英特尔方案平板PCB共享( Z3735F_G+ALC5640+AXP288+RL_SM02BD_8723BS+BC
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1ANT_WFL-R-SMT_ANT-IPEX_WFL-R-SMWFL-R-SMTANT-IPEXANT2ANT-WIFI-2_0_ANT-WIFI-2_ANT-WIFANT-WIFI-2ANT-WIFI-2BAT1BATTERY_0_CON-SMT-1_25-5P_LI_3.LI_3.7VCON-SMT-1_25-5PCON14CON RF I-PEXMHF-20279_0_ANT-IPU.FL-R-SMTANT-IPEXCR24LED0603_LED0603_LED0603LED0603LED0603CR25LED0603_LED0603_LED0603LED0603LED0603CR3502DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9400ESD9X7V_SMCR_1P0XP6_FBP02C_ESD9ESD9X7V-2T/RSMCR_1P0XP6_FBP02CCR9401DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9402DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9403DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9500DIODE_SMCR_SC79_BAP63-02_H11513BAP63-02SMCR_SC79CR9501DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9502DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9503DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9504DIO_ESD_E0402S_ESD9N5BM-2/TR_H3ESD9N5BM-2/TRE0402SCR9507DIODE_SMCR_SC79_BAP63-02_H11513BAP63-02SMCR_SC79D6LED_6_IR-LED-D3_IR12-21C-TR8IR12-21C-TR8IR-LED-D3D10DIODE_0_SOD123_1N58191N5819SOD123D902D_1N5819HW_SOD123_1N5819HW1N5819HWSOD123D903DIODE_0_SOD123_1N58191N5819SOD123ED26DIODE BI-DIRTRIG_E0402S_ESD9B5ESD9B5VE0402SED27DIODE BI-DIRTRIG_E0402S_ESD9B5ESD9B5VE0402SED28DIODE BI-DIRTRIG_E0402S_ESD9B5ESD9B5VE0402SED29DIODE BI-DIRTRIG_E0402S_ESD9B5ESD9B5VE0402SED30DIODE BI-DIRTRIG_E0402S_ESD9B5ESD9B5VE0402SFB7FB0402_SMR0402_600R@100MHZ600R@100MHzSMR0402FB7000FERRITE_ALTSIZE_SMF0402_1P15XP6FERRITE_ALTSIZESMF0402_1P15XP65_P65HFB7015INDUCTOR_L0402_600R/100MHZ600R/100MHzL0402FB7016INDUCTOR_L0402_600R/100MHZ600R/100MHzL0402FIL1FIL_SAW-856561_DFN5_B9482(1575MB9482(1575MHz)DFN5FIL2FIL_SAW-856561_DFN5_B9482(1575MB9482(1575MHz)DFN5IR1IR_RECEIVE_2_IRM-V538_TR1_IRM-VIRM-V538/TR1IRM-V538_TR1J6CON6_0_CON-FPC-0_5-5P-OP_5PIN0.5PIN0.5CON-FPC-0_5-5P-OPJ7HDMI CONG3168-0500XXXX-00_HDMIHDMI-MINI-19P-CBS-B4501H-BELLHDMI-MINI-19P-CBS-B4501H-BELL-1J11PJ381-2_0_PJ-B2318S-BELL_PJ-B23pj-b2318s-bellPJ-B2318S-BELLJ13TOUCH_SCREEN_1_CON-FPC-0_5-12P_Touch_screenCON-FPC-0_5-12PJ3500CON6_WTB_MTG2_1X6_P8MM_WTB_ACESCON6_WTB_MTG21X6_P8MM_WTB_ACES_50208J3501CON12_MICROSD_MTG4_3_TF-CARD_COCON12_MICROSD_MTG4TF-CARDJ8504CON24_RCPT_CAM_BYT_CR_CON-BTB-PCON24_RCPT_CAM_BYT_CRCON-BTB-P0_4H1_5W4_1F-24P-OPJ8505CON24_RCPT_CAM_BYT_CR_CON-BTB-PCON24_RCPT_CAM_BYT_CRCON-BTB-P0_4H