TSUMV56RJ+RT9116+SY8205液晶电视 PCB 和原理图共享下载
NamePart TypePCB DecalValueCN102INVERTER_1CN6-20ACON6-2.0CN201HEADER_1X4-2MM_180DCN4-20ACON4-2.0CN202CON9_1CN8-20ACON8-2.0CN301DIP-36(2_18)_0CON20X2-2.0-LVDSDIP\40\2X20CN401CON6_2_0.0MMCN7-20ACON7-2.0CN407HEADER_1X4-2MM_180DCN4-20ACON4-2.0CN601CON2CN2-20ACON2-2.0CN602CON2CN2-20ACON2-2.0D401BAV99_0D0402ESDD402BAV99_0D0402ESDD404BAV99_0D0402NCD405BAV99_0D0402NCF701FUSER1206NCF702FUSEAXIAL0.45A/12VH107HOLE-V8HOLE4-7NCH108HOLE-V8HOLE4-7NCH109HOLE-V8HOLE4-7NCH110CON3_3TPADNCH111CON3_3TPADNCH112CON3_3TPADNCH113CON3_3TPADNCH114CON3_3TPADNCH115CON3_3TPADNCL19INDUCTOR_0L0402NC/18nHL20INDUCTOR_0L04020RL21INDUCTOR_0L04020R/390nHL22INDUCTOR_0L0402560nHL23INDUCTOR_0L0402560nHL24INDUCTOR_1L0402FB/200mA/1000ohmL25INDUCTOR_5L0805NC/0RL26INDUCTOR_0L0402NC/220nHL27INDUCTOR_1L0402FB/200mA/1000ohmL87INDUCTOR_1L0402FB/50mA/1000ohmL101L3X3_2.2UH_1_0.5ASMD03X032.2uH/1.5AL701INDUCTOR_IRON_2SMD08X08SPM6530T-4R7MLED7017012X/SM_2LEDLED/REDP401HDMI_J_2_VERTER_2HDMI_TYPE_AHDMI/90DP402USB-B_1USB_MINI_4PUSB2.0/90DP403CONNECTOR_COAX-J_0RCV3-14MM-1AV3P404CONNECTOR_COAX-J_0_2RCV2-14MM-1AV2P701DC_JACK_0DC-JACK3PDCJACKQ201NPN(BEC)_1SOT-23NC/3904Q301P_DGS_3SOT23-100AO3401AQ302P_DGS_3SOT23-100NC/AO3401AQ303NPN(BEC)_1SOT-233904Q402NPN(BEC)_1SOT-233904Q601NPN_BEC_3SOT-233904Q602PNP(BEC)_0SOT-233906Q603NPN_BEC_3SOT-233904Q701P_DGS_2SOT23-100AO3401AQ702P_DGS_2SOT23-100AO3401AQ703NPN(BEC)_1SOT-233904Q704NPN(BEC)_1SOT-233904Q705NPN(BEC)_1SOT-233904T1TRF_ATB2012_75011_NTPTRANS_ATB2012BW21S7511A01TFTP201TEST_POINT_1TP-0.5MMNCTU4FK1602_CAN_TUNERFK1602NC/FK1602TU5CON3_2TUNER-C2RFU7MXL601RF_0QFN24_MXL601MxL661U8SOT-223SOT-223AMS1117L-3.3U9MSD91RQN_80_1IC-80P-LQFP-10X10-P04TSUMV56RJXXU101SOT-223_1SOT-223AS1117L-3.3U102SY8008B_1.2ASOT-23-5SY8077/1AU103LDO_SOT-223_1117-ADJSOT-2231117-ADJU202IRIR-1IRU203M24CXX_0SOP8-255-50MX25L3236FU204M24CXX_0SOP8-255-50NCU601TC0177/TPA3110_0QFN4X5_28L_0-5_3RT9116U701AOZ1036_2DFN4X3-12SY8205Y5CRYSTAL-2PIN_0XTAL\HC49\F24.000MHzY201CRYSTAL_12XTAL\HC49\F24MHz
这个之前有发的哦不知道是不是一样的 woshiwangyuxiang 厉害了,我的哥 听说56RJ后来芯片改过了,老版电路与新版芯片不通用了。 支持支持
