矿用隔爆兼本安型摄像仪-矿井用的防爆红外摄像机PCB原理
整套资料齐全。包括程序,说明书结构,评审检查报告,测试报告。全部都有。电源板1
BD1KBP310_SIP4X150_KBP310KBP310SIP4X150CON1CON3X1-7P62MM_DIP_3PIN_5_08V_PSPS-WFR-003DIP_3PIN_5_08D1D-FR107_DIODE_DIP200_50_FR107FR107DIODE_DIP200_50D2D-P6KE200A_DIODE_DIP400_40_P6KEP6KE13ADIODE_DIP400_40D3FUSE_250V_3P15A_F350X150_50_FUSFUSE_250V_3P15AF350X150_50D4D-P6KE200A_DIODE_DIP400_40_P6KEP6KE13ADIODE_DIP400_40D5D-FR107_DIODE_DIP200_50_FR107FR107DIODE_DIP200_50D7D-P6KE200A_DIODE_DIP400_40_P6KEP6KE13ADIODE_DIP400_40D8D-V20100C_V20100C_V20100CV20100CV20100CD9D-P6KE200A_DIODE_DIP400_40_P6KEP6KE13ADIODE_DIP400_40D10D-LL4148_LL4148_LL4148LL4148LL4148D11D-ZMM5245B_DIODE_150X60_ZMM5245ZMM5245BDIODE_150X60J2DIP180-CON2X1-2P54MM_DIP_2PIN_5PS-WF-00020DIP_2PIN_5_08L1INDUCTOR_L1206_1MH_(T:WE480X4401mHL1206L2INDUCTOR_L1206_1MH_(T:WE480X4401mHL1206LF1INS_COM_3.3MH_LF2_INS_COM_3.3MHINS_COM_3.3mHLF2Q3MOSFET-N-60V-7.6A-SUD23N06_TO-2SUD23N06TO-252Q5MOSFET-P--55V--31A-IRF5305_TO-2IRF5305TO-252Q6MOSFET-N-60V-7.6A-SUD23N06_TO-2SUD23N06TO-252Q10LT6106HS5_SOT-25_LT6106HS5LT6106HS5SOT-25Q11D-TL431_SOT-23_TL431TL431SOT-23S2SRX-YI25_SRX-YI20_SRX-YI20SRX-YI20SRX-YI20T1EI28_EI28_EI28EI28EI28U1PC817B_PC817B_PC817BPC817BPC817BU2TOP254YN_TO-220-7C_TOP254YNTOP254YNTO-220-7CU3LM393_SO-8_LM393LM393SO-8U4LM393_SO-8_LM393LM393SO-8
电源板2
CAP4CAP_X_AC275V_100NF_CAP13X6_10_CCAP_X_AC275V_100nFCAP13X6_10CAP8CAP_Y_AC250V_1NF_CAP10_CAP_Y_ACCAP_Y_AC250V_1nFCAP10CAP10CAP_Y_AC250V_1NF_CAP10_CAP_Y_ACCAP_Y_AC250V_1nFCAP10D10DIODE_2_SMA_B340AB340ASMAD11FUSE_250V_3P15A_F350X150_50_FUSFUSE_250V_3P15AF350X150_50D151N4148_SOD-323_1N4148WS1N4148WSSOD-323D16P3100_1_SMA_BS0080MBS0080MSMAD17DIODE TAZ BI-DIR_R1812_BA201NBA201NR1812D18P3100_1_SMA_BS0080MBS0080MSMAD19DIODE TAZ BI-DIR_R1812_BA201NBA201NR1812D20P3100_1_SMA_BS0080MBS0080MSMAD21DIODE TAZ BI-DIR_R1812_BA201NBA201NR1812D24ESD5Z5.0T1_SOD-523_ESD5Z12T1-GESD5Z12T1-GSOD-523D26ESD5Z5.0T1_SOD-523_ESD5Z5.0T1/NESD5Z5.0T1/NCSOD-523D27ESD5Z5.0T1_SOD-523_ESD5Z5.0T1/NESD5Z5.0T1/NCSOD-523D301N4148_SOD-323_1N4148WS1N4148WSSOD-323D31ESD5Z5.0T1_SOD-523_ESD5Z12T1-GESD5Z12T1-GSOD-523FB7FBEAD_1_R0805_FBEADFBEADR0805H1TEST