CON_RJ45_1X8_F_RA_0_HR911105A_HHR911105AHR911105A
J6CON_RJ45_1X8_F_RA_0_HR911105A_HHR911105AHR911105A
J7PJ-393_PJ-393_PJ-393PJ-393PJ-393
J8CONNRCPT 2_XHB-2A_XHB-2AXHB-2AXHB-2A
J9PJ-393_PJ-393_PJ-393PJ-393PJ-393
J10FPC50_FFC-50P-0R5-SMD_FH12-50S-FH12-50S-0R5SVFFC-50P-0R5-SMD
J11FPC30_FFC-30P-0R5-SMD_FH12-30S-FH12-30S-0R5SVFFC-30P-0R5-SMD
J12DB9-F_0_DB9-F_DB9-FDB9-FDB9-F
J13CONNRCPT 5X2_HEADER5X2_2R54_HEHEADER5X2_2R54HEADER5X2_2R54
J14CONNRECT 10X2_HEADER10X2_2R54_HEADER10X2_2R54HEADER10X2_2R54
J15HDR_1_WJ2EDGRC-5R08-2P_WJ2EDGRCWJ2EDGRC-5R08-2PWJ2EDGRC-5R08-2P
J16CONNRCPT 2_WJ2EDGRC-5R08-2P_WJWJ2EDGRC-5R08-2PWJ2EDGRC-5R08-2P
J17CONNRCPT 2_WJ2EDGRC-5R08-2P_WJWJ2EDGRC-5R08-2PWJ2EDGRC-5R08-2P
L1744822222_0_ACM2012-900-2P_ACM2ACM2012-900-2P-T002ACM2012-900-2P
L2IND_BEAD_0805_600OHM_200MA_LC08BLM21PG600LC0805
L3IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L4IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L5IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L6IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L7IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L8IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L9IND_BEAD_0805_600OHM_1_LC0805_BBLM21PG600LC0805
L10INDUCTOR_0_TSM0630_TSM0630-3R3MTSM0630-3R3MTSM0630
L11INDUCTOR_0_TSM0630_TSM0630-3R3MTSM0630-3R3MTSM0630
L12INDUCTOR_0_TSM0630_TSM0630-3R3MTSM0630-3R3MTSM0630
Q1MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q2MOS-P_0_SOT23-3_2N70022N7002SOT23-3
Q3MOS-P_0_SOT23-3_2N70022N7002SOT23-3
SW1SWDIP-4_0_DM-04-V_DM-04-VDM-04-VDM-04-V
SW2SWITCH-SPST-4P_K2-1112SW-A4SW-0K2-1112SW-A4SW-04K2-1112SW-A4SW-04
SW3SWITCH-SPST-4P_K2-1112SW-A4SW-0K2-1112SW-A4SW-04K2-1112SW-A4SW-04
SW4SWITCH-SPST-4P_K2-1112SW-A4SW-0K2-1112SW-A4SW-04K2-1112SW-A4SW-04
U1MYC-Y6ULX_SOM_MYC-Y6ULX_SOM_MYCMYC-Y6ULX_SOMMYC-Y6ULX_SOM
U2TPS2051BDBVR_SOT23-5_TPS2041BDBTPS2041BDBVSOT23-5
U3TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U4TFCARD_TFCARD_TFCARDTFCARDTFCARD
U5TSX-3225_X-4P-3R2X2R5-SMD_X3225X322512MSB4SIX-4P-3R2X2R5-SMD
U6GL850G_TSSOP28_GL850GGL850GTSSOP28
U7AT24C512_SOIC8_AT24C02C-SSHM-TAT24C02C-SSHM-TSOIC8
U8MINI_PCI_LATCH_1_MINI_PCIE_SLOT679105700(molexMini PCI-E)MINI_PCIE_SLOT
U9SMF05CT1G_SOT363_SMF05CSMF05CSOT363
U10TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U11TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U12LAN8720A_QFN-24_LAN8720ALAN8720AQFN-24
U13TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U14TPD4E1U06DBVR_SOT363_TPD4E1U06DTPD4E1U06DCKRSOT363
U15WM8904_QFN-32-0R4_WM8904CGEFLWM8904CGEFLQFN-32-0R4
U16RT9013-18GB_SOT23-5_RT9013-18GBRT9013-18GBSOT23-5
U17ADM202_0_SOIC16_SP3232EEN-L/TRSP3232EEN-L/TRSOIC16
U18MAX3485ESA_SOIC8_SP3485EN-L/TRSP3485EN-L/TRSOIC8
U19TJA1050_SOIC8_SN65HVD230DRSN65HVD230DRSOIC8
U20PESD1CAN_SOT23-3_PESD1CANPESD1CANSOT23-3
U21BL8032CB6TR_SOT23-6_BL8032CB6TRBL8032CB6TRSOT23-6
U22BL8032CB6TR_SOT23-6_BL8032CB6TRBL8032CB6TRSOT23-6
U23BL8032CB6TR_SOT23-6_BL8032CB6TRBL8032CB6TRSOT23-6
USB1USB-MICRO_USB-U-F-M5SS-W-1_USB-USB-MICROUSB-U-F-M5SS-W-1
USB2USB-A-DOUBLE_USB-A-DOUBLE_USB-AUSB-A-DOUBLEUSB-A-DOUBLE
感谢分享 感谢分享 感谢分享 感谢分享 感谢版主的分享,赞一个:( : 这个资料很不错,来学习学习,谢谢分享
