pcbjia 发表于 2016-6-23 21:45
飞凌 IMX6Q 底板 PCB文件和原理图 共享下载
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BAT_MF621F_2_CON_2PIN_SMT_CON_2CON_2PIN_SMTCON_2PIN_SMTCN12XCN18_2MM_DIP_3_2XCN18_2MM_DIP2.0 DIP 1802XCN18_2MM_DIPCN22XCN10_2MM_DIP_3_2XCN10_2MM_SMDDIP 1802XCN10_2MM_SMDCN4DC_090050_DC_090050_DC_090050DC_090050DC_090050COM1PH_4A_USB_4_CAN-3P_2.05PIN2.0 5PINCAN-3PCOM2LBST_CON254_0_JUMPER3_2_54MM_3P3PINJUMPER3_2_54MMCON3SF7W006S1A_CON_SIM_CD_2P54MM_IOCON 6 SIM CARDCON_SIM_CD_2P54MMCON5CONN_HDR_4X1_BAT-4PIN_IO_NCCNC CON_1X4BAT-4PIND1DIODESCHOTTKY_CD214C_B330B330CD214CD2BIDIRECTIONESD_SOD-923_NP_ESD5ESD5B5VLSOD-923_NPD3BIDIRECTIONESD_SOD-923_NP_ESD5ESD5B5VLSOD-923_NPD4BIDIRECTIONESD_SOD-923_NP_ESD5ESD5B5VLSOD-923_NPD5BIDIRECTIONESD_SOD-923_NP_ESD5ESD5B5VLSOD-923_NPD6LED_LED_0603_IC_NCLED_ORANGENC LED_ORANGELED_0603D7LED_LED_0603_IC_LED_GREENLED_GREENLED_0603D8LED_LED_0603_IC_LED_ORANGELED_ORANGELED_0603D9LED_LED_0603_IC_LED_YELLOWLED_YELLOWLED_0603D10DIODESCHOTTKY_2_SOD123_IN5819IN5819SOD123D12DIODE_SOD323_IC_BAT54HT1BAT54HT1SOD323D13BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD14BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD15BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD16BIDIRECTIONESD_CD214C_NC SMBJNC SMBJ18CACD214CD17BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD18BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD19BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD20BIDIRECTIONESD_CD214C_NC SMBJ1NC SMBJ18CACD214CD21DIODESCHOTTKY_SMC_B330B330SMCD22BIDIRECTIONESD_R-R0402_NC ESD5NC ESD5B5VLR-R0402D23DIODESCHOTTKY_SOD123B_SS32ASS32ASOD123BD24DIODESCHOTTKY_2_SOD123_MBR0540MBR0540SOD123IR1LBST_CON254_3P_JUMPER3_2_54MM_33PINJUMPER3_2_54MMJ13.5MM_AUDIO_JACK_PJ3640_IO_AUDIAudio JackPJ3640J23.5MM_AUDIO_JACK_PJ3640_IO_AUDIAudio JackPJ3640J3CONN_SATA_22P_CON_SATA_22F_XIEM10029364-001LFCON_SATA_22F_XIEMEIJ4CONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19CON19_SDCARD_28X16_SMJ52XCN4_2MM_DIP_0_2XCN3_2MM_DIP_22.0 DIP 1802XCN3_2MM_DIPJ6OV2659_1_FPC24_OV2659OV2659FPC24J7V890-1AX1-A1_0_SI-61001_IO_SI-6si-61001-FSI-61001J9MINI_PCI_LATCH_0_MINIPCIE_52PINCON 2X26 MINI PCIEXPRESSMINIPCIE_52PINJ11USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSBJ12USB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5CON5_MICROUSBJ13CONN_HDMI_19P_TYPE_A_1_HDMI_TYP10029449-001RLFHDMI_TYPE_AJ14FPC10 FOR 9_0.7TOUCH_FPC-10PIN10PIN*0.5FPC-10PIN-1_0MMJP1PH_6A_PH_6A_2.0 6PIN2.0 6PINPH_6AL1BEAD_0_L0603_DISCRETE_120OHM120OHML0603L2IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L3IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L4BEAD_0_L0603_DISCRETE_120OHM120OHML0603L5BEAD_0_L0603_DISCRETE_120OHM120OHML0603L6IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L7IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L8BEAD_0_L0603_DISCRETE_120OHM120OHML0603L9IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L10IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L11IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L12IND_L0603_DISCRETE_100OHM@100M100 