在上4K高清电视主板 RTD2796 +TPA3110LD2 方案PCB 原理图+源码程
NamePart TypePCB DecalValueCN11PHONEJACK_STEREO_SW_8AUDIO-DW8.3X14.5Line inCN208_HEADER_1JP-H4X2.0NC/4X2.0CN218_HEADER_1JP-H4X2.0NC/4X2.0CN103CON5_33PIN/2.0MM_NO-TESTPAD3Pin/2.0MMCN201HEADER_4_62PIN/2.0MM_NO-TESTPAD2Pin/2.0mmCN203HEADER_4_62PIN/2.0MM_NO-TESTPAD2Pin/2.0mmCN602DVI_0DVI-W2474320-1004CNF2FI-RE41S-HF_1FIRE-41MR-0.5NCCNF6FI-RE41S-HF_5FIRE-51MR-0.5-SLK-AWF23-400-513CCON4HEADER_7X2_28PIN/2.0MM_NO-TESTPAD8pin/2.0MMCON5HEADER_7X2_345PIN/2.0MM_NO-TESTPAD5pin/2.0MMCON11HEADER_7X2_112PIN/2.0MM_NO-TESTPAD12pin/2.0MMD1DIODED-SMAS-1206SS34D5ZC2800E/SOT_1D-SOD323SUDZ5.6BD6ZC2800E/SOT_1D-SOD323SUDZ5.6BD8BAT54CW-FQ-SOT23BAT54CW-FD22BAT54CW-FQ-SOT23NC/BAT54CW-FD32ZC2800E/SOT_1D-SOD323SUDZ5.6BD33ZC2800E/SOT_1D-SOD323SUDZ5.6BD34BAT54CW-FQ-SOT23BAT54CW-FD43BAT54CW-FSOT23BAT54CW-FD44ZC2800E/SOT_2ZD0805NC/UDZ5.6BD45BAS70-04/SOTBAV99-SOT23BAV99D46BAS70-04/SOTBAV99-SOT23BAV99D47BAS70-04/SOTBAV99-SOT23BAV99D48DIODE_1SOD3231N4148WSD2041_2.5KE10CAD12061N4148D2051_2.5KE10CAD12061N4148DP1DISPLAY_PORT_1MOLEX\47272DISPLAY_PORT-CONE2ESD_4RV-0603NC_5pFE3ESD_4RV-0603NC_5pFF4FUSER06030RH5JQIRMIPMARKAmarkH6JQIRMIPMARKAmarkH7ORIENTATION_4SCREW3.5RMorientationH8JQIRMIPMARKAmarkH9JQIRMIPMARKAmarkHDMI1CON34_3HDMI-S19X0.5-23HDMI-CONHDMI2CON34_3HDMI-S19X0.5-23HDMI-CONL1INDUCTOR_IRON_0L1206NC/FEB_1206L14INDUCTORL06030£[L21INDUCTOR_IRON_0L1206FEB_1206L22INDUCTOR_IRON_0L1206NC/FEB_1206L24INDUCTOR_IRON_2SMD08X08SWPA8040S2R2NT/4AL26INDUCTOR_IRON_2IND-4X4SWPA3015S2R2NT/1.5AL1204INDUCTOR_IRON_2SMD08X08SWPA8040S4R7NT/4ALW3LL0805BEAD/60R/0805LW4LL0805BEAD/60R/0805LW5LL0805BEAD/60R/0805Q7TRX_NPN-OQ-SOT23MMBT3904LT1GQ8MOSFET_P_GSDQ-SOT23NC/AO3401Q10PNP_0_2Q-SOT23PMBT3906LQ11PNP_0_2Q-SOT23PMBT3906LQ12MMBT3904L_0Q-SOT23LMBT3904LT1GQ15MOSFET_P_GSD_2Q-SOT23AO3401Q16NPN_3Q-SOT23PMBT3904Q23MOSFET_P_GSD_2Q-SOT23NC/AO3401Q24PNP_0Q-SOT23SST3906FQ25NPN_3Q-SOT23PMBT3904Q26NPNQ-SOT232N3904Q27NPNQ-SOT232N3904Q39NPN(BEC)_0SOT-233904Q206PNP_3SOT-233906S1SOT223-GOI-1234_14SINK_58X58MMPBU7LT1086_2U-SOT2231117/3.3VU9STS7PF30LU-SOP8/1.39435U10CS4334_2RT9026_MSOP-10RT9026U11BGA_34BGA1024_P0_8_27X27BGA_32X32U13X24C04_0U-SOP8/1.3X24C16 (SMD)U15VGA_CON15_015P229-2FVGA_CON15U16SOIC8/P1.27/7_0.98U-SOP8A/1.3SFLASHU172421_6U-SOT23-5UP7534GMA5U18SOT-223TO-252_NEWAMS1117L-3.3U20PAM2301SOT-23-5SY8088BU21SOT-223TO-252_NEWAMS1117L-3.3U22AOZ1036_32DFN2X2-8SY8805U23AOZ1036_32DFN2X2-8SY8805U201TPA3110D2_1TSSOP-28TPA3110LD2UD3DDR2_9DDR3DDR3UD4DDR2_9DDR3DDR3UDDC62421_0SO0824C02UX16CS4334_1RCLAMP524PNC/RClamp0524PY3CRYSTAL_0Y-DH514.318MHz **** Hidden Message *****
回 老吴 的帖子
老吴:[内容隐藏](2017-03-01 16:03) images/back.gif
好东西,看看 好东西,看看 这太高尚了 回复下下,先收藏了 看看,好东西 哈哈,最近这种牛逼的板子真是越来越多了 这太高尚了
