老吴 发表于 2016-12-6 23:43
全球首发-展讯最新SC7731C 手机 PCB文件和原理图共享下载
SC7731C   是展讯新推出的手机CPU 。
NamePart TypePCB DecalValueANT0400CON-SPRING-T105-11F2RCON-SPRING-T105-11F2RANT7203CON-SPRING-TP-220-000CON_SPRING_TP-220-000ANT7204CON-SPRING-TP-220-000CON_SPRING_TP-220-000D4100DIODE-SCHOTTKY-WSB5543W-2/TRSOD_FL_2412_H070D5100DIODE-LED-YELLOW-LTW-M670ZVS-BTDIODE-LED-YELLOW-LTW-M670ZVS-BTYELLOWD6100DIODE-ZENER-PZ3D5V1HSOD_2513_H110FB3100BEAD-1000-OHM-100MHZ-100MA-0402SL04021000ohm/100MHz/100mAFB3101BEAD-600-OHM-100MHZ-700MA-0603SL0603-S600ohm@100MHz 700mAFB3106BEAD-1000-OHM-100MHZ-100MA-0402SL04021000ohm/100MHz/100mAFB3107BEAD-1000-OHM-100MHZ-100MA-0402SL04021000ohm/100MHz/100mAFB3108BEAD-1000-OHM-100MHZ-100MA-0402SL04021000ohm/100MHz/100mAFB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mAFB7200RES-0-0201SR02010FD6201NC-FIDUCIALMARKPAD-FIDFD6202NC-FIDUCIALMARKPAD-FIDFD6203NC-FIDUCIALMARKPAD-FIDFD6204NC-FIDUCIALMARKPAD-FIDJ0400CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1J0401CON-RF-ARF00-0285011-0001CON_RF_ARF00-0285011-0001J0402CON-RF-ARF00-0285011-0001CON_RF_ARF00-0285011-0001J3100CON-EAR-J301-R05GA-MZL2CON-EAR-J301-R05GA-MZL2J3103CON-SPRING-21-111-00200-2CON-SPRING-21-111-00200-2J3104CON-SPRING-21-111-00200-2CON-SPRING-21-111-00200-2J4100CON-FPC-196200-25041_REVCON-FPC-196200-25041_REVJ4107CON-FPC-196243-06041-3CON-FPC-196243-06041-3J5100CON-FPC-196200-25041_REVCON-FPC-196200-25041_REVJ5101CON-BTB-F-OK-22NF030-04CON-BTB-F-OK-22NF030-04J6100CON-BAT-PAN30-03193-S118CON-BAT-PAN30-03193-S118J6200CON-USB-MICRO-HY07-AB0720CON-USB-MICRO-HY07-AB0720J6201CON-BTB-M-AXT640224_CWCON_BTB_M_AXT640224_CWJ6400SOCKET-SIM-CAF99-08153-010605SOCKET-SIM-CAF99-08153-010605J6402SOCKET-SIM-CAF99-08153-010605SOCKET-SIM-CAF99-08153-010605J6500SOCKET-TFLASH-CAF11-08153-011401SKT_TFLASH_CAF11-08153-011401J7200CON-RF-SWITCH-MM8030-2610RK0CON-RF-SWITCH-MM8030-2610RK0L0300IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uHL0301IND-POWER-1.0UH-MLP2520W1R0MIND_POW_MLP2520_H1001.0uHL0302IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uHL0303IND-POWER-1.0UH-MLP2520W1R0MIND_POW_MLP2520_H1001.0uHL0305IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uHL0400IND-NF-0201IND-NF-0201NFM6600MOTOR-F102730-15QPAD_2_P300_R200X400MIC3100AUDIO-MIC-OF-F15PD42-11EPAUDIO-MIC-OF-F15PD42-11EPMIC3101AUDIO-MIC-OB-F15LX44-1290-RCEPAUDIO-MIC-OB-F15LX44-1290-RCEP(NF)Q6100TRIODE