OHM@100MHZL0603L15FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L17DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L18DLW43_IND4_CHOKE_0805_DISCRET_1NC 90OHMIND4_CHOKE_0805L19DLW43_IND4_CHOKE_0805_DISCRET_2NC 90OHMIND4_CHOKE_0805L20DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L21DLW43_IND4_CHOKE_0805_DISCRET_3NC 90OHMIND4_CHOKE_0805L22DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L23DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L24DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L25DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L26DLW43_IND4_CHOKE_0805_DISCRETE_NC 90OHMIND4_CHOKE_0805L27FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L28FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L29FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L30FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L31FERRITEBEAD_0_L0603_120R_100MH120R_100MHz_3A_0603L0603L32FERRITEBEAD_0_L0603_120R_100MH120R_100MHz_3A_0603L0603L33COMMON MODEINDUCTOR_FIL-2X1_2-EXD24CD900UFIL-2X1_2-4L34COMMON MODEINDUCTOR_FIL-2X1_2-EXD24CD900UFIL-2X1_2-4L35FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L36FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L37BEAD_0_0603_CC_DISCRETE_120OHM120OHM0603_CCL38INDUCTOR_IND_VLS3012_SM_DISCRET4.7UH SPN3015IND_VLS3012_SML39BEAD_0_C0603_DISCRETE_120OHM120OHMC0603L40INDUCTOR_L0402_NCNCL0402L41INDUCTOR_L0402_NCNCL0402L42DLW43_IND4_CHOKE_0805_DISCRET_3NC 90OHMIND4_CHOKE_0805L43INDUCTOR_POWER_L6020_6.8UH2A6.8uH 2A SPN6020L6020L44FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L45INDUCTOR_L0603_DISCRETE_470OHM470OHML0603L46DLW43_IND4_CHOKE_0805_DISCRET_490OHMIND4_CHOKE_0805L47INDUCTOR_L0603_DISCRETE_470OHM470OHML0603L48FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L49BEAD_0_L0603_DISCRETE_120OHM120OHML0603L50FERRITEBEAD_0_L0603_60R_100M_160R_100MHzL0603L52BEAD_0_L0603_DISCRETE_120OHM120OHML0603L53BEAD_0_L0603_DISCRETE_120OHM120OHML0603L54FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L55FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L56FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L59INDUCTOR_IND_4X4_DISCRETE_1UH1UH SPN252012IND_4X4L60INDUCTOR_IND_4X4_DISCRETE_1UH1UH SPN252012IND_4X4L521INDUCTOR_POWER_VEPD0603_4R7M_2.2.2uH 3A SPN6020VEPD0603_4R7ML522FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L523FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603L526BEAD_0_L0402_DISCRETE_120OHM120OHML0402L527INDUCTOR_L0603_DISCRETE_100OHM100OHML0603L528INDUCTOR_L0603_DISCRETE_100OHM100OHML0603L529INDUCTOR_POWER_IND_5015_2.2UH22.2uH 2A