ESP32 模块做的PCB文件
D1DIODE_8_SMB_DO-214AA_SS54SS54SMB_DO-214AA
D2DIODE_9_SMB_DO-214AA_SMBJ18ASMBJ18ASMB_DO-214AA
ERX1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
ESD11N6263_D4_5_DFN1006-2L-BI_ESD73031N-2/TRESD73031N-2/TRDFN1006-2L-BI
ESD21N6263_D4_5_DFN1006-2L-BI_ESD73031N-2/TRESD73031N-2/TRDFN1006-2L-BI
ETX1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
FB1BEAD102_FB0805_120R/4A120R/4AFB0805
FB2BEAD102_FB0805_120R/4A120R/4AFB0805
FB3BEAD0805_FB6_FB0805_120R/4A120R/4AFB0805
J1CON4_HDR-TH_4P-P2_54_HDR-TH_4P-P2_54hdr-th_4p-p2_54HDR-TH_4P-P2_54
J2CON10_2_CONN-TH-10P_AFC11-S10ICC-00_AFC11-S10ICC-00AFC11-S10ICC-00CONN-TH-10P_AFC11-S10ICC-00
J3CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MMCON2,1.27MMCONN-SMD-1_25MM-2PLT
J4CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MMCON2,1.27MMCONN-SMD-1_25MM-2PLT
J5CON14A_3_CONN-TH_PHB2_0-2X7PWZDK_PHB2.0-2X7PWZDKPHB2.0-2x7PWZDKCONN-TH_PHB2_0-2X7PWZDK
J6CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MMCON2,1.27MMCONN-SMD-1_25MM-2PLT
J7CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MMCON2,1.27MMCONN-SMD-1_25MM-2PLT
J8CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MMCON2,1.27MMCONN-SMD-1_25MM-2PLT
JMP1JMP2P_HDR-TH_2P-P2_00-V-M_JMP2PJMP2PHDR-TH_2P-P2_00-V-M
JMP2JMP2P_HDR-TH_2P-P2_00-V-M_JMP2PJMP2PHDR-TH_2P-P2_00-V-M
L1INDUCTOR_L6_7X6_7_3.3UH/5A3.3uH/5AL6_7X6_7
LCS1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
LDC1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
LED1LED0603_LED34_LED0603-RD_REDREDLED0603-RD
LRST1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
LSCLK1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
LSDA1TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MMTP1mmTP40
MH1M_HOLE_PTHHOLE650CIR320_PTHHOLE650CIR320PTHHOLE650CIR320PTHHOLE650CIR320
MH2M_HOLE_PTHHOLE650CIR320_PTHHOLE650CIR320PTHHOLE650CIR320PTHHOLE650CIR320
MK1M_HOLE_ID-BOARD_MKmkID-BOARD
MK2M_HOLE_ID-BOARD_MKmkID-BOARD
MK3M_HOLE_ID-BOARD_MKmkID-BOARD
Q1P-MOSFET-SOT-23_Q2_1_SOT-23_AO3401AO3401SOT-23
Q2N-MOSFET-SOT-23_Q4_1_SOT-23_2N70022N7002SOT-23
Q3P-MOSFET-SOT-23_Q2_1_SOT-23_AO3401AO3401SOT-23
Q4N-MOSFET-SOT-23_Q4_1_SOT-23_2N70022N7002SOT-23
Q5MMBT2222A/SOT_0_SOT-23_MMBT3904MMBT3904SOT-23
Q7MMBT2222A/SOT_0_SOT-23_MMBT3904MMBT3904SOT-23
U1ESP8080_11_SMD_32P-L21_2-W18_0_ESP32-C5-WROOM-1_ESP32-C5-WROOM-1ESP32-C5-wroom-1SMD_32P-L21_2-W18_0_ESP32-C5-WROOM-1
U2LM317T-LIE_U7_SOT-223_AMS1117-3.3AMS1117-3.3SOT-223
U3GT30L32S4W_U9_6_SOP-8_EP_SY8205FCC,SO8ESY8205FCC,SO8ESOP-8_EP
U4GT30L32S4W_U9_6_SOP-8_S8002S8002SOP-8
谢谢分享 谢谢分享 6666666666666 谢谢谢谢分享 多谢分享 好好学习天天向上