POINT_1_MC40_HOLEHOLEMC40J1CON3_4_DIP_7PIN_5_08_7P 7.62MM7P 7.62mmDIP_7PIN_5_08J2CON10X2_8_DIP-22-2M0_DIP-22-2.0DIP-22-2.0DIP-22-2M0J3CON10X2_8_DIP-22-2M0_CON10X2_8CON10X2_8DIP-22-2M0J7SIP7_9_SIP_5P_1M5_CON5CON5SIP_5P_1M5J8SIP7_6_V4-2M0_V4-2M0V4-2M0V4-2M0J9CON14_PS-WFR-114_CON14CON14PS-WFR-114J10CON4_SIP_4P_1_5-SKT_CON4CON4SIP_4P_1_5-SKTJ12CON14_PS-WFR-114_CON14CON14PS-WFR-114J13SIP7_9_SIP_5P_1M5_CON5CON5SIP_5P_1M5JQ1HFD23_HFD23012-1Z_HFD23/012-1ZSHFD23/012-1ZS/555HFD23012-1ZJQ2HFD23_HFD23012-1Z_HFD23/012-1ZSHFD23/012-1ZS/555HFD23012-1ZL1IND_0603L_L-8M3X8M3_6.8UH/3A-SM6.8uH/3A-SMDRH8D43-6R8ML-8M3X8M3L2INDUCTOR_L1806_BLM41PG750SN1BLM41PG750SN1L1806L3IND_0603L_L-8M3X8M3_6.8UH/3A-SM6.8uH/3A-SMDRH8D43-6R8ML-8M3X8M3L4INDUCTOR_L1806_BLM41PG750SN1BLM41PG750SN1L1806L5IND_0603L_L-8M3X8M3_6.8UH/3A-SM6.8uH/3A-SMDRH8D43-6R8ML-8M3X8M3L6INDUCTOR_L1806_BLM41PG750SN1BLM41PG750SN1L1806L7IND_0603L_L-8M3X8M3_6.8UH/3A-SM6.8uH/3A-SMDRH8D43-6R8ML-8M3X8M3L8INDUCTOR_L1806_BLM41PG750SN1BLM41PG750SN1L1806LF1INS_COM_3.3MH_LF2_INS_COM_3.3MHINS_COM_3.3mHLF2PTC1R_0_R1812_MF-MSMF150/24XMF-MSMF150/24XR1812R116R_R0603_0_(SIP_2P_2_54)0SIP_2P_2_54R117R_R0603_0_(SIP_2P_2_54)0SIP_2P_2_54T1H1102_0_PM-16-12M7X9M4-1M27_PM4PM44-11BGPM-16-12M7X9M4-1M27TP6TESTPIN_TEST_1_GNDGNDTEST_1TP7TESTPIN_TEST_1_GNDGNDTEST_1U2AC127-DC12_2_DIANYUAN3_CFA25S12CFA25S12WDIANYUAN3U6TPS5420_2_SO-8-4M9X6M-1M27_TPS5TPS54331DSO-8-4M9X6M-1M27U10SLVU2.8-4_SO-8-5MX4M-1M27_SLVU2SLVU2.8-4SO-8-5MX4M-1M27U13MAX485EESA_SO-8-4M9X6M-1M27_MAXMAX13085EESASO-8-4M9X6M-1M27U14TCMT1100_0_SMD4-2M8X7M-1M27_TCMTCMT1100SMD4-2M8X7M-1M27U15TCMT1100_0_SMD4-2M8X7M-1M27_TCMTCMT1100SMD4-2M8X7M-1M27U16MAX3221_SO_16_0M65_MAX3221IPWMAX3221IPWSO_16_0M65
联网的网络板部分 KS8995M 主控
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED11DIODE_2_SMA_B340AB340ASMAD12DIODE_3_SMA_B340AB340ASMAGNDTEST POINT SMD1_1.0_STP40_TESTTEST POINT SMD1.0STP40J3SIP7_9_SIP_5P_1M5_CON5CON5SIP_5P_1M5J8HEADER 