SPN5020IND_5015L530FERRITEBEAD_0_L0603_60R_100MHZ60R_100MHz_3A_0603L0603Q1MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q22N7002_SOT23_IC_2N70022N7002SOT23Q3MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q4MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q5MOSFET_P_SOT23A_SOT23_SI2305SI2305SOT23Q6NPNSOT23A_SOT23_MMBT3904MMBT3904SOT23Q7MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q82N7002_SOT23_IC_2N70022N7002SOT23Q9MOSFETN_0_SOT23_WPM2026WPM2026SOT23Q10MOSFETN_0_SOT23_WPM2026WPM2026SOT23Q11MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q122N7002_SOT23_IC_2N70022N7002SOT23Q13MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q14MOSFET_2N_CHAN_SC70-6_IC_BSS138BSS138DW-7SC70-6Q15MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q162N7002_SOT23_IC_2N70022N7002SOT23Q17MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q182N7002_SOT23_IC_2N70022N7002SOT23Q20NPN_2_SOT23_2N90142N9014SOT23Q21MOSFET_P_SOT23_IC_IRLML6401IRLML6401SOT23Q22SI4435DY_0_SO8_SI4435DYSI4435DYSO8Q23NPN_2_SOT23_2N90142N9014SOT23Q24MOS_0_GDT7_5X5_SDM_GDTGDTGDT7_5X5_SDMQ252N7002_SOT23_IC_AO3400AO3400SOT23Q26SI4435DY_0_SO8_SI4435DYSI4435DYSO8Q27NPN_2_SOT23_2N90142N9014SOT23RT1THERMISTOR_R0402_DISCRETE_10K10KR0402RT2THERMISTOR_R0402_DISCRETE_10K10KR0402SH3RES_SHORT-3_1TO2_SH0603-X2_PIN10SH0603-X2_PIN1TO2SH4RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SH6RES_SHORT-2_SH0805_40_DISCRETE_SOLDER SHORTSH0805_40SW2SW_TACT-SPST-2_SM_KEY6X6_IC_PBPB switchKEY6X6SW3EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_EVQPUA02KKEY6X6X5SW4EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_EVQPUA02KKEY6X6X5SW5EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_EVQPUA02KKEY6X6X5SW6SW_TACT-SPST-2_SM_KEY6X6_IC_PBPB switchKEY6X6TP1TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP2TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP3TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP4TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP5TESTPAD_C035S_IC_TEST POINTTEST POINTC035STP15TESTPAD_C035S_IC_TEST POINTTEST POINTC035STP16TESTPAD_C035S_IC_TEST POINTTEST POINTC035STP17TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP18TESTLOOP_TPAD_020_IO_TPAD_020TPAD_020TPAD_020TP19TESTPAD_HOLE3_2X6_IC_TEST POINTEST POINTHOLE3_2X6TP20TESTPAD_HOLE3_2X6_IC_TEST POINTEST POINTHOLE3_2X6TP21TESTPAD_HOLE3_2X6_IC_TEST POINTEST POINTHOLE3_2X6TP22TESTPAD_HOLE3_2X6_IC_TEST POINTEST POINTHOLE3_2X6TVS1DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS20DIODE_TVS_BIDIR_CD214C_IC_ESD9BESD9B3.3ST5GCD214CTVS21DIODE_TVS_BIDIR_CD214C_IC_ESD9BESD9B3.3ST5GCD214CTVS22DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS23DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS24DIODE_TVS_BIDIR_SOD-923_NP_IC_EESD9B3.3ST5GSOD-923_NPTVS25DIODE_TVS_BIDIR_CD214C_IC_ESD9BESD9B3.3ST5GCD214CTVS26DIODE_TVS_BIDIR_CD214C_IC_ESD9BESD9B3.3ST5GCD214CU1IMX6Q_CORE_CON_B_0_IMX6_IO_BOARIMX6Q_CORE_CON_BIMX6_IO_BOARDU2WM8962_BGA_49P_CUST_BGA49_0P5_3WM8962BGA49_0P5_3P62X4U3NC7WZ17_SC70_6LEAD_IC_NC7WZ17NC7WZ17SC70_6LEADU4ADMP421_LGA5_LGA5_CAV_4P1X3P1MMNC