NanoPi-2-1507-Schematic
NanoPi-2-1507-SchematicThe NanoPi2 is a high performance ARM Board developed by FriendlyARM for Hobbysts, Makers and Hackers for IOT projects.
It features the Samsung Cortex-A9 Quad Core S5P4418@1.4GHz SoC and 1G 32bit DDR3 RAM.
It has built-in WiFi and Bluetooth which supports 802.11 b/g/n and Bluetooth 4.0. It boots Android and Debian from a TF card.
It integrates an HDMI and LCD interface.
Its adoption of the Raspberry Pi’s GPIO pin header makes it compatible with both Raspberry Pi’s external GPIO modules and Arduino’s shield boards.
Its PCB dimension is 75 x 40 mm.
Features
CPU: S5P4418, 1.4GHzRAM: 1GB DDR3Built in SDIO WiFi and Bluetooth moduleUSB 2.0 Type A x 1Debug Serial Port/UART0 x 1microSD Slot x 2microUSB x 1: for data transmission and power inputLCD Interface: 0.5 mm pitch SMT FPC seat, for full-color LCD (RGB: 8-8-8)HDMI: HDMI 1.4A, Type-A, 1080P60DVP Camera Interface: 0.5mm spacing FPC socket. It includes ITU-R BT 601/656 8-bit, I2C and IOGPIO: 2.54mm spacing 40pin, compatible with Raspberry Pi's GPIO. It includes UART, SPI, I2C, IO etcButton: User Button x 1, Reset Button x 1LED: LED for Power Indication x 1, User LED x 1PCB Dimension: 75 x 40mmPower: DC 5V/2AOS: Android, Debian
不错的
