poiu0766 发表于 2014-10-27 17:34
电子硬盘方案PCB图
发出来给大家看看的。
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
NamePCB DecalValuePart TypeC1C060322pF/0603CAP_NP_2C15C040210nF/0402CAP_NP_3C16C040210nF/0402CAP_NP_3C17C040210nF/0402CAP_NP_3C18C040210nF/0402CAP_NP_3C29C040215pF/0402CAP_NP_2C30C040215pF/0402CAP_NP_2C32C06031uF/0603CAP_NP_4C61C080510uF/0805CAP_NP_2C62C04020.1uF//0402CAP_NP_2C63C04020.1uF/0402CAP_NP_2C64C04020.1uF/0402CAP_NP_2C65C080510uF/0805CAP_NP_2C66C04020.1uF/0402CAP_NP_2C67C04020.1uF/0402CAP_NP_2C68C04020.1uF/0402CAP_NP_2C69C080510uF/0805CAP_NP_2C70C04020.1uF/0402CAP_NP_2C71C04020.1uF/0402CAP_NP_2C72C04020.1uF/0402CAP_NP_2C73C080510uF/0805CAP_NP_2C74C04020.1uF/0402CAP_NP_2C75C04020.1uF/0402CAP_NP_2C76C04020.1uF/0402CAP_NP_2C77C080510uF/0805CAP_NP_2C78C04020.1uF/0402CAP_NP_2C79C04020.1uF/0402CAP_NP_2C80C04020.1uF/0402CAP_NP_2C81C080510uF/0805CAP_NP_2C82C04020.1uF/0402CAP_NP_2C83C04020.1uF/0402CAP_NP_2C84C04020.1uF/0402CAP_NP_2C85C080510uF/0805CAP_NP_2C86C04020.1uF/0402CAP_NP_2C87C04020.1uF/0402CAP_NP_2C88C04020.1uF/0402CAP_NP_2C89C080510uF/0805CAP_NP_2C90C04020.1uF/0402CAP_NP_2C91C04020.1uF/0402CAP_NP_2C92C04020.1uF/0402CAP_NP_2C93C040215pF/0402CAP_NPC94C04020.1uF/0402CAP_NPC95C080510uF/0805CAP_NP_2C96C040215pF/0402CAP_NPC97C04020.1uF/0402CAP_NPC98C080510uF/0805CAP_NP_2C99C120647uF/0805CAP_NPC100C120647uF/0805CAP_NPC101C080510uF/0805CAP_NP_2C102C080510uF/0805CAP_NP_2C103C080510uF/0805CAP_NP_2C104C080510uF/0805CAP_NP_2C105C04020.1uF/0402CAP_NP_2C106C04020.1uF/0402CAP_NP_2C107C04020.1uF/0402CAP_NP_2C108C04020.1uF/0402CAP_NP_2C109C080510uF/0805CAP_NP_2C110C080510uF/0805CAP_NP_2C111C080510uF/0805CAP_NP_2C112C080510uF/0805CAP_NP_2C113C04020.1uF/0402CAP_NP_2C114C04020.1uF/0402CAP_NP_2C115C04020.1uF/0402CAP_NP_2C116C04020.1uF/0402CAP_NP_2C117C080510uF/0805CAP_NP_2C118C080510uF/0805CAP_NP_2C119C04020.1uF/0402CAP_NP_2C120C04020.1uF/0402CAP_NP_2C121C040210uF/0402CAP_NP_2C122C080510uF/0805CAP_NP_2C123C04020.1uF/0402CAP_NP_2C124C04020.1uF/0402CAP_NP_2CON1SATA22P-SMD-MSATA-Male_22PSATA_MALE_5CON2CN_USB_MABMiniBHEADER_4_1F1PS\S3\45321AFUSE_0.5A_SMDFB1L08051uH/0Ohm/L0805INDUCTORFB2L08051uH/0Ohm/L0805INDUCTORJP2SIP-4PDIP_PADSIP_4JP3RSETX3JP-3-200JUMPER_3_200JP4RSETX3JP-3-200JUMPER_3_200L1CHOKE-3155.6uH/GSSQ-315PLD5R6NINDUCTORL2CHOKE-3155.6uH/GSSQ-315PLD5R6NINDUCTORLEDLED-A33PIN