chen468859 发表于 2017-10-20 11:51
AD:RT5350路由器 原理图+PCB(第一次画4层板,没有验证)
CommentDesignatorFootprintQuantityNIC140214.7uFC2060310 ohmC30402110nFC404021NIC50402110pFC604021100pFC7040211uFC8040210.1uFC904021100pFC1004021100pF/NIC11040210.1uF/NIC12040211uFC140402127pFC15040210.1uFC160402110pFC170402122nFC18040212.7pFC35040211.2pFC36040211.5pFC37040212.7pFC38040211.2pFC40040214.7uFC42060310.1uFC43040211.2nFC48040211.2nFC50040210.1uF/NIC51040211.2nFC58040211.2nFC60040211.2nFC65040211.2nFC67040211.2nFC71040211.2nFC73040211.2nFC77040211.2nFC79040214.7uFC84060314.7uF/NIC90060310.1uFC91040210.1uFC92040214.7uFC93060310.1uFC98040216.8nFC10004021220uFC101CAP315110uFC102060314.7uF/NIC103060310.1uFC104040211.5nFC1050402168pFC106040214.7uF/NIC107060310.1uFC108040214.7uFC109060310.1uFC110040211uFC111040214.7uFC112060310.1uFC113040210.1uFC114040210.1uF/NIC11504021470pF/NIC15304021470pFC154040211000pF/2KV/NIC15512061470pF/NIC15604021470pFC157040210 ohm/SBC158120610 ohm/SBC159120610 ohm/SBC16012061470pFC161040210 ohm/SBC162120611000pF/2KV/NIC16312061330uF/25VC165CAP315122uF/NIC1951206110uF/NIC196120610.1uF/NIC197040210.1uF/NIC198040214.7uF/NIC199120610.1uF/NIC20004021470uFC236CAP31510.1uFC2420402110nF/NIC24304021470uFC244CAP31510.1uFC247040218.2nFC24804021680pF/NIC249040210.1uF/NIC250040214.7uFC2510402110PF/NIC2520402110pFC278040215.6nHC284040212.2pFC285040211.8pFC28604021NIC287040213.3nHC381040212.7nHC3820402110PF/NIC3840402110uF/NIC386080510.1uFC387040210.1uFC388040210.1uFC389040210.1uFC390040210.1uFC391040210.1uF/NIC392040210 ohmC405040211.2pF/NIC406040211.5pF/NIC407040211.2pFC409040210.1uFC414040211.5pF/NIC415040210 ohm/NIC420040210.1uFC422040214.7uF/NIC4230603110PF/NIC4240402110PF/NIC4250603110PF/NIC4260603110PF/NIC4270603110PF/NIC4280603110PF/NIC4290603110PF/NIC430060314.7uF/NIC433060310.1uF/NIC434040210.1uF/NIC43506031470uF/NIC436CAP-1106-DIP10.1uF/NIC437060311000pF/NIC43804021100pF/0603C4410603/040210.1uF/NIC4420402110pFC443040213.3nHC444040210.1uF/NIC44504021SMA/UFLRCON1UFLR-MINIPCI1SMA/UFLRCON2UFLR-MINIPCI1TVS SMCJ16A/NID16DO-214AB11N4148/NID19DO-214AC1LEDD2006031LEDD2106031LEDD2306031LEDD2406031LEDD2506031LEDD2606031LEDD2706031LEDD2806031LEDD2906031SK34A/NID31DO-214AC1V-PORT/NID3406031V-PORT/NID35060311N5819,DO1607/NID36DO16071USB-ANT-RAE1ANT-RT5370-AP-D95951DC JACKJ3DC-JACK1HEADER 4x1J4SIP410 ohm/SBL10603/040212.2nHL11040212.7nHL12040214.7uH/VLC5045L14VLC5045T10 ohm/SBL160603/040210 ohm/SBL170603/040210 ohmL24120610 ohmL251206115uH/GDR0810PU150KL33GDR-081010 ohmL34060310.8pFL51040213.3pFL52040210 ohmL530402122uH,DIP,RingCoil/NIL670L_D6H14112K 1%R1040218.2K 