8_0_DIP_4PIN_3_5_SHORT_PPLTB1.5-02-SF-3.50DIP_4PIN_3_5_SHORTJ10SIP7_6_V4-2M0_V4-2M0V4-2M0V4-2M0L11INDUCTOR_L1806_BLM41PG750SN1BLM41PG750SN1L1806L12IND_0603L_L-8M3X8M3_6.8UH/3A-SM6.8uH/3A-SMDRH8D43-6R8ML-8M3X8M3T2H1102_0_PM-16-12M7X9M4-1M27_PM4PM44-11BGPM-16-12M7X9M4-1M27U7TPS5420_0_SO-8-4M9X6M-1M27_AT24AT24C02SO-8-4M9X6M-1M27U8KS8995M_1_KS8995MA_KS8995MKS8995MKS8995MAU10SLVU2.8-4_SO-8-5MX4M-1M27_SLVU2SLVU2.8-4SO-8-5MX4M-1M27U11SLVU2.8-4_SO-8-5MX4M-1M27_SLVU2SLVU2.8-4SO-8-5MX4M-1M27U122X5 1_0.3GBIT TRANSCEIVER_1X9FI1x9/SC/SIP1X9FIBERU18TPS5420_2_SO-8-4M9X6M-1M27_TPS5TPS54331DSO-8-4M9X6M-1M27U192X5 1_0.3GBIT TRANSCEIVER_1X9FI1x9/SC/SIP1X9FIBERU21LM350/TO3_2_SOT_223_AMS1117/(SOAMS1117/(SOT-223)SOT_223VNET_1V8TEST POINT SMD1_1.0_STP40_TESTTEST POINT SMD1.0STP40Y2CYSTAL-SMD4_XTL3225_25M25MXTL3225
主板部分 TMS320DM6467TZUT1+LCMXO2-1200HC-TG100+TLV320AIC23BPWR
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME1V2TEST POINT_TEST_VCC_1V2VCC_1V2TESTBT1BAT_HB414-IV01E_HB414-IV01EHB414-IV01EHB414-IV01ED6ESD5Z5.0T1_SOD-523_ESD5Z5.0T1ESD5Z5.0T1SOD-523D27DIODE_0_SMA_B1100B1100SMAD30MAX809_SOT23_MAX809R/NCMAX809R/NCSOT23D32DIODE_4_SOD-323_1SS3551SS355SOD-323D34ESD5Z5.0T1_SOD-523_ESD5Z5.0T1ESD5Z5.0T1SOD-523D46D-B320A_SMA_B240AB240ASMAE1FILTER_3_PIN_NFM18C_NFM18CC223RNFM18CC223R1C3/NCNFM18CJ1HEADER 2_SIP_2P_1_27-SKT_HEADERHEADER 2X1.27SIP_2P_1_27-SKTJ2HEADER 6_SIP_6P_1_27W-SKT_HEADEHEADER 6SIP_6P_1_27W-SKTJ5CON10X2_8_DIP-22-2M0_DIP-22-2M0DIP-22-2M0DIP-22-2M0J8CON5_SIP_5P_1_5-SKT_CON5-1.5CON5-1.5SIP_5P_1_5-SKTJ14HEADER 30_USL30_0_4_USL00-30L-CUSL00-30L-CUSL30_0_4J17HEADER 21X2_FPC40_0_5L_FPC40/0.FPC40/0.5LFPC40_0_5LJ22CON10X2_8_DIP-22-2M0_DIP-22-2M0DIP-22-2M0DIP-22-2M0J23SIP7_6_V4-2M0_V4-2M0V4-2M0V4-2M0J24SIP7_6_SIP_4P_1_5-SKT_V4-2M0V4-2M0SIP_4P_1_5-SKTJ25HEADER 7X2_DIP2X7_1414DIP2X7L2L0805_221SN1D_L0805_BLM21PG221SBLM21PG221SN1DL0805Q1ASM811SEUS-T_SOT143_PT7M7811TTBPT7M7811TTBESOT143Q2MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23Q3TLV1117IDCYR_0_SOT-223_TLV1117DTLV1117DCYRSOT-223Q4MMBT3904_SOT-23_MMBT3904MMBT3904SOT-23RN17RESISTOR DIP 