DragonBoard410c Schematics
DragonBoard410c SchematicsOS Support: Android 5.1 (Lollipop) on Linux Kernel 3.10, Linux based on Debian 8.0, and Windows 10 IoT CoreCPU: Quad-core ARM® Cortex® A53 at up to 1.2 GHz per core with both 32-bit and 64-bit supportMemory/storages: 1GB LPDDR3 533MHz / 8GB eMMC 4.5 / SD 3.0 (UHS-I)Graphics: Qualcomm Adreno 306 GPU with support for advanced APIs, including OpenGL ES 3.0, OpenCL, DirectX, and content securityVideo: 1080p@30fps HD video playback and capture with H.264 (AVC), and 720p playback with H.265 (HEVC)Camera Support: Integrated ISP with support for image sensors up to 13MPConnectivity and Location: Wi-Fi 802.11 b/g/n 2.4GHz, integrated digital coreBluetooth 4.1, integrated digital coreQualcomm® IZat™ location technology Gen8COn-board Wi-Fi, BT and GPS antennaI/O Interfaces: HDMI Full-size Type A connector, one micro USB (device mode only), two USB 2.0 (host mode only), micro SD card slotNote: Micro USB (device mode) and USB 2.0 (host mode) are mutually exclusive and cannot be operated at the same timeExpansion:One 40-pin low speed expansion connector: UART, SPI, I2S, I2C x2, GPIO x12, DC powerOne 60-pin high speed expansion connector: 4L MIPI-DSI, USB, I2C x2, 2L+4L MIPI-CSIFootprint for one optional 16-pin analog expansion connector for stereo headset/line-out, speaker and analog line-in.The board can be made compatible with Arduino using an add-on mezzanine board
看看设计