ADMP421BLGA5_CAV_4P1X3P1MMU5ADMP421_LGA5_LGA5_CAV_4P1X3P1MMNC ADMP421BLGA5_CAV_4P1X3P1MMU6ESD ARRAYDFN10_DFN10_*ESDA6V8U*ESDA6V8UDDFN10U7MAX11801_TQFN_12P_QFN12_IC_MAX1MAX11801QFN12U8NLSV1T34_ULLGA6_1P45X1_0P5MM_ICNLSV1T34ULLGA6_1P45X1_0P5MMU9GL850G_QFN28_2_GSL_QFN28_GL850GGL850GGSL_QFN28U10AR8031_QFN48_QFN48_0P4_6X6MM_EPAR8031QFN48_0P4_6X6MM_EPADU11RTL8723AS_RTL8723AS_RTL8723ASRTL8723ASRTL8723ASU12EUP3476_SOIC-8EDP_EUP3476DIR1EUP3476DIR1SOIC-8EDPU13MODULE_AH-1613_MODULE_AH-1613_IVK-1613MODULE_AH-1613U141G126_SOT353_IC_M74VHC1GT126DF1M74VHC1GT126DF1GSOT353U16MIC2526_8P_SO8_IC_MIC2026-1YMMIC2026-1YMSO8U17SN74LVC2G126DCTR_SSOP8_IC_SN74LSN74LVC2G126SSOP8U18FT232RQ_QFN32_MC1320X_IC_FT232RFT232RQQFN32_MC1320XU19NLSV1T34_ULLGA6_1P45X1_0P5MM_ICNLSV1T34ULLGA6_1P45X1_0P5MMU20TJA1040T_SO_8P_SO8_1P27_4X5_IC_TJA1040TSO8_1P27_4X5U21ADM2587_ADM2587_ADM2587ADM2587ADM2587U24CM2020_TSSOP_38P_TSSOP38_0P5_4PCM2020TSSOP38_0P5_4P5X9P8U25MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QQFN5X3_0P5_3X3U26MAX202EEUE_SON_16_NCMAX232ECSNC MAX232ECSESON_16U27MAX202EEUE_SON_16_NCMAX232ECSENC MAX232ECSESON_16U30MAX8903A_TQFN_28P_TQFN28_0P4_4XMAX8903CTQFN28_0P4_4X4U31MAX8903A_TQFN_28P_TQFN28_0P4_4XMAX8903CTQFN28_0P4_4X4U95TCXO RAKON SMD4P_TCXO325_RAKONIT2205BE/16.368MHzTCXO325U96GPS-RF_GPS-ANT_GPS-RFGPS-RFGPS-ANTU529EUP3485_2_SOIC-8EDP_EUP3485EUP3485SOIC-8EDPU531COM10PIN_0_COM10PIN-B_COM10PINcom10pinCOM10PIN-BU532COM10PIN_0_COM10PIN-B_COM10PINcom10pinCOM10PIN-BU533COM10PIN_0_COM10PIN-B_COM10PINcom10pinCOM10PIN-BU534RS485_0_RS485-2P_RS485RS485RS485-2PU535CON4_1_IPEX_IPEXIPEXIPEXU536CON20PIN-B_2XCN10_2MM_SMD_CON20CON20PIN-B2XCN10_2MM_SMDU537COM10PIN_0_COM10PIN-B_COM10PINcom10pinCOM10PIN-BU538COM10PIN_0_COM10PIN-B_COM10PINcom10pinCOM10PIN-BU539EUP2573_0_SOT23_5_EUP2573EUP2573SOT23_5U540SPKER_SPEAKER_2-54M_SPKERSPKERSPEAKER_2-54MU541SPKER_SPEAKER_2-54M_SPKERSPKERSPEAKER_2-54MU542SN74LVC1G00_SOT23_5_SN74LVC1G00SN74LVC1G00SOT23_5U543RS485_0_RS485-2P_RS485RS485RS485-2PUSB1USB_AF_SIDE_DIP_USB_AF_SIDE_DIPUSB_AF_SIDE_DIPUSB_AF_SIDE_DIPUSB2USB_AF_SIDE_DIP_USB_AF_SIDE_DIPUSB_AF_SIDE_DIPUSB_AF_SIDE_DIPY1CRYSTAL_12M_20PPM_0_XTAL4_SX_3212MHzXTAL4_SX_3225Y2XTAL_13Y_XTAL4_SX_3225_IC_25MHZ25MHZXTAL4_SX_3225
**** Hidden Message *****
xzcxnihd 发表于 2016-6-23 23:11
好东西,谢谢楼主分享了
yangjing29 发表于 2016-6-24 17:14
路过看一下
ernvhehe 发表于 2016-6-30 15:43
下来看看,谢谢楼主
rongzhai 发表于 2016-7-4 10:57
老大真厉害
cwooye 发表于 2016-7-12 11:02
你这个不是pads9.5格式的啊,退我金币
韬铸 发表于 2016-7-13 16:05
看一下,可惜没有核心板
huangliang0108 发表于 2016-7-15 22:30
好东西 谢谢楼主分享
jianping724 发表于 2016-7-15 23:15
很好???
longma668 发表于 2016-7-21 15:03
谢谢楼主
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 飞凌 IMX6Q 底板 PCB文件和原理图 共享下载