8_1_R8-0402_RN8-22RN8-22R8-0402RN19RPACK4_0_R4-0402_RN4-22RN4-22R4-0402U1LCMXO2-1200-TG100_VQ100_LCMXO2-LCMXO2-1200-TG100VQ100U3MEMORY-NAND-128MX8BITS-TSOP48_TK9F1G08U0CTSOP48U6MT47H64M16BT-5E_0_FBGA84_K4T1G1K4T1G164QF-BCF7FBGA84U8DAVINCIHDTMS320DM6467TZUT1BGA_23X23_0P8MMU9AT88SC0104C_SOP8_AT88SC0104CAAT88SC0104CASOP8U12HT1381_1_TSSOP8_S-35390A-T8T1GS-35390A-T8T1GTSSOP8U13TLV320AIC23_TSSOP-28-4M5X9M8-0MTLV320AIC23BPWRTSSOP-28-4M5X9M8-0M65U14S-24C02C_SOP8_S-24C02CI-J8T1US-24C02CI-J8T1USOP8U15RTL8169S_4_QFN32_RTL8201ERTL8201EQFN32Y124MHZ_XTAL24MHzOSC-3225Y233MHZ_XTAL33MHzOSC-3225Y412MHZ_XTAL12MHzOSC-3225Y5OSC4/SM_1_OSC-4-3M2X2M5_27MHZ27MHzOSC-4-3M2X2M5Y7ZTB_3_SSP-T7_32.768KHZ32.768KHzSSP-T7Y825MHZ_XTAL25MHzOSC-3225
有以下所有资料。全部齐全。
KBA127产品ES评审报告.xlsx
工艺部分\KBA127-B0矿用隔爆兼本安型摄像仪作业指导书.xlsx
工艺部分\KBA127量产(MP)阶段制造与检验规范.docx
整机部分\KBA127产品ES试产总结报告.docx
整机部分\KBA127产品参数表_20140718.xlsx
整机部分\kba127整机bom.zip
整机部分\外观检验标准(中星微).pdf
机构部分\KBA127矿用隔爆兼本安型摄像仪.zip
机构部分\KBA127矿用隔爆兼本安型摄像仪外包装图纸.exb
测试报告\KBA127单机功能测试报告.zip
测试报告\KBA127工作稳定性测试报告.xlsx
测试报告\KBA127工频耐压测试报告.xlsx
测试报告\KBA127本安参数测试报告.xlsx
测试报告\KBA127电源波动性测试报告.xlsx
测试报告\KBA127绝缘电阻测试报告.xlsx
测试标准\前端设备高低温测试.pdf
测试标准\前端设备高温高湿测试.pdf
测试标准\振动冲击试验标准.pdf
电路部分\PCB
电路部分\元件datasheet
电路部分\单板BOM
电路部分\原理图
电路部分\器件位置图
电路部分\图纸
电路部分\坐标文件
电路部分\拼版文件
电路部分\PCB\allegro.jrl
电路部分\PCB\allegro.jrl,1
电路部分\PCB\KBA127-8821-CPUB-V1.11-EN.brd
电路部分\PCB\KBA127-8821-CPUB-V1.11-EN.brd.lck
电路部分\PCB\KBA127-8821-NETB-V1.11.brd
电路部分\PCB\KBA127-8821-PWRB-BA-V1.11.brd
电路部分\PCB\KBA127-8821-PWRB-V1.11.brd
电路部分\PCB\signoise.run
电路部分\PCB\signoise.run\case1
电路部分\PCB\signoise.run\cases.cfg
电路部分\PCB\signoise.run\cases.cfg,1
电路部分\元件datasheet\PWR_BA_datasheet
电路部分\元件datasheet\readme.txt
电路部分\元件datasheet\PWR_BA_datasheet\744822222.pdf
电路部分\元件datasheet\PWR_BA_datasheet\c_YXA.pdf
电路部分\元件datasheet\PWR_BA_datasheet\FR107.pdf
电路部分\元件datasheet\PWR_BA_datasheet\irfr5305.pdf
电路部分\元件datasheet\PWR_BA_datasheet\KBP310.pdf
电路部分\元件datasheet\PWR_BA_datasheet\leaddisc_commercial_cd_zh.pdf
电路部分\元件datasheet\PWR_BA_datasheet\LL4148.pdf
电路部分\元件datasheet\PWR_BA_datasheet\lm393.pdf
电路部分\元件datasheet\PWR_BA_datasheet\LT6106.pdf
电路部分\元件datasheet\PWR_BA_datasheet\MKP_B32671Z_673Z.pdf
电路部分\元件datasheet\PWR_BA_datasheet\P6KE6V8(C)A - P6KE400(C)A.pdf