-PNP-WPT2E33-3/TRSOT-893AQ6101FET-N-PNM523T201E0SOT_3_P050_160_H090TP6226CON-SPRING-818009999CON-SPRING-818009999TVS3125TVS-ESD9L5.0ST5GSOD_FL_1006_H040TVS4100TVS-NZQA6V8XV5T1GSOT_FL_5_P050_160_H060(NF)TVS4102MLV-AVLC5S02050SMLV0402(NF)TVS6200TVS-ESD9L5.0ST5GSOD_FL_1006_H040TVS6201TVS-ESD9L5.0ST5GSOD_FL_1006_H040TVS6202TVS-ESD5Z7.0T1GSOD_FL_1608_H070(NF)U0100ASIC-SC7731C-600-0.4BGA_600_P040_1330X1210_H090U0400RF-SW+PA-SKY77592PQFN_28_P073X075_600X600_T387_H100U0401RF-SAW-SAFFB1G95AA0F0AFILTER_5_110X090_H0501950MHz(NF)U0402RF-SAW-DUPLEX-SAYEY1G95HA0F0AFILTER_8_180X140_H060TxRx:1950/2140MHzU0403RF-SAW-DUPLEX-SAYEY1G88CA0B0AFILTER_8_180X140_H060TxRx:1880/1960MHzU0404RF-BALUN-RFBLN2012090BS0T50FILTER_CAF_10_P050_200X125_H105U0405RF-TRANSCEIVER-SR3533GBGAS_49_P040_330X330_H079_SR3533GU0406RF-PA-SKY77761RF-PA-SKYWORKS-3X3-10PINU0407RF-PA-SKY77762RF-PA-SKYWORKS-3X3-10PINU0409RF-PA-SKY77768RF-PA-SKYWORKS-3X3-10PINU0410RF-SAW-DUPLEX-SAYEY897MHA0F0AFILTER_8_180X140_H060TxRx:897.5/942.5MHzU0412RF-SWITCH-EC278QFN2X2-12-P0.5-T0.9X0.9(NF)U0500MEM-NAND+LPDDR2-MT29RZ4C4DZZHGPL-18BGA_162_P050_1150X1300_H080U4105POWER-DC2DC-WD3119E-6/TRSOT_6_P095_280_H130U5200SENSOR-MOTION-LIS3DHPQFN_16_P050_300X300_H100U5202SENSOR-LIGHT+PROX-EPL21822KVWJPSENSOR-LIGHT+PROX-EPL21822KVWJPU7200BT+WIFI+FM+GPS-SR2351CBT+WIFI+FM+GPS-SR2351U7201RF-SAW-DPX-DPX1608LL87R1524ARF-SAW-DPX-1.6X0.8-YAGEO1.5/2.4GHzU7202RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172U7203RF-SAW-SAFFB1G57KE0F0ARF-SAW-1.1X0.91575.42MHzU7204RF-LNA-GPS-BGU8009RF-LNA-GPS-BGU8009U7206RF-SW+PA-2.4G-SR2319ARF-SW+PA-2.4G-SR2319AX020032.768K-Q-SC32S0322070AAAFXTAL_CC_320X150_H08532.768KHzX0401XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDS26MHz(NF)Y7200XTAL-TCXO-26MHZ-1XXB26000MABOSC_CC_250X200_H090_KDS26MHz
老吴 发表于 2016-12-6 23:55
全网首发。网上根本找不到的资料。有需要的下载。没需要的看看图片就好。为了不要随意网上传播。所以RMB 。
我手上持有大量的资料。资料实在太多了, 100个电脑主板,都还没发完, 手机,平板,TVBOX智能电视盒等。差不多有 300G 的资料。具体有多少份,我自己也都不知道。。。 而且有一些资料因为太新了。。 不敢发上来。。
不要问我资料从哪里来,最少没偷,没抢。偷来的也不敢发呀,不然不是找死啊。
我的目标,不断的收集齐所有行业的PCB文件。 所有万一哪天你给公司设计的PCB文件。在逆天PCB论坛出现了,也不要感到奇怪。
秋风式街球 发表于 2016-12-7 06:32
好资料啊
corecouter 发表于 2016-12-7 06:38
单枪舞九州 发表于 2016-12-7 07:45
逆天哦
草帽焦 发表于 2016-12-7 08:15
大赞呀,,
lg0556 发表于 2016-12-7 08:18
bidinghong 发表于 2016-12-7 08:22
好资料
panups 发表于 2016-12-7 08:39
老大猛料真多。
miaomiao 发表于 2016-12-7 08:41
牛B,谢谢
页: [1] 2 3 4 5
查看完整版本: 全球首发-展讯最新SC7731C 手机 PCB文件和原理图共享下载