1_5W4_1F-24P-OPJ9700CON40_RCPT_2X20_P4MM_BTB_RCPT_DCON40_RCPT2X20_P4MM_BTB_RCPT_DF40CJ9900CABLE_HOLDER_CABLE_HOLDER_SV08MCABLE_HOLDERCABLE_HOLDER_SV08MJ9901CON-SMT-1_0_CON-PAD-2_5-2P_CON-con-pad-2_5-2pCON-PAD-2_5-2PJ9902CON-SMT-1_1_CON-PAD-2_5-2P_CON-con-pad-2_5-2pCON-PAD-2_5-2PL14L0402_SMR0402_0R0RSMR0402L15L0402_SMR0402_6.8NH6.8nHSMR0402L16L0402_SMR0402_6.8NH6.8nHSMR0402L19INDUCTOR_1_IND-4X4_4.7UH/1.5A4.7uH/1.5AIND-4X4L901L_LVS404018_IND-4X4_10UH10uHIND-4X4L2000IND_ALTSIZE_SML2520_1P2H_1.0UH_1.0UHSML2520_1P2HL9509CHOKE_4PIN_ALT_SML_4P_43X53_C_180OHM_100MHZSML_4P_43X53_CM_P35HL9510INDUCTOR_0_L0201_4.7NH4.7nHL0201L9511INDUCTOR_0_L0201_NC/4.7NHNC/4.7nHL0201LCD4LD089WU1_2_CON-FPC-0_5-40P_LD08LD089WU1CON-FPC-0_5-40PQ5MOSFET_N_SOT523_CJ1012CJ1012SOT523Q1040852_1_SOT23_39043904SOT23Q30MOSFETP_SOT23_VIC1121VIC1121SOT23Q31MOSFETP_SOT23_VIC1121VIC1121SOT23Q34MOSFETP_SOT23_VIC1121VIC1121SOT23Q35NPN_0_SOT23_VIC1221VIC1221SOT23Q54MOSFET_N_SOT523_2SK30192SK3019SOT523Q55MOSFET_N_SOT523_CJ1012CJ1012SOT523Q56MOSFET_N_SOT523_2SK30192SK3019SOT523Q57MOSFET_N_SOT523_2SK30192SK3019SOT523Q58MOSFET_N_SOT523_NC/2SK3019NC/2SK3019SOT523Q59MOSFET_N_SOT523_NC/2SK3019NC/2SK3019SOT523Q60MOSFET_N_SOT523_2SK30192SK3019SOT523Q74MOSFET_N_SOT523_2SK30192SK3019SOT523Q91MOSFETN_SOT23_VIC1221VIC1221SOT23Q2000WPM1481_LCC6_P65MM_SQ2P05MM_NS_WPM1481LCC6_P65MM_SQ2P05MM_NSQ8405MOSFETN_SOT23_VIC1221VIC1221SOT23RT2000THERMISTOR_SMRT0402_27X47_10K_D10KSMRT0402_27X47RT2001THERMISTOR#1_SMRT0402_27X47_10K10KSMRT0402_27X47SH1000SHUNT_LOCAL_SHUNT_0402_SHUNT_LOSHUNT_LOCALSHUNT_0402SH2003SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDSHUNT_L4-SIG_PWR_P4XP6SH2004SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDSHUNT_L4-SIG_PWR_P4XP6SH2005SHUNT_BYT_CR_MRD_SHUNT_BOTTOM_PSHUNT_BYT_CR_MRDSHUNT_BOTTOM_P4XP6SH2006SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDSHUNT_L4-SIG_PWR_P4XP6SH2007SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDSHUNT_L4-SIG_PWR_P4XP6SH2008SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_PSHUNT_BYT_CR_MRDSHUNT_L4-SIG_PWR_P4XP6SH9001SHUNT_LOCAL_SHUNT_0402_SHUNT_LOSHUNT_LOCALSHUNT_0402SW7000LS77C2DE_T_0_SWI-INT-1100AAGS-ALS77C2DE_TSWI-INT-1100AAGS-AIR-1SW7001LS77C2DE_T_0_SWI-INT-1100AAGS-ALS77C2DE_TSWI-INT-1100AAGS-AIR-1SW7002LS77C2DE_T_0_SWI-INT-1100AAGS-ALS77C2DE_TSWI-INT-1100AAGS-AIR-1T8TEST_1_SHIELD-PTC0703B-5P_SHIELSHIELDSHIELD-PTC0703B-5PTP46TP_1_TESTPAD_C20_TESTPAD_C20TESTPAD_C20TESTPAD_C20U10MINIUSB_0_USB-5P-MICRO-DIP-BELUSBUSB-5P-MICRO-DIP-BELL-1U17MAX2659_0_AFN_MAX2659_MAX2659MAX2659AFN_MAX2659U18U_BCM4752IFBG_BGA49_P65_5SQ_1P3BCM4752IFBGBGA49_P65_5SQ_1P3H_PAD12MILU19LPW5206H_SOT25_DS9715ABGDS9715ABGSOT25U24ESD