LEDLED_8P1TP-0603JP-2/0603JUMPER_2P2TP-0603JP-2/0603JUMPER_2PR3RP41KRES_8P4R_RHNPR4RP41KRES_8P4R_RHNR1R060312K/1%/0603R_2R2R060351K/0402RR3R0603110K/0402RR4R06030/0402RR5R06030/0402RR6R04024.7K/0402RR7R04021M/0402R_2R8R0603100K/0603R_3R9R04024.7K/0402RR20R04024.7K/0402RR21R04024.7K/0402RR22R04024.7K/0402RR23R04024.7K/0402RR24R04024.7K/0402RR25R04024.7K/0402RR26R04024.7K/0402RR27R04024.7K/0402RR28R04024.7K/0402RR29R04024.7K/0402RR30R04024.7K/0402RR31R04024.7K/0402RR32R04024.7K/0402RR33R04024.7K/0402RR34R04024.7K/0402RR35R04024.7K/0402RR36R06031K/0603R_2R38R0603330/0603R_2R39R0402110K/0402R_2R40R0402510K/0402R_2R41R0402100K/0402R_2R42R0402200K/0402R_2TP1SIP-1PTestpinTESTPINU4TSOP48-12X20-SKNAND FlashNAND_FLASH_0U5TSOP48-12X20-SKNAND FlashNAND_FLASH_0U6TSOP48-12X20-SKNAND FlashNAND_FLASH_0U7TSOP48-12X20-SKNAND FlashNAND_FLASH_0U8TSOP48-12X20-SKNAND FlashNAND_FLASH_0U9TSOP48-12X20-SKNAND FlashNAND_FLASH_0U10TSOP48-12X20-SKNAND FlashNAND_FLASH_0U11TSOP48-12X20-SKNAND FlashNAND_FLASH_0U12TSOP48-12X20-SKNAND FlashNAND_FLASH_0U13TSOP48-12X20-SKNAND FlashNAND_FLASH_0U14TSOP48-12X20-SKNAND FlashNAND_FLASH_0U15TSOP48-12X20-SKNAND FlashNAND_FLASH_0U16TSOP48-12X20-SKNAND FlashNAND_FLASH_0U17TSOP48-12X20-SKNAND FlashNAND_FLASH_0U18TSOP48-12X20-SKNAND FlashNAND_FLASH_0U19TSOP48-12X20-SKNAND FlashNAND_FLASH_0U20WDFN-6L-2X2RT8010PQW/WDFN 6L 2x2MIC293XX_6U21WDFN-6L-2X2RT8010PQW/WDFN 6L 2x2MIC293XX_6U22TFBGA211-12X12JMF602/TFBGA/211 ballsJMF602_25Y1OSC-3X230MHz/NXK-32/3.2x2.5x1.5CRYSTAL_0
老吴 发表于 2014-10-27 17:44
好资料
htcunlocker 发表于 2014-10-27 18:14
等级不够.....:(
slim443 发表于 2014-10-27 18:33
还有样板照片
水很深我 发表于 2014-10-27 18:35
bidinghong 发表于 2014-10-27 19:41
好资料
bidinghong 发表于 2014-10-27 19:42
谢谢分享
漂泊 发表于 2014-10-27 20:16
子非鱼721 发表于 2014-10-27 20:38
学习一下 顶一个
jxhuanglj 发表于 2014-10-27 21:14
谢谢楼主分享!
页: [1] 2 3 4 5 6
查看完整版本: 电子硬盘方案PCB图