电路部分\元件datasheet\PWR_BA_datasheet\PC817B.pdf
电路部分\元件datasheet\PWR_BA_datasheet\SUD23N06.pdf
电路部分\元件datasheet\PWR_BA_datasheet\TDK CK45.pdf
电路部分\元件datasheet\PWR_BA_datasheet\TL431BMSDT.pdf
电路部分\元件datasheet\PWR_BA_datasheet\TOP252-262.pdf
电路部分\元件datasheet\PWR_BA_datasheet\V20100C.pdf
电路部分\元件datasheet\PWR_BA_datasheet\ZMM5221B - ZMM5267B.pdf
电路部分\单板BOM\KBA127-8821-CONB-V1.11-BOM.xlsx
电路部分\单板BOM\KBA127-8821-CPUB-V1.11-BOM.xlsx
电路部分\单板BOM\KBA127-8821-NETB-V1.11-BOM.xlsx
电路部分\单板BOM\KBA127-8821-PWRB-BA-V1.11-BOM.xlsx
电路部分\单板BOM\KBA127-8821-PWRB-V1.11-BOM.xlsx
电路部分\原理图\KBA127-8821-CPUB-V1.11-EN.DSN
电路部分\原理图\KBA127-8821-NETB-V1.11.DSN
电路部分\原理图\KBA127-8821-PWRB-BA-V1.11.DSN
电路部分\原理图\KBA127-8821-PWRB-V1.11.DSN
电路部分\器件位置图\KBA127-8821-CONB-V1.11
电路部分\器件位置图\KBA127-8821-CPUB-V1.11
电路部分\器件位置图\KBA127-8821-NETB-V1.11
电路部分\器件位置图\KBA127-8821-PWRB-BA-V1.11
电路部分\器件位置图\KBA127-8821-PWRB-V1.11
电路部分\器件位置图\KBA127-8821-CONB-V1.11\KBA127-8821-CONB-V111-BOTTOMSILK.pdf
电路部分\器件位置图\KBA127-8821-CONB-V1.11\KBA127-8821-CONB-V111-TOPSILK.pdf
电路部分\器件位置图\KBA127-8821-CPUB-V1.11\KBA127-8821-CPUB-V111-BOTTOMSILK.pdf
电路部分\器件位置图\KBA127-8821-CPUB-V1.11\KBA127-8821-CPUB-V111-TOPSILK.pdf
电路部分\器件位置图\KBA127-8821-NETB-V1.11\KBA127-8821-NETB-V111-BOTTOMSILK.pdf
电路部分\器件位置图\KBA127-8821-NETB-V1.11\KBA127-8821-NETB-V111-TOPSILK.pdf
电路部分\器件位置图\KBA127-8821-PWRB-BA-V1.11\KBA127-8821-PWRB-BA-V111-BOTTOMSILK.pdf
电路部分\器件位置图\KBA127-8821-PWRB-BA-V1.11\KBA127-8821-PWRB-BA-V111-TOPSILK.pdf
电路部分\器件位置图\KBA127-8821-PWRB-V1.11\KBA127-8821-PWRB-V111-BOTTOMSILK.pdf
电路部分\器件位置图\KBA127-8821-PWRB-V1.11\KBA127-8821-PWRB-V111-TOPSILK.pdf
电路部分\图纸\cpub
电路部分\图纸\netb
电路部分\图纸\pwrb+conb
电路部分\图纸\pwrb_ba
电路部分\图纸\cpub\KBA127-8820-CPUB-V1.11-EN.DSN
电路部分\图纸\cpub\KBA127-8821-CPUB-V1.11-EN修改建议.xls
电路部分\图纸\cpub\KBA127-8821-CPUB-V111.brd
电路部分\图纸\netb\KBA127-8821-NETB-V1.11.brd
电路部分\图纸\netb\KBA127-8821-NETB-V1.11.DSN
电路部分\图纸\netb\KBA127-8821-NETB-V1.11修改建议.xls
电路部分\图纸\pwrb+conb\KBA127-8821-CONB-V111.brd
电路部分\图纸\pwrb+conb\KBA127-8821-CONB-V111.DSN
电路部分\图纸\pwrb+conb\KBA127-8821-PWRB-V1.11修改建议.xlsx
