星宸科技SSD2355挂DDR4 AI开发板 Comake Pi D1 四层PCB和原理图等资料
PCB 原理图。等资料一起打包。回复可见下载
**** Hidden Message *****
NamePart TypePCB DecalValue
CON4USB2.0_TYPEA_90DUSB-4P-AUSB2.0_TypeA_90D
CON5SMD_USB_TYPEAB_0MICRO-USB-5F-B-SZ22MCH-051T-126L1
CON8MIPI_3FPC40PIN-0.5MMAMIPI
CON9HEADER_20X2_3FPC_6PINFPC_6PINB_Up_Type
CON10HEADER_1X4-2MM_180DB2.0V-L4PRED Wafer/2.0mm/1*4p/180D/Male
CON11HEADER_1X4-2MM_180DB2.0V-L4PRED Wafer/2.0mm/1*4p/180D/Male
CONR1RJ45_0JACK-12P-RJ45RJ45_1X1-90D
CONR2RJ45_0JACK-12P-RJ45RJ45_1X1-90D
D1DIODE_SCHOTTKY31_1SOD123DC52C24
D2DIODE_1SOD-323HEB5819WS
D3DIODE_1SOD-323HEB5819WS
D7DIODE_1DO-214ACSS24
D11DIODED0402_0.55X0.6NC/DCE0510D2
D12DIODED0402_0.55X0.6NC/DCE0510D2
D13DIODED0402_0.55X0.6NC/DCE0510D2
D14DIODED0402_0.55X0.6NC/DCE0510D2
D15DIODED0402_0.55X0.6NC/DCE0510D2
D16DIODED0402_0.55X0.6NC/DCE0510D2
D19DIODE_0SOD-523NC/AZ5123-01F
D20DIODE_0SOD-523NC/AZ5123-01F
D23DIODE_0DFN1006DCE0310D2
D24DIODE_0DFN1006DCE0310D2
D25DIODE_0DFN1006DCE0310D2
D26DIODE_0DFN1006DCE0310D2
D32DIODE_1SOD-323HEB5819WS
D38DIODE_0DFN1006DCE0310D2
D39DIODE_0DFN1006DCE0310D2
D40DIODE_0DFN1006DCE0310D2
D41DIODE_0DFN1006DCE0310D2
D42DIODE_ZENERSOD123DC52C3V6
D43DIODE_1DO-214ACNC/SS24
D45DIODE_ZENERSOD123NC/DC52C3V6
D48DIODE_1SOD-323HEB5819WS
DEM1DIODE_SCHOTTKY31_1SOD-123-DIODENC/1N5819HW/B130LAW-7-F
EC1C-DIP_470UF/25VCE-3.5X8470uF/50V
EC2C-DIP_470UF/25VCE-3.5X847uF/50V
ECEM1C-DIP_470UF/25VCE-3.5X8NC/220uF
F1FUSE_24V/_5AFB-12100R
F2FUSE_24V/_5AFB-12100R
FB1L0402_0L0402FB_60R_300mA
FB2BEADR04020R
IR5IR/RX_MSTARIRIR/RX
J4SMA-3PIN_0KK23011-02-7HNC/IPEX1
J5CON36_1FPC-36-0.5MM-BHBS36-05-V
J6CON36_1FPC-36-0.5MM-BHBS36-05-V
J7CON6_0HCON6-DIP-1.25CON6
J8AIC1734-XXPU_3FPC10-0.5-2CON10-0D5
J9AIC1734-XXPU_3FPC10-0.5-2CON10-0D5
JP1HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP2HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP3HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP4HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP5HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP14HEADER4X10JP-10X4HEADER4X10
JP15HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP16CON20AJP-2X10BBH-20P/Box Header/2.54mm/2*10p/180D/Male
JP173CON100_3JP-1X4NC/Header/2.54mm/1*4p/180D/Male
JP18HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP19HEADER_2_0JP-1X6SAR Header/2.54mm/180D/Male
JP1033CON100_3JP-1X4Header/2.54mm/1*4p/180D/Male
JP184HEADER_2_0JP-1X6NC/Header/2.54mm/1*6p/180D/Male
JP185HEADER_1JP10X3HEADER10X3
JP187HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
JP188HEADER_2_0JP-1X6NC/Header/2.54mm/1*6p/180D/Female/WOS
JPR1HEADER_4_0JP-1X2NC/Header/2.54mm/1*2p/180D/Male
JPR2HEADER_4_0JP-1X2NC/Header/2.54mm/1*2p/180D/Male
JPSD1HEADER_4_0JP-1X2Header/2.54mm/1*2p/180D/Male
L1CHOKE_4.7UH/4.1A-L8.0W8.0H4.0AMPI0420ED1uH/AMPI0420ED1R0MTHB4
L3CHOKE_4.7UH/4.1A-L8.0W8.0H4.0AMPI0420ED1uH/AMPI0420ED1R0MTHB4
L4CHOKE_4.7UH/4.1A-L8.0W8.0H4.0DFE20162.2uH/DFE201610E-2R2M
L5CHOKE_4.7UH/4.1A-L8.0W8.0H4.0DFE20161uH/DFE201610E-1R0M