1%R80402110KR12040211KR13040211KR14040211KR15040211KR16040211KR17040211KR180402122R21040214.7K/NIR24040214.7K/NIR250402149.9 1%R260402149.9 1%R270402149.9 1%R280402149.9 1%R290402149.9 1%R310402149.9 1%R320402149.9 1%R380402149.9 1%R390402149.9 1%R400402149.9 1%R410402149.9 1%R480402149.9 1%R49040219.1K 1%R500402149.9 1%R510402149.9 1%R520402149.9 1%R530402149.9 1%R540402149.9 1%R550402149.9 1%R560402149.9 1%R570402149.9 1%R58040214.7K/NIR66040212K 1%R670402147 ohm 1%R680402116.9K 1%R70040214.7KR71040214.7K/NIR88040214.7K/NIR89040214.7KR94040214.7KR95040214.7K/NIR101040214.7KR107040214.7K/NIR112040214.7K/NIR113040214.7k ohmR118040214.7KR119040214.7K/NIR136040214.7k ohmR142040214.7KR144040214.7K/NIR146040214.7K/NIR148040214.7k ohmR150040214.7K/NIR152040214.7k ohmR1540402175R1600402175R1610402175R1620402175R1630402175R1640402175R1650402175R1660402175R1670402175R1680402175R1690402175R1700402175R1710402175R1720402175R1730402175R174040210 ohm/SBR1830402120KR1880402122R189040214.7K/NIR19004021330R191040214.7KR19204021330R193040214.7K/NIR195040210 ohm/NIR19604021330R197040214.7K/NIR198040214.7KR199040210 ohmR20004021330R20104021330R20204021330R20304021330R20404021330R20504021330R206040210 ohm/SBR21004021845K 1%/NIR211040211K ohmR21204021100KR2480402139K 1%R2500402115K 1%R251040213K 1%R252040210 ohm/SBR280040212K 1%R284040210 ohm/NIR286040214.7KR2930402133/NIR2950402110KR2980402151 ohmR300040210 ohm/SBR306040214.7K/NIR307040214.7k ohmR308040210 ohmR309040210 ohmR310120610 ohmR311120610 ohmR312120610RR31312061100KR/NIR314080515.6KR,1%/NIR315080511KR,1%NIR316080510 ohm/NIR317040214.7KR318040210RR31904021100 ohm/1%/0603R3200603/0402110uFRC106031SW TACT-SPSTS1SW4P1SW TACT-SPST-RAS2SW2P1SW TACT-SPST-RAS3SW2P1XTAL_3.2x2.5SH1RT5350-SHELDING122SR1040214.7KSR204021RT5350SFU1TFBGA19617x2 Header /BOXU5DCONN7X21AT24C02A/SB/NIU6SOIC-81BAT1664M3/NIU7SOT-891APM2701ACU8SOT-23-61MX25L3205DM2IU10SO81HN2066CGU16DIP-20PIN-25101RJ-45X4-No-ShieldU17RJ45-4P1HN2066CGU18DIP-20PIN-25101RJ-45X1PU19RJ45A1hn1674CGU20DIP-16PIN-20101G693L_R3132Q/NIU25SOT-143/SC-82AB1IT7652/2AU28SOP8-1.27-6-EP120MHz +/- 10ppmU33XTAL-DIP-3X91SDRAM 16MX16U35TSOP2-54P-400mil1AX3023,SOT23-5/NIU36SOT23-515pF/NIUC1040215pF/NIUC204021C-UBR27-00-00USB1USB_A-RECEPT-R/A-DIP1
2749237077 发表于 2017-10-20 12:44
路途之路 发表于 2017-10-20 12:57
mgceshuang 发表于 2017-10-20 13:08
xnima_irumei 发表于 2017-10-20 13:55
菜鸟的名义 发表于 2017-10-20 16:11
免费?
gzwireless 发表于 2017-10-21 20:59
学习一下
333zc 发表于 2017-12-26 10:49
看看再说吧
hhwnlrm 发表于 2018-1-22 11:36
看看再说吧
quiet0607 发表于 2018-4-17 15:48
看看
页: [1] 2 3
查看完整版本: AD:RT5350路由器 原理图+PCB(第一次画4层板,没有验证)