电路部分\图纸\pwrb+conb\KBA127-8821-PWRB-V111.brd
电路部分\图纸\pwrb+conb\KBA127-8821-PWRB-V111.DSN
电路部分\图纸\pwrb_ba\KBA127-8821-PWRB-BA-V1.11.DSN
电路部分\图纸\pwrb_ba\KBA127-8821-PWRB-BA-V1.11修改建议.xls
电路部分\图纸\pwrb_ba\KBA127-8821-PWRB-BA-V111.brd
电路部分\坐标文件\KBA127-8821-CONB-V1.11_坐标文件.xlsx
电路部分\坐标文件\KBA127-8821-CPUB-V1.11_坐标文件.xls
电路部分\坐标文件\KBA127-8821-NETB-V1.11_坐标文件.xlsx
电路部分\坐标文件\KBA127-8821-PWRB-BA-V1.11_坐标文件.xls
电路部分\拼版文件\KBA127-8821-CONB-V1.11.zip
电路部分\拼版文件\KBA127-8821-CONB-V1.11制板说明.doc
电路部分\拼版文件\KBA127-8821-CPUB-V1.11.zip
电路部分\拼版文件\KBA127-8821-CPUB-V1.11制板说明.doc
电路部分\拼版文件\KBA127-8821-NETB-V1.11.zip
电路部分\拼版文件\KBA127-8821-NETB-V1.11制板说明.doc
电路部分\拼版文件\KBA127-8821-PWRB-BA-V1.11.zip
电路部分\拼版文件\KBA127-8821-PWRB-BA-V1.11制板说明.doc
电路部分\拼版文件\KBA127-8821-PWRB-V1.11.zip
电路部分\拼版文件\KBA127-8821-PWRB-V1.11制板说明.doc
软件部分\AutoSearch_20141119_V2.1.1.7.rar
软件部分\ISP01.113C.0110.V02.F.0.bin
软件部分\KBA127_FPGA.jed
软件部分\KBA127_HD_3.2.0_Build20141219.bin
软件部分\TestTool_20150122_v1.0.6.6.rar
软件部分\UpdateTool_20150107_v1.0.10.14.rar
软件部分\vc710_v3_0_0.upf
附件部分\KBA127(A)矿用隔爆兼本安型摄像仪说明书.doc
附件部分\KBA127矿用隔爆兼本安型摄像仪说明书.doc
附件部分\产品标签设计文件
附件部分\保修卡设计文件
附件部分\合格证设计文件
附件部分\装箱单设计文件
附件部分\产品标签设计文件\KBA127(A)包装信息标贴20141225.pdf
附件部分\产品标签设计文件\KBA127信息标贴作业指导说明.pdf
附件部分\产品标签设计文件\KBA127包装信息标贴20141225.ai
附件部分\产品标签设计文件\KBA127包装信息标贴20141225.pdf
附件部分\产品标签设计文件\信息标贴示意.pdf
附件部分\保修卡设计文件\KBA127(A)保修卡(壹年).ai
附件部分\保修卡设计文件\KBA127保修卡(A)(壹年).pdf
附件部分\保修卡设计文件\KBA127保修卡(壹年).ai
附件部分\保修卡设计文件\KBA127保修卡(壹年).pdf
附件部分\保修卡设计文件\KBA127保修卡作业要求.docx
附件部分\合格证设计文件\KBA127(A)合格证.ai
附件部分\合格证设计文件\KBA127(A)合格证.pdf
附件部分\合格证设计文件\KBA127合格证.ai
附件部分\合格证设计文件\KBA127合格证.pdf
附件部分\合格证设计文件\KBA127合格证制作作业指导说明书.docx
附件部分\装箱单设计文件\KBA127(A)装箱单.pdf
附件部分\装箱单设计文件\KBA127装箱单.pdf
附件部分\装箱单设计文件\装箱单示意图.pdf
所有资料齐全。
不另外设置特别限制。按常规只要2级就能下载了。回复可见。
**** Hidden Message *****
整套资料齐全。有兴趣的下载。这个机子成品图片网上已经能找到了。已经量产了。
虽然一直有人从论坛上搬东西到自己网站上,本来想设RMB 下载的。不过后来想想还是算了。毕竟偷过去的东西,大家都不支持。骂声一片。随便搬吧。不过账号被我检测到就照封不误。。
随便搬,资料也没我多。所以就不设RMB 了。只要回复就能下载。 牛人出马... 标准式的好资料,谢谢分享!!!
回 老吴 的帖子
老吴:所有资料齐全。
不设限制下载。只要2级就能下载了。回复可见。
....... (2017-02-22 10:51) images/back.gif
谢谢分享,学习学习 看着就很牛逼 多谢老大的分享。。好牛逼的资料 一定要看一下