SPE6V8UDDFN-10_0_SLP2510P8SPE6V8UDFN10RGBSLP2510P8U26BCM43438_0_WLBGA60-0_4-5_35X3_3BCM43438WLBGA60-0_4-5_35X3_35-BCM43438U27LFB212G45CG7D227_1_LFB212G45CG7LFB212G45CG7D227LFB212G45CG7D227U42DS8008_4_SOT23_5_NC/ME6211-33NC/ME6211-33SOT23_5U214ESD SPE6V8UDDFN-10_0_SLP2510P8SPE6V8UDFN10RGBSLP2510P8U225KXCJ9-1008_LGA10_0_65_3X3MM_KXCKXCJ9-1008LGA10_0_65_3X3MMU902U_MP3202_SOT26_MT9201MT9201SOT26U1000SOC_VLV2_CR_CONCEPT_CUST_WW3_BGSOC_VLV2_CR_CONCEPT_CUST_WW3BGA592_P65MM_17X17U2003AXP288_1P04_LCC76_P4MM_SQ9P1MM_AXP288_1P04LCC76_P4MM_SQ9P1MM_EP5P5U2005LP3211_0_SOT23_6_1P295H_LP3211_LP3211SOT23_6_1P295HU2006G5121_1_SOT26_MT3608MT3608SOT26U3005MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3006MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3101MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3102MT41K256M16_BGA96_P8MM_9P1X14P1MT41K256M16BGA96_P8MM_9P1X14P1U3500MX25U1635E_0_SOP8-50-210_MX25U1MX25U1635ESOP8-50-210U3501KLM8G1WEMB_B031_0_BGA153_11P5X1KLM8G1WEMB_B031BGA153_11P5X13_12MILPADU6206RL_SM02BD_8723BS_LCC44_P9MM_SQ1RL_SM02BD_8723BSLCC44_P9MM_SQ12_1P6HU7001ALC5640_VB_LCC48_P4MM_SQ6MM_1P0ALC5640_VBLCC48_P4MM_SQ6MM_1P0HU700274LVC1G126_SOT23_5_74LVC1G126_G74LVC1G126SOT23_5U7200MIC_AMS_O40S42_EC1_1_MIC-4020_SMIC_AMS_O40S42_EC1MIC-4020_SMD-P2_4U8001KXCJK_1013_LCC16_NS_P5MM_SQ3MM_KXCJK_1013LCC16_NS_P5MM_SQ3MM_1P01HU8002AK09911C_12MILPAD_BGA8_P4MM_1P1AK09911C_12MILPADBGA8_P4MM_1P19SQ_P57H_12MILPADU8003BMC150_LCC14_P4MM_2P2SQ_BMC150_BMC150LCC14_P4MM_2P2SQ_BMC150U8024BMG160_LCC12_NS_P5MM_SQ3MM_1P0HBMG160LCC12_NS_P5MM_SQ3MM_1P0HU9001TUSB1210_LCC32_P5MM_5SQ_EP3P45_TUSB1210LCC32_P5MM_5SQ_EP3P45U900974AVC1T45YZP_BGA6_5MM_1P4_P9_7474AVC1T45YZPBGA6_5MM_1P4_P9U9010AOZ6184_DPDT_LCC10_P4MM_1P8X1P4AOZ6184_DPDTLCC10_P4MM_1P8X1P4Y5KT2016A26000ACW18TLG_BRCM_0_TCXKT2016A26000ACW18NANTCXO_KT2016_2X1D6_0D8Y6CRYSTAL-4_0_CRY-D3225_26M-20PPM26M-20ppmCRY-D3225Y1000XTAL_4PIN_SMY_4P_79X98_PAD37X3925.0MHZSMY_4P_79X98_PAD37X39_24HY1001XTAL_0_FC135_32.768KHZ_G41053-032.768KHZFC135Y6200OSC_TCXO_ALT_SMY_4P_2P15X2P65_P26MHZSMY_4P_2P15X2P65_P8H 6层设计。
厉害了 这个太厉害了 谢谢分享英特尔方案平板PCB共享 这么复杂的板子厉害啊 好东西非常喜欢