L6CHOKE_4.7UH/4.1A-L8.0W8.0H4.0DFE20161uH/DFE201610E-1R0M
L8CHOKE_4.7UH/4.1A-L8.0W8.0H4.0AMPI0630ED2.2uH/AMPI0630ED2R2MTHB4
L11CHOKE_4.7UH/4.1A-L8.0W8.0H4.0DFE32254.7uH/DFE322512F-4R7M
L96L/0402L0402NC/2nH
L97L/0402L0402NC/1.2nH
LEDSD1LED_0LED-0603LED/GREEN
LR1INDUCTORL04020R
LR2INDUCTORL04020R
LR3INDUCTORL04020R
LR4INDUCTORL04020R
LR5INDUCTORL04020R
LR6INDUCTORL04020R
M1T_POINT_RMAKTP
M2SD-55091-006-80SD-55091-8055091-0874
M3T_POINT_RMAKTP
M4T_POINT_RMAKTP
M5T_POINT_RMAKTP
MIC1MIC_0DIP1X02PM-80-VMIC_1
MIC2MIC_0DIP1X02PM-80-VMIC_1
MIC3MIC_0DIP1X02PM-80-VMIC_1
Q1SMD_NMOS_SOT-23DGS_1SOT-23NC/DC3401
Q2MMBT3904_SOT23-3_1SOT-23NC/MMBT3904
Q6IRLML2502_0SOT-23DGS2N7002
Q8SMD_NMOS_SOT-23DGS_1SOT-23DC3407AH
Q9SMD_NMOS_SOT-23DGS_1SOT-23DC3401
Q12MMBT3904_SOT23-3_1SOT-23MMBT3904
Q13SMD_NMOS_SOT-23DGS_1SOT-23DC3401
Q14SMD_NMOS_SOT-23DGS_1SOT-23DC3401
Q22IRLML2502_0SOT-23DGS2N7002
Q23IRLML2502_0SOT-23DGS2N7002
Q24IRLML2502_0SOT-23DGS2N7002
Q25IRLML2502_0SOT-23DGS2N7002
QR1IRLML2502_0SOT-23DGS2N7002
QR2IRLML2502_0SOT-23DGS2N7002
QSD11SMD_NMOS_SOT-23DGS_1SOT-23DC3401
S1HOLE-V8_1H6D3NC/H6D3
S2HOLE-V8_1H6D3NC/H6D3
S3HOLE-V8_1H6D3NC/H6D3
S4HOLE-V8_1H6D3NC/H6D3
S5SW_PUSHBUTTON_0SW2PKEY
S6SW_PUSHBUTTON_0SW2PKEY
S7SW_0SW_6P_2.54MMSW_6P
SD1SKTSD-KALER-TF01A-K3SK10056619_WGQSK10056619
SPK_L1HEADER_1X4-2MM_2DIP1X02PM-80-VCON2-DIP-2.0mm
SPK_R1HEADER_1X4-2MM_2DIP1X02PM-80-VCON2-DIP-2.0mm
SW1ROCKER_SWITCHESSW-2P-MRA1KKAT0BRocker Switch
TR110/100BASE-TX_LAN_MAGNETICIC-16P-10_100BASEHST-0041SAR
TR210/100BASE-TX_LAN_MAGNETICIC-16P-10_100BASEHST-0041SAR
U1ETA3417/TMI3411SOT23-5PTMI3411U
U3ETA3417/TMI3411SOT23-5PTMI3411U
U4LDO_ID9306-AD_300MA_1SOT23-5PTMI3411U
U5LDO_ID9306-AD_300MA_1SOT23-5PTMI3411U
U6LDO_ID9306-AD_300MA_1SOT23-5PTMI3411
U7ADP1610_7SOT23-5PTMI6030-33
U8ADP1610_7SOT23-5PTMI6050-25
U9BL8079AGCB5TR_0SOT23-5PNC/BL8079AGCB5TR
U10ADP1610_7SOT23-5PNC/TMI6030-33
U11ADP1610_7SOT23-5PNC/TMI6030-18
U12WIFI_1WF-MODULE-6WF-MODULE-6
U14TMI6263BHSOT23-5PTMI6263BH
U15ADP1610_7SOT23-5PNC/TMI6050-18
U16MIC4576_2IC-6P-TSOT23FP6755S6CTR
U39P3P_EXTDRAM_BGA14X14_84IC385-P065-14X14BGA14x14
U41ETA8156_0SOT23-6TMI3255S
UA1CS8138S/LTK5150SOP-8LCS8138S/LTK5150
UA2CS8138S/LTK5150SOP-8LCS8138S/LTK5150
UEM1AM29LV160_2IC-0.5MM153P-FBGABWCTARJ11X32G
UF124C08_0SOP8A-150+208GD25Q128E/3V3
UF224C08_3SOP8-150+208A9GD5F1GM7UEYIG/1Gb-3V3
UM1DDR4_DRAMIC-96P-TFBGA-DDR4-DRAMDDR4_DRAM/ NT5AD512M16C4-JRI
UR1IP101A_2IC-32P-QFN-4X4-P04IP101GR
UR2IP101A_2IC-32P-QFN-4X4-P04IP101GR
VR1DIODE_BI-DIR_TRIGR0402NC/DCE0510D2LC
VR2RESISTOR_VARVR-TC33X-110K
Y1OSC-20MHZ_HALF_0XTALS-2_5X3_2MMCrystal/; /3.2x2.5mm/YIC-24M18PI/XT324-10/20
Y2CRYSTAL-2PIN_0XTALS-SMD-3215DST310S/32.768KHz
YR1OSC-20MHZ_HALF_0XTALS-2_5X3_2MMCrystal/; /3.2x2.5mm/YIC-25M18PI/XT324-10/20
YR2OSC-20MHZ_HALF_0XTALS-2_5X3_2MMCrystal/; /3.2x2.5mm/YIC-25M18PI/XT324-10/20
:):):):):):):):):) good good study, day day up duxz811 发表于 2026-11-10 11:19
:):)66666666666 very good 感谢分享 这个不错,感谢分享 :)星宸科技SSD2355挂DDR4 AI